During the Summer, are there any pros or cons to removing the 5.0 engine shroud? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 05-27-2015, 07:32 PM   #1
I hClick image for larger version
Name:	ImageUploadedByMustang Evolution1432776720.919157.jpg
ID:	183523ave a 2015 GT 5.0 PP MT 6. Our Summers here are in the 90+ range. I realize the PP option gives a larger radiator but would removing the engine shroud during the Summer help to keep the engine cooler and help keep down the under hood temps?
retiredf5 is offline   Reply With Quote
Old 05-28-2015, 07:06 AM   #2
If you want to do it, but I'd guess the difference would be very minimal. Hopefully Fords engineers and designers put enough thought into it to optimize heat dissipation. Also, the shrouds could concentrate air flow for heat extraction and removing could possibly have the opposite effect.
bmatticus is offline   Reply With Quote
Old 05-28-2015, 07:31 AM   #3
oxford5pointoh's Avatar
If you try it, hook up an OBD II tool while your driving that gives you the exact temp, then try it with and without in similar conditions. Then you will have the real answer. I doubt anyone in here will know for sure. My guess is that it won't make a difference but who knows.
IG @Oxford5pointoh
Old 05-28-2015, 08:12 AM   #4
Strange Mud's Avatar
this is one of those air flow/insulation answers that like Ox said you'll need to test. My guess is there will not be enough of a difference to matter except it won't look as cool
pun intended
Old 05-28-2015, 12:32 PM   #5
Do whatever you want ---BUT---
The shroud funnels the air coming in through the radiator. There is an electric fan that will come on when needed. I live in Florida and do not have a temperature problem at all.
I'm guessing you are just asking for trouble removing the shroud.
ANOTHER REASON I DON"T BUY A USED CAR
Old 05-29-2015, 08:12 AM   #6
thelastsumurai's Avatar
I took mine off a week after I got my car no problems. I just want it to look new/good for when I trade for my '16 GT500
'16 Eco-Boost Premium, White, Performance Pkg, 6R80 (again), Pwr Ebony Lthr with Nether Region Cooling, Adaptive Cruise Control, Enhanced Security Pkg., Reverse Park Assist., Big Worm OTT Graphix.
2014 GT Premium 200A, Black on black , leather , 6R80, Nav, Security. Pro Cal, HT catback exhaust 12.54@112
thelastsumurai is offline   Reply With Quote
Old 05-29-2015, 10:09 PM   #7
cboyd's Avatar
I don't think there is any need to change anything under the hood for a DD I live in Houston where it is hot all the time and never have had an issue with the temperature under the hood. Also that shroud under the hood is a fire blanket if your engine was to ever catch on fire for some reason, like if you were in a wreck or something.
cboyd is offline   Reply With Quote
Pros and Cons of SCT Tuner 2011Rushracing 2011-2014 V6 Mustang 5 08-18-2011 05:59 PM
Need advice on Zoom clutches before i install it ne one ever had one ?? pros and cons Justbust1n 1979-1995 Mustang GT 5 03-01-2011 03:22 PM
UPR X Pipe:pros and cons TheWop 1996-2004 Mustang GT 6 01-07-2011 05:48 PM
BBunt302's Manual on the Pros/Cons of Using Proper Grammar on the Internet bbunt302 The Bar 15 04-13-2009 09:01 AM
Pros and cons NorwegianMustang Pre-2005 V6 Mustang 12 02-26-2005 11:53 AM
05:43 PM
