Ford racing x-pipe - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 06-08-2015, 10:05 PM   #1
Ford racing x-pipe
Has anyone installed the ford racing x-pipe on their 2015 GT? I was trying to decide on it versus an h-pipe.
v8shep is offline   Reply With Quote
Old 06-09-2015, 01:44 PM   #2
14sgmgt's Avatar
I actually have the h pipe preordered from CJs. Think it will go well with my Ford racing touring AB.
14sgmgt is offline   Reply With Quote
Old 06-09-2015, 03:37 PM   #3
Is it stainless also? I'm not sure I like the total seal clamps the ford racing comes with either.
Old 06-09-2015, 04:11 PM   #4
14sgmgt's Avatar
No it's not but also only $120.
Old 06-09-2015, 04:43 PM   #5
Were you going to have it welded in or use clamps on the cut sections?
Old 06-09-2015, 07:47 PM   #6
mats96744's Avatar
i got the frpp x pipe w/quad tip roush axel back! surprisingly the 6 clamps hold up good! i checked a couple times since installing the exhaust and clamps still on tight!
mats96744 is offline   Reply With Quote
Old 06-09-2015, 08:07 PM   #7
14sgmgt's Avatar
I will use the clamps that come with it. I don't see the need to weld anything.
Old 06-09-2015, 09:27 PM   #8
The clamps just wrap around the two pipes that are end to end and no leaks? That's good. Any problems cutting the resonator out?
Old 06-09-2015, 09:54 PM   #9
14sgmgt's Avatar
Just make sure you take the whole exhaust off before you cut. Don't want to hit the fuel tank😟
Old 06-09-2015, 10:53 PM   #10
mats96744's Avatar
water comes out all the clamps. but its normal! the 2 clamps provided by frpp form to the pipes! fits good and holds strong doesn't sag or flex. plus i have the roush quad exhaust which i think is a little heavier than the stock! mine lined up perfectly so there was no gap between the pipe.
Old 06-09-2015, 10:59 PM   #11
mats96744's Avatar
Ford racing x-pipe
jus cut it to what the directions say! i jus put a piece of tape around for a guide and used my sawzall! its not as nerve wrecking as it seems. i use a sawzall for my job so i was confident in that part. if u never used one maybe practice first and get the right blade for the job. and what 14sgmgt said take out the whole exhaust, easier to measure and easier to cut and safer imo. dont want to get any metal shavings in your eyes!
Old 06-24-2015, 12:59 AM   #12
kennolee's Avatar
I installed the X-pipe with the Roush Axle-backs, sounds great. I jacked the car up in the garage to do it. The biggest issue I had was trying to fit under the car in a way that I could achieve leverage for using the Sawzall. If you use the jack-method, use care as not to cut into the floorboard. Also, I would recommend NOT using an impact (it is not recommended anyway). My 20V Dewalt "Impact" did the trick. The engine side clamps gave a little challenge to get off, but not much. The resonator is heavier than you'd expect, but not bad for the way you have to remove it.
Sent from Kennolee using Mustang Evolution
kennolee is offline   Reply With Quote
H pipe vs x pipe vs straight pipe 509pony 2005-2010 Mustang GT 100 02-15-2015 09:35 AM
ford racing h-pipe with side exhaust Merben50 2011-2014 Mustang GT 7 07-07-2012 07:16 PM
Ford racing x-pipe Edens5 2011-2014 Mustang GT 17 06-17-2012 05:48 PM
What would ford racing x pipe do? NicholasP 2011-2014 V6 Mustang 3 05-15-2012 12:53 AM
Ford racing clamp on x-pipe godsdisciple85 2011-2014 Mustang GT 8 12-20-2011 01:24 PM
05:32 PM
