Base modle gt rim size - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 07-10-2015, 08:39 PM   #1
Should I stay with 18s or move up to 19s and what's a good off set
Ibad5.0 is offline   Reply With Quote
Old 07-10-2015, 09:03 PM   #2
NewMtang's Avatar
18s
Go to the 18s, the 19s are more expensive and there isn't that much of tire size to choose from.
Depends on your driving.
Old 07-11-2015, 09:07 PM   #3
I haven't seen any 18 options for the 2015. I see a ton on American Muscle for 05-14 Mustangs, but not for the 15. I asked them why there are no 18 options and they said the base model brakes are bigger then the previous years and that the 18 inch wheels wont clear them. I really want the black AMR wheel that are so popular but I don't want to have to buy new tires with them, I would rather just use my tires with an 18 inch rim.
Tennis_pro is offline   Reply With Quote
Old 07-11-2015, 10:34 PM   #4
Well....my 2015 came from the factory with 18 inch wheels....and they do clear the brakes. The tires are 235/50 R18 Pirelli P Nero Zeroes.....
Old 07-11-2015, 11:06 PM   #5
natestang07's Avatar
That's not true. I thought the only ones that needed 19's were bembo equiped cars
Old 07-11-2015, 11:41 PM   #6
My gt came with 18s I wanna know should I stay 18s or upgrade to 19s
Old 07-11-2015, 11:52 PM   #7
I would stay 18. 19s will be more expensive to replace and there seem to be fewer options
Old 07-12-2015, 05:01 AM   #8
Yes mine came with 18 inch wheels also. I have the base model so no brembo brakes for me either. However, when I called American muscle and asked them about 18 inch options for the 2015 they said that the aftermarket 18 inch wheels will not clear even the base model brakes. This could be wrong information, however I'm just telling you what they said. If you look on their website, there are no 18 inch options for the 2015.
Old 07-12-2015, 05:42 AM   #9
I went on tore rack and actually found a bunch of 18 inch that would fit the 2015. Seems the offset is like 10 mm more than the 14. I wanted to order those AMR wheels from AM but since they don't have an 18 option I actually found one that looks very similar on tire rack and am probably gonna go with that.
http://www.tirerack.com/wheels/Wheel...autoModClar=GT
Old 07-12-2015, 08:27 AM   #10
Have you checked the weight of these wheels compared to the stock ones? If they are about the same, then all is good......however even adding 8 pounds to unsprung weight at each corner is going to make a massive difference in slower acceleration, decreased mpg and worse handling.
I once went with heavier custom chrome wheels on a 2008 base Corvette. They ruined the off the line acceleration, and lowered my mpg by 10%. It's called rotational inertia......look it up and research the weight of every wheel you consider, or you could be as sorry as I was.
Old 07-12-2015, 06:27 PM   #11
Grabber Blue5.0's Avatar
Mine came with 20's. These cars look good with a big wheel.
Old 07-12-2015, 07:12 PM   #12
/\ make a build thread.
Best Replacement Front & Rear Speakers for 2014 Base Coupe base stereo GT 1 2011-2014 V6 Mustang 8 07-05-2014 10:42 AM
Base 13 V6 or Base 13 5.0 2011 Kona Blue General Mustang Discussion 68 03-12-2013 09:50 AM
WTT/WTB .... Rim or Rim & Tire swap back n a stang Mustang Parts for Sale and Wanted 0 10-19-2012 03:47 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
What modle is this Fordhartbreaker Pre-2005 V6 Mustang 2 03-02-2012 12:31 PM
12:17 PM
