Ford should have had this from the factory --- no more prop rod!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 07-14-2015, 04:29 PM   #1
I was actually surprised that a car that cost as much as the GT premium still had a prop rod for the hood. The hood is on the heavy side, the prop rod is way long and the hole to put it in is WAAAAAAY over there across the hood. It also restricts access when you are cleaning/working around the engine compartment.
The modification to install hydraulic prop rods is a no-brainer -- first thing any new Mustang owner should install.
I got the Redlines, and their install video is excellent. I went slowly and carefully, and still had them on the car in less than 1/2 an hour. They look and work great, and they even relax their force when the hood is going down so that the last foot or so is unassisted and you can easily slam the hood. Great product, and if you have not done this for yourself, you should strongly consider doing so......they even open the hood further than where the hood sat on the stock prop rod. Its also a very nice touch that Redline now includes the shaped drill bit for doing the exact right sized hole you need to drill in the battery cover. That is a class addition that they would not have needed to do.
Old 07-14-2015, 04:44 PM   #2
Jbone007's Avatar
Agree, one of my 1st few mods!! Got mine from AM!
Jbone007 is offline   Reply With Quote
Old 07-14-2015, 04:53 PM   #3
Got mine from CJ's...........both are good vendors.
Old 07-14-2015, 05:07 PM   #4
Smoked50's Avatar
Agreed, I have the Steeda
Smoked50 is offline   Reply With Quote
Old 07-15-2015, 11:03 AM   #5
scurfie's Avatar
I agree the Redline hood struts are excellent.
I would also suggest a JLT oil separator too. Surprising how much oil would be sucked back into your manifold.
scurfie is offline   Reply With Quote
Old 07-15-2015, 11:35 AM   #6
Thanks, I'll take a look........might you have the link to where you got yours?
Thanks!
Old 07-15-2015, 11:43 AM   #7
scurfie's Avatar
Thanks!
Yes sir! JLT Performance Mustang Oil Sep Pass Side GT/Boss 302 2011-15
And yes I wrote a review but I do NOT receive any compensation from CJ Pony Parts.
Old 07-15-2015, 12:20 PM   #8
Smoked50's Avatar
Agree the JLT oil seperator is next on my list..
Old 07-15-2015, 12:25 PM   #9
Kelleniz is offline   Reply With Quote
Old 07-15-2015, 12:52 PM   #10
Blue302's Avatar
I ordered the Redline stainless steel struts, can't wait to put them on. I agree they should be standard for higher trim levels
Blue302 is offline   Reply With Quote
Old 07-15-2015, 01:07 PM   #11
I've hated that damn hood stand on my car since the first time I saw it. I've got Roush hood struts ready to be installed, hopefully this weekend. Just makes a car look so cheap.
Old 07-15-2015, 01:22 PM   #12
scurfie's Avatar
Absolutely! Hood struts should be standard.
I put a Steeda G-Trac K-member brace on my Mustang, just because it's a convertible. Why were there threaded holes towards the the front of the frame from the factory? It was as if Ford knew people would add the brace.
Old 07-15-2015, 01:25 PM   #13
Rapinator126's Avatar
The JLT oil separator is junk. Why don't yall do some research vs going after everything someone else thinks works.
Old 07-15-2015, 01:30 PM   #14
scurfie's Avatar
I have caught oil in my JLT separator. I was surprised how much there was too. There are other makes of oil separators if you think the JLT is junk.
Old 07-15-2015, 01:32 PM   #15
I know it's junk.
But it's your car. That's what separates the real cars and the "I think I know " cars
Old 07-15-2015, 01:34 PM   #16
natestang07's Avatar
Every car my family has had that had the hydro prop rod has stopped working. Is this a normal occurrence later down the road?
Old 07-15-2015, 01:35 PM   #17
The JLT has been proven in tests to be one of the least effective cans.
Old 07-15-2015, 01:38 PM   #18
You thinkin' Bob's?
I wonder what the weight difference is between having a skinny little rod holding the hood up, or using two massive, oil filled, hydraulic cylinders to do the infrequent job of holding the hood open.
We are all about performance here at ME, gentlemen...
Old 07-15-2015, 01:40 PM   #19
Originally Posted by straybullitt View Post
You thinkin' Bob's?
And not to mention in the winter time my Maxima good really enjoyed dropping on my head while I did stuff. Wonder if I can sue Nissan for brain damage.
Old 07-15-2015, 02:00 PM   #20
The trunk lid on my Mustang does the same thing to me! Soon, I am going to start wearing a bicycle helmet everywhere that I go, to prevent any further brain damage. I'm gonna get a sticker to put on the front of the helmet that says, "Hi. My name is Straybullitt".
Of course, those struts will eventually fail, like all of the rest of them, and will get replaced after a few good bumps on the head while checking the oil.
Old 07-15-2015, 02:16 PM   #21
My uncle gave me this nifty little thing that looked like a big fishing weight but it had a screw down clamp in it. If you out that sucker on right below the strut that thing would stay there forever.
Old 07-15-2015, 02:21 PM   #22
light, strong, simple, never wears out and hits you in the head.
I like the prop-rod.
Old 07-15-2015, 03:08 PM   #23
Hood lifts
Mine are still resting in the trunk, but I will be getting to it pretty soon--as soon as I corner my son in-law.
reflections is offline   Reply With Quote
Old 07-15-2015, 03:14 PM   #24
bucko's Avatar
Don't have any first hand experience with a JLT oil separator, but the one I built from using a simple air compressor water separator worked. I tracked the car on weekends, and drove it daily to work. In a weeks time (250 miles a week), I'd have a couple of tablespoons of oil in the glass; enough for me to value the ten dollar water separator in keeping that oil from the intake/throttle plate.
As to a prop rod verses an aftermarket hydraulic unit, I can only guess it had to do with cost. While we may think a few dollars is not much, Ford see's it has thousands installed. We already complain with the cost of what we pay for a car these days, so they cheap out on accessories to keep their costs down. A little here, a little there, adds up.
Old 07-15-2015, 04:34 PM   #25
Smoked50's Avatar
So if the JLT doesn't work what does for a NA motor?
Old 07-15-2015, 04:55 PM   #26
UPR or Bob's catch cans. I've heard the PCV valve from the 3.5 ecoboost F150 from 13+ works well as a good replacement for the factory PCV, with less blow by.
Old 07-15-2015, 06:21 PM   #27
BLKBETTY13's Avatar
Breathers
BLKBETTY13 is offline   Reply With Quote
Old 07-16-2015, 03:09 AM   #28
bucko's Avatar
Make your own. Get a simple water trap that's used for air compressors, add two barbed fittings to it's inlet and outlet, then splice this to the existing line that runs from the intake tube to the engines faux valve cover.
Old 07-17-2015, 03:22 PM   #29
scurfie's Avatar
I know it's junk.
Then there are quite a few "I think I know cars" out there. Look I have the separator on my car, and collects oil as it should. And, my car is as real as yours.
Old 07-17-2015, 03:24 PM   #30
Doubt that last statement very highly
Old 07-17-2015, 04:09 PM   #31
Grabber Blue5.0's Avatar
The problem is it doesn't collect enough. Check your return line and you'll see what I mean.
Do the Redine struts requiring trimming of the battery box to fit on the 15's?
Old 07-17-2015, 04:31 PM   #32
Blue302's Avatar
Yes, the Redlines require drilling a hole through the plastic battery cover. I haven't installed yet but watched a video on CJ Pony Parts website
Old 07-17-2015, 04:48 PM   #33
scurfie's Avatar
The new UPR catch can is better than the JLT I bought. Even so I'm draining a couple of tablespoons of oil every couple of weeks.
Old 07-22-2015, 02:38 PM   #34
hctr154's Avatar
Originally Posted by BLKBETTY13 View Post
Breathers
Yes. ..just a quick wipe down every couple of weeks is all the upkeep required. Looks kinda cool in my opinion.
ID:	187781   Click image for larger version
2013 GT A6
hctr154 is offline   Reply With Quote
Old 07-25-2015, 12:16 PM   #35
randyGT's Avatar
A lot of track vehicles use to tie down the hoods. I think that's part of the reason no struts. Plus the mustang is like a Harley, they want to make a lot of parts so people can customize their ride... Just my initial thought
2015 Mustang GT premium
Magnetic grey 5.0
randyGT is offline   Reply With Quote
Anyone have the no-drill hydraulic prop rods for the hood? Guard 5.0 2015 Mustang GT 12 07-07-2015 06:25 AM
Poly, Rod, or Poly/Rod panhard bar? Mustang Coyote 2011-2014 Mustang GT 2 12-19-2014 11:03 AM
Hood Prop PonyBoy415 2011-2014 Mustang GT 12 10-10-2013 12:18 PM
2010 HD V-Rod Muscle :: 2010 Harley Davidson V-Rod Muscle Jetag93 Member Garages 0 08-12-2012 05:47 PM
Hood Prop OIF2007Mustang Mustang Audio & Video 8 09-14-2010 09:02 AM
10:11 PM
