Coil overs - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 08-02-2015, 11:14 AM   #1
Coil overs
Is there anyone out there with a coil over system on their 15? I blew a stock strut after 10,000 miles and I'm contemplating getting coil overs instead of having ford replace the strut. I'm looking at KW variant v1 and the bc coil over kit. I like the bc kit because it comes with caster/camber adjustment and compression /rebound adjustment and they're about $500 cheaper. However...I wouldn't really use the compression/rebound adjustment.
So here are my questions...
1.What c/c plates are compatible with the KW coil overs.
2. Is the bc set up hard to get dialed in with all the adjustments
3. What are your thoughts on the two choices
Mikeyt03 is offline   Reply With Quote
Old 08-02-2015, 03:48 PM   #2
I knew I should have started an exhaust thread instead : /
Old 08-02-2015, 04:13 PM   #3
Rapinator126's Avatar
Lol exhaust thread would have been 1,000 comments deep already.
Sorry have nothing for you on your question.
Rapinator126 is online now   Reply With Quote
Old 08-02-2015, 04:42 PM   #4
Lol I know. There would be 50 posts and 5 arguments and it would have been closed by a moderator 20 minutes ago. And someone would have asked about it voiding their warranty.
Old 08-02-2015, 06:09 PM   #5
The_Chech's Avatar
I have BC's on my 2011 and they're really easy to dial in. It's a bit rougher then stock but stock on the S197 feels like your floating it was horrible. All in all the BC's are very user friendly for sure.
2011 Kona Blue Gt Premium on coilovers and kooks full exhaust.
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 08-02-2015, 10:12 PM   #6
IG - The_Chech
How does the compression and rebound adjust? Similar to koni yellows?
Old 08-03-2015, 03:37 AM   #7
IG - The_Chech
Old 08-03-2015, 06:35 AM   #8
The_Chech's Avatar
They're really easy you turn it on the top with the dial that's on it already
Name:	ImageUploadedByMustang Evolution1438605296.836741.jpg
IG - The_Chech
Old 08-03-2015, 07:23 PM   #9
Attachment 188570
IG - The_Chech
Gotcha. Thanks! Did you corner balance your coilovers? Was it a pain to set the height ect...?
Old 08-05-2015, 06:02 PM   #10
You should get one with switches bro. Like hydraulics.That way you don't have to worry about changing the height manually. If you corner balance, make sure you do it with you sitting in the drivers seat. I learned this the hard way on my 05 neon. It really effect turn in if you don't. You should check out tein coil overs.
Johnyb03 is offline   Reply With Quote
Coil overs silver98mustang 1996-2004 Mustang GT 12 07-26-2011 09:26 AM
Changing plugs and coil overs 06' 3v GT buck199 2005-2010 Mustang GT 8 05-21-2011 09:38 PM
Lower Springs verse Coil Overs??? Sonic Blue Pre-2005 V6 Mustang 6 04-30-2006 11:03 AM
coil overs vs. lowering springs STEVE Pre-2005 V6 Mustang 6 06-13-2004 02:36 PM
!!!!Coil Overs!!!! !*!STANG!*! Pre-2005 V6 Mustang 12 10-13-2003 06:19 PM
04:20 PM
