Royal Purple Differential Oil Change - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 08-11-2015, 11:42 AM   #1
Smoked50's Avatar
Anyone using Royal Purple in their rear differential?
If so are you using the RP75x90 with Ford's 4oz bottle of friction modifier? How do you like it?
Smoked50 is offline   Reply With Quote
Old 10-29-2015, 07:04 AM   #2
Same question.
COYOTE6 is offline   Reply With Quote
Old 10-29-2015, 07:19 AM   #3
Kevin.Cook
Guest
Posts: n/a
I use RP but use the 75w140 in my 2011 and 2014 3.7. Along with the Friction modifier. I don't notice a difference over the fluid Ford puts in. No gear noise and still smooth. But it's nice knowing what exact fluid you have where and for how long it will last.
Old 10-30-2015, 07:58 AM   #4
So I'm considering switching out to the royal purple in the diff as well. It has the 3.55 lim slip. So I'm curious why are you using the 75w140 instead of 75w-90?
Thanks!!!
Old 10-30-2015, 08:01 AM   #5
Kevin.Cook
Guest
Posts: n/a
That is the recommended weight and such for the 3.7 as well as my area. Coyotes might be different.
I believe Ford revised the recommendations for 8.8s to use 75w140. Any synthetic of choice will be ok. I have yet to have any issues with my 2011 and 2014 3.7. Both run this fluid. The 2014 for about 5 months now.
Old 10-30-2015, 08:22 AM   #6
I think Kevin is confused. For the 11-14, the fill is 75w140. However this is in the 2015 section and 75w85 is the rear end fluid listed in the manual. I'm sure you'd have no trouble with the slightly thicker 75w90.
2013 SGM 3.7 | MPT Tune | JBA Shorty Headers | MGW Gen 1 | Blowfish Street Bracket | 18" Charcoal AMR | FRPP 3.55 | BMR LCA | Steeda Panhard Bar | Dynotech 3.5" Driveshaft |
mariusvt is offline   Reply With Quote
2012 v6 Racing stripe advice (Dark purple/royal purple) Riccardi93 2011-2014 V6 Mustang 6 08-14-2014 06:53 PM
Royal Purple & Dealer Oil Change? Fritzep 2011-2014 Mustang GT 29 04-22-2013 08:58 PM
aimsoil, royal purple , oil with a twist ebgonzalez1 2011-2014 V6 Mustang 12 11-16-2012 05:56 AM
royal purple oil? joey18 Pre-2005 V6 Mustang 24 07-30-2012 04:00 PM
11:41 PM
