2015 Cabin Air Filter Replacement plus Pictures - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 08-12-2015, 01:43 PM   #1
1- drop the glove compartment door
2- look for the flat tap with a screw in it around 9 o clock in pict #1
3- unscrew the silver screw, pull on the tab and the hinged door will open up and you will see the filter.
4- pull the filter out and replace it noting air direction arrow.
5- reverse the above procedure.Click image for larger version
Name:	ImageUploadedByMustang Evolution1439408591.973090.jpg
ID:	189231Click image for larger version
Name:	ImageUploadedByMustang Evolution1439408608.078838.jpg
retiredf5 is offline   Reply With Quote
Old 08-12-2015, 01:51 PM   #2
Here are the two pictures in larger size . . . Having some problem with the laptop.
PS the door to the air filter is easily remover to access the filter
Name:	ImageUploadedByMustang Evolution1439409073.574228.jpg
ID:	189233Click image for larger version
Name:	ImageUploadedByMustang Evolution1439409088.460101.jpg
Old 08-12-2015, 07:36 PM   #3
Do you have to remove the glove box? Is it inside the compartment for the owners book?
v8shep is offline   Reply With Quote
Old 08-13-2015, 07:49 AM   #4
No, you do not have to REMOVE the door . . . It unhooks from both sides and flops down but is still attached.
After the door flops down, looking FORWARD there is a piece of black felt that needs to be pulled aside or better still, I cut both sides so it could be raised out of the way. The drop down shelf for the manual is left in place as there is nothing above it.
Old 08-13-2015, 03:20 PM   #5
So in your pictures am I looking at the top, or left / right side?
Old 08-13-2015, 05:34 PM   #6
You are looking straight on thru the glove box opening. When you drop the glove box door it will become apparent how everything is oriented. Ive attached the picture or the door that is screwed closed in the first picture. In the previous pictures if you double tap them they should enlarge for better viewing.
Name:	ImageUploadedByMustang Evolution1439508865.317859.jpg
Old 08-20-2015, 12:12 PM   #7
hctr154's Avatar
I didn't think the 15s had been out long enough to clog up filters just yet...unless you drive up and down a dusty road every day.
Sent from my SM-T217S using Mustang Evolution mobile app
2013 GT A6
hctr154 is offline   Reply With Quote
Old 08-20-2015, 12:24 PM   #8
Normally you are correct. But when someone has bad allergy problems in the MidAtlantic area, changing the filter twice a year helps a lot.
Old 08-25-2015, 02:06 PM   #9
We drove a couple of hundred miles through a dust storm so bad, that visbility was down to a block or two.........the car and under the hood was a MESS. I have not looked at the cabin filter yet, but ordered one anyway.
FYI........these filters are $25 to $28 at the dealer, and they can be bought on line with free shipping for a little over $17.50.
Old 08-25-2015, 06:14 PM   #10
Where are they available at $17.50??
Old 08-25-2015, 06:59 PM   #11
I got mine on eBay from them, and it actually came to $17.89, so a little more than I mentioned, sorry:
Car Part Kings
Customer Support Team
(888) 501-6588
Old 08-28-2015, 03:45 PM   #12
Are you SURE these are the instructions for the 2015 convertible as well?
I've had the glove box door down three times, taken my iPad with your pics on it and set it on the passenger seat and looked from there to inside the car....and I still do NOT see the same things inside there that your pics show!
I can't see/find "that screw at 9 o'clock" anywhere.....
Old 08-28-2015, 06:21 PM   #13
Convertible..... It would have to be the same. Glove box not just opened but unlatched where the top of the glove comp is almost touching the floor. You need to be behind the glove box. You should see a fiber gray colored mat hanging down and behind that is what you are looking for.
Hope this helps
Old 08-28-2015, 06:36 PM   #14
Hope this helps
So, laying on the floor and looking up behind the door?
Old 09-01-2015, 09:28 AM   #15
Chameleon's Avatar
Great info!
2015 PUSH DECALS ---->
http://pushbutton.tictail.com
Chameleon is offline   Reply With Quote
Old 09-01-2015, 06:23 PM   #16
NO . . . U r making this too hard.
Once your drop the glove box, it does a 180degree so it it touching the floor, u look directly thru the front and u will see a fabric curtain which you pull aside and then you will see something similiar to the attached pictures
Old 11-25-2015, 08:07 PM   #17
Could you tell me what type of screwdriver you used? Thanks
dkramarz is offline   Reply With Quote
Old 11-27-2015, 10:37 PM   #18
NewMtang's Avatar
Before you purchase the paper filter to insert for $17.89, thing about purchasing the K&N Filter for $38.99 - 6% discount with FREE SHIPPING FROM AM. The can be cleaned by the kit you use on your CAI Filter. It should last at least 2 years, since it can be reused.
K&N Mustang Cabin Air Filter VF2020 (05-14 All) - Free Shipping
Old 11-28-2015, 08:23 AM   #19
Its been awhile but believe it was a small Phillips.
Old 01-20-2016, 04:22 PM   #20
Not trying to be a hater, but I found this writeup to be confusing and only minimally helpful when I did my filter today. As someone who writes instructions for a living, I will try to clarify a few points:
In order to just "drop" the door, you have to first release the tensioner arm along the right hand side by grabbing the knurled end of it and popping it up out of its slot. Push in gently on both sides of the glove compartment walls near the rubber-coated studs so that they clear their grooves and then let the glove compartment down.
The air filter compartment door goes front to back, and the screw you're looking for is right behind the flap in the felt divider at the rear of the glove compartment, which you don't need to remove or anything- just lift it up. BTW, it's a T20 Torx screw, not a Phillips.
You can reach the Torx screw from up underneath the glove compartment, not going in through the front. I found that resting my left elbow on the floorboard and reaching up with a torx screwdriver worked best, while holding the felt flap open with my right hand so I could see what I was doing. If you can, leave the air filter door on its hinge, because it's a PITA trying to fit its tabs back into the slots in the air filter housing after you put in the new filter. The door may fall off anyway, but it's not too big a deal.
You will pull the filter out from left to right and downwards. It will have to bend some. Just pull it all the way out and remove it from up underneath the compartment, not through the front. Do note the airflow direction, which is from top to bottom and should be indicated along the sidewall of the filter.
a. Put the door back on and screw the torx screw back in
b. Put the felt divider back into place, because you will inevitably have to pull and push it around some to access stuff during this procedure.
c. Lift the glove compartment door back up, push in on the sides to get it back into the grooves, and then reattach the tensioner arm. Make sure to snap it back down into place firmly.
J Doug
2003 Mach 1 - *sold*
2015 Mustang GT Premium
doug is offline   Reply With Quote
Old 01-20-2016, 06:46 PM   #21
Doug,
All help in between better
communication is welcome.
Old 01-20-2016, 09:56 PM   #22
Thank you sir. As an S550 noob, I couldn't tell what I was looking at to start with, so I figured other first-timers might benefit from some details that probably seem obvious to you more experienced guys.
J Doug
Cabin filter change. Good call. b2673ad 2011-2014 V6 Mustang 22 06-19-2015 12:31 PM
Ordering parts like cabin filter jomcgui 2011-2014 V6 Mustang 1 10-07-2014 09:29 AM
cabin air filter FullyAutomatic 1996-2004 Mustang GT 5 03-25-2014 06:58 PM
Cabin filter Blackedout Pre-2005 V6 Mustang 5 09-07-2011 05:36 PM
cabin air filter replacement jbobbie Pictures and Videos 1 11-19-2009 07:08 AM
03:54 AM
