Steeda IRS Support bushings Install (video) - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 08-18-2015, 11:05 AM   #1
Seatown Stang's Avatar
So, as I'm sure all of us have found out, the IRS is amazing for handling, but in a straight line it will wheel hop like crazy. So I took to the forums to see what can be done, on a relativity light budget, and help rid the car of wheels hop.
My results, of course, brought me over to our boys in blue at Steeda. I picked up their IRS Support bushings, differential bushings, and the subframe braces. Total cost of around $400...Not bad at all!
In this video I go through a detailed install of the IRS support Bushings. The install was surprisingly easy and very straight forward. Everything had great fitment and was very high quality. The hardest part was getting the 2 piece bushing into place, but that was trivialized with a little WD-40.
Total install took about 60mins with me taking my time, filming, and basic hand tools.
https://youtu.be/T2LoDU1lFUw
2015 Mustang GT Premium
Mods: Lund Tuned, AWE Switchpath Catback, AirRaid CAI, Eibach Pro-kit Springs, 3.55 gears, Ferrada FR2 20x9 and 20x10.5, APR Splitter, RTR front Grill, Steeda subframe braces, Steeda differential bushings, Steeda IRS bushing support, BMR Vertical Links, BMR Lower Control Arm Bearing kit (BK055), BMR Front subframe brace.
Seatown Stang is offline   Reply With Quote
Old 08-19-2015, 08:12 AM   #2
So, someone I've been talking to said nothing has remedied his wheel hop. I just bought one and am about to pick it up. How much difference did this kit make? I also noticed BMR has a kit. Thanks.
2015 GT PP ingot silver
Redlinez is offline   Reply With Quote
Old 08-19-2015, 09:41 AM   #3
tj@steeda's Avatar
The wheel hop is not a one cure all issue. Different owners have had success with different combinations of parts ... for example, here is SilverS550's case: Steeda’s 2015 Mustang test - “No wheelhop,”
Been on vacation the last week but I had a chance to hit the track last night. Wasn't planning on making any passes but it was dead and the cars that were making passes were hookin' really well so I decided to make a few. Unfortunately I didn't have the laptop with me to log the passes.
First pass I left soft. 2000 RPM and no 2-step. Car hooked and zero wheel spin or hop. Hooked well enough that it bogged a bit off the line.
Second pass. 3000 RPM on the 2-step, no launch control just RPM mode. Car dead hooked. No spin, no hop. Again, hooked well enough to bog the car a bit.
Third pass. 3200 on the 2-step, RPM mode. Again, hooked with no hop and just a bit of spin.....enough to just chirp the tires.
So, that's 6 passes with the Steeda bushing supports, sub frame braces and vertical links and the car is showing ZERO wheel hop. These last 3 were what I was really looking for as the car was hooking and showing no sign of hop at all.
2015 Mustang Suspension | Steeda Autosports | Free Shipping!
Let me know if I can help assist with a package!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Steeda Adding More S550 Parts Weekly - Steeda S550 Mustang Rear IRS Subframe Support tj@steeda 2015 Mustang GT 0 03-21-2015 08:52 AM
Wheel Hop Solution: Steeda S550 IRS Subframe Bushing Support System (GT, V6, Eco) tj@steeda 2015 Mustang GT 5 03-01-2015 03:07 PM
Steeda Radiator Support - Informative Video tj@steeda 2011-2014 Mustang GT 0 03-18-2014 11:53 AM
Steeda HD motor mount bushings 2013fiveO 2011-2014 Mustang GT 6 01-12-2014 12:33 PM
To IRS or Not to IRS Nel86 1996-2004 Mustang GT 11 06-03-2011 12:31 PM
07:49 PM
