Oil filter location - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 09-06-2015, 03:03 PM   #1
Oil filter location
Doing my first oil change on a Mustang today (have done hundreds over the years so this isn't a newbie question). Where is the oil filter on the 2015? Is it that filter under the little plastic flap that's held up by a little screw? That one looks like it's attached to the transmission oil cooler.....not what you'd typically see.
Maybe I need to have fewer beers before I start these things......and also get a Haynes manual.
dblhelx is offline   Reply With Quote
Old 09-06-2015, 05:00 PM   #2
I checked through the whole owner's manual, and there is NOTHING that shows where the oil filter resides............odd, I thought. Sorry I can't help you here.
Old 09-06-2015, 07:07 PM   #3
knight5.0's Avatar
Sounds like you have a performance pack car and yes that's where it's at.
Black 2011 Mustang GT Premium
Manual transmission, SS clutch line
Brembo brake package
Steeda CAI, Borla axle back & BBK X pipe
And Jon (Godfather tuner) Lund tune
knight5.0 is offline   Reply With Quote
Old 09-06-2015, 07:13 PM   #4
Nope. Not a performance pack. I've never seen an oil filter screwed into such a thing. Looks like a bare aluminum block and it has hoses coming off of it. Usually the filter screws right up to the engine block.....this is different to me .
Old 09-06-2015, 07:27 PM   #5
knight5.0's Avatar
That sounds like you're describing the external all cooler. The lines coming out of it would be coolant lines.
Old 09-06-2015, 07:51 PM   #6
DBLHELX..............sounds like you should be SURE before you tear into this project!
When you find the filter, let us know where it is?
Old 09-06-2015, 07:53 PM   #7
Of course. Not touching it until I find out. Kind of ridiculous this isn't so obvious. Nobody in here has changed oil yet and can shed some light?
Old 09-06-2015, 07:58 PM   #8
You got me curious, so I GOOGLED it, and there still was no information on where the filter is! It's got to be there somehere, right?
Old 09-06-2015, 08:02 PM   #9
I've Googled like crazy. This is nuts. I've changed oil sooooooooooooooooo many times. It was so dam hot today I just didn't feel like sweating under the car and taking off a dozen screws and tabs to remove the under panels. I was hoping it was right there or online with a pretty picture. This is embarrassing lol
Old 09-07-2015, 12:17 PM   #10
I'm sure you've figured it out by now, but you have to take the plastic cover off and it's up in front of the engine down low.
duhameister is offline   Reply With Quote
Old 09-07-2015, 02:34 PM   #11
Waylap1's Avatar
Region: New Hampshire
Well since it's the same Coyote 5.0 as our 11-14's it would be towards the very front of the motor, slightly drivers side. You need to remove the whole large plastic belly pan. Which is like a 2 minute job.
Waylap1 is offline   Reply With Quote
Old 09-08-2015, 06:12 AM   #12
scurfie's Avatar
I've changed my oil on my 2015. There is a small plastic flap attached by a small screw. Remove the screw and pull that flap down, and you will see the filter.
Good luck not getting oil on your arm or face too. Even with a rag the oil spills out.
scurfie is offline   Reply With Quote
Old 09-08-2015, 06:22 AM   #13
Finally someone who has changed a 15. Was yours a small white filter and attached to some bare aluminum thing.
As far as spills.....after I loosen the filter I placenta plastic bag around it and remove the filter. All the oil goes into the bag.
Old 09-08-2015, 07:51 AM   #14
scurfie's Avatar
I tried the bag but it still got caught since there's so little space, and the oil spilled out. It did get most but not all.
Old 09-08-2015, 07:52 AM   #15
scurfie's Avatar
Yes filter was white. You'll see it right away after getting the plastic flap down.
Best oil & oil filter xrsfx Pre-2005 V6 Mustang 5 05-18-2015 09:46 AM
Oil, Oil Additives, Oil Filters, FACTS robb15033 General Mustang Discussion 2 08-02-2012 11:37 AM
Fuel Filter Location 1989 Mustang Gt. joseandmarilyn 1979-1995 Mustang GT 2 07-15-2007 09:44 PM
cold air k&n filter PN/filter size tire Pre-2005 V6 Mustang 0 12-05-2003 05:37 PM
Location Location Location Ken The Bar 9 08-07-2003 08:51 AM
10:32 AM
