Dude, Same Rattle as 2014?! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 09-06-2015, 06:34 PM   #1
VTHokiez's Avatar
Wheel well rattling in the wind sounds exactly like the rattle in my 2014. Starts at 60 MPH and sounds like plastic on metal flapping in the wind. Took the 2014 to 5 dealerships and they were never able to locate the source of the noise. Does anyone else have this issue?
VTHokiez is offline   Reply With Quote
Old 09-06-2015, 09:29 PM   #2
Have someone pace you on the freeway and either have them video that corner of your car, or see if they can tell what is flapping around............just a thought.
Old 09-07-2015, 05:35 AM   #3
ponie1992's Avatar
I get this sound as well. To me, it almost sounds like it's in the door or fender area. I'd like to know what it is for sure!
Sent from my SM-G920V using Mustang Evolution mobile app
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 09-07-2015, 08:44 AM   #4
VTHokiez's Avatar
Sounds like we are in the same boat.
---------- Post added at 10:43 AM ---------- Previous post was at 10:43 AM ----------
Actually did that in the 14 and setup a GoPro... Nada
---------- Post added at 10:44 AM ---------- Previous post was at 10:43 AM ----------
Old 09-08-2015, 09:08 AM   #5
VTHokiez's Avatar
So I tightened down my driver's side runner and the sound went away at 60 MPH but still rears its head around 75. Next time I go in for service, I'll be sure to have them tighten it to spec. Just thought I'd pass this along.
Old 09-08-2015, 09:13 AM   #6
Strange Mud's Avatar
plastic fender liner maybe?
"every one of you was going 50"
Old 09-08-2015, 09:15 AM   #7
Kevin.Cook
Guest
Posts: n/a
Isn't there foam inside the fender area? Open your car door and try to look in the gap behind the front fender.
Old 09-08-2015, 01:23 PM   #8
VTHokiez's Avatar
There's foam, but it feels tight and secure.
---------- Post added at 03:23 PM ---------- Previous post was at 03:22 PM ----------
That's what it sounds like, but I think it's actually the runner moving in the wind
Old 08-03-2016, 11:08 AM   #9
CorneliusRox's Avatar
I think we have the exact same issue. What do you mean by 'runner'?
I'm at 65k and this just became an issue in the last 1000 miles or so. It drives me crazy and I can't track it down.
Corey | BSME
2012 Mustang - 3.7L - Loaded - Completely Stock!
CorneliusRox is offline   Reply With Quote
Old 08-03-2016, 11:10 AM   #10
I also saw this on another forum:
"Open the passenger door and look through the hinge side into the front fender. You should see a black material, which is a hard foam or fiberglass panel that seals the opening. It is a press fit and can become loose, then cause a rattle at speed.
If it's loose, remove the wheel, then the plastic wheel house for access. The press the panel back into place.
Also check the plastic wheel house itself. This is attached with one or two screws and a series of plastic push pins. If these are missing or loose the piece will rattle as well.
Plastic push pins are generally good for one use. Once you remove them, best to replace them."
I'm going to give it a try.
Corey | BSME
Old 08-15-2016, 01:44 PM   #11
I found the rattle. Now to find a fix...
The place where the a-pillar and the front fender meat is loose. I checked and all the fasteners are on tight, so I'm not sure what has changed...
I bought a paint pen, but I'm not going to paint it until I solve the issue, which I need to do before winter because I don't want any rust.
I also did some ABA testing to make sure I could turn the rattle on and off. It's definitely these two making contact.
[COLOR="Silver"]
Corey | BSME
Old 08-16-2016, 05:52 AM   #12
VTHokiez's Avatar
Well that's interesting, never even thought to think that could be the source. Good find - the rattling actually subsided for me on its own, but this is great to know. Good luck on a fix!
Airaid CAI rattle on 2014 14mayhem 2011-2014 V6 Mustang 18 08-03-2015 11:34 AM
Brand 2014 mustang gt accident! Will it ever be the same? Djourdan 2011-2014 Mustang GT 63 12-07-2013 10:14 PM
Dash Rattle?? Tranny Rattle?? ricklmesa Pre-2005 V6 Mustang 0 03-08-2006 07:19 PM
friends prank dude, dude ****s himself... *WW* Zim The Bar 14 10-27-2005 09:26 PM
Danger Dude Flex Pre-2005 V6 Mustang 4 07-20-2003 10:06 AM
10:04 AM
