Sync Update - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 10-04-2015, 09:11 AM   #1
VTHokiez's Avatar
Sync Update
Hey Guys/Gals,
I have a Sync update available this morning, and it's a large file. Just wanted to let others know. I'm installing now.
Adam
VTHokiez is offline   Reply With Quote
Old 10-04-2015, 09:54 AM   #2
Senior Member
rlma84's Avatar
I wish they did same for the 2013 and 2014 so buggy and no signs of updates fixing it some times just feel like just reaping it all out and putting and aftermarket unit c'mon ford step up and give us something that actually works on this radios so frustrating
rlma84 is offline   Reply With Quote
Old 10-04-2015, 09:58 AM   #3
scurfie's Avatar
Originally Posted by VTHokiez View Post
Hey Guys/Gals,
Adam
Please share the results. I pray they fixed the bugs.
scurfie is offline   Reply With Quote
Old 10-04-2015, 07:46 PM   #4
How do you know there is one available and how do you get it installed?
dblhelx is offline   Reply With Quote
Old 10-04-2015, 07:53 PM   #5
VTHokiez's Avatar
I haven't had an opportunity to mess with it too much today, so I can't tell you what the changes are other than what the change log says. To check for an update, log into your My Ford Touch account and follow the prompts.
Adam
Old 10-04-2015, 08:13 PM   #6
scurfie's Avatar
Thanks.
Old 10-25-2015, 03:54 PM   #7
EastTNMustang's Avatar
Any update, or is this bogus?
EastTNMustang is offline   Reply With Quote
Old 10-25-2015, 04:30 PM   #8
Junior Member
Sync Update
There was a sync update that added Siri eye and fixed some bugs. I never experienced any bugs but installed the update anyways. About a 500mb download need a 2gig thumb drive. Install is easy as starting your car and letting it idle 20mins while it installs
Go to owner.ford.com if you have it all setup it will show if you have an update there
Iceman2733 is offline   Reply With Quote
Old 10-26-2015, 04:25 AM   #9
You can also start driving the car after the install begins so you do not have to idle it for the extended period.
sloppymax is offline   Reply With Quote
Old 10-26-2015, 10:23 AM   #10
scurfie's Avatar
I got pulled over for speeding while installing the update, I forgot and shut off the engine, and everything installed just fine.
Old 10-26-2015, 05:58 PM   #11
WJBertrand's Avatar
What is Siri eye?
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 10-28-2015, 01:05 PM   #12
splain's Avatar
Siri Eye
I did the update just the other day and it added Siri Eyes Free...Which allows you to use siri from your iPhone to read and reply to text messages while driving. Works not too bad...And a whole lot better than Ford Sync ... By the way you just have to push and hold the speak button for 3 seconds to use it
splain is offline   Reply With Quote
Old 10-28-2015, 03:23 PM   #13
scurfie's Avatar
Wow! I didn't know that thanks!
Old 10-29-2015, 10:51 AM   #14
splain's Avatar
To use the new update with an iPhone
Just a reminder that you may have to restart your iPhone to make it work properly with sync. Right after I did the update I pressed the voice button and held it for 3 seconds and all I got was static. After resetting my iPhone it was all good
Old 11-11-2015, 01:42 AM   #15
Tried to do a system check. Said has to have 200 on odometer. I have 2400. Tried to update sync. Failed. Ugh.
COYOTE6 is offline   Reply With Quote
Old 11-11-2015, 02:26 PM   #16
WJBertrand's Avatar
Where do you get the update with Siri eye? I have no updates on my Ford Sync page. Or may it's not for the 2013?
-Jeff-
Ventura, CA
Old 11-12-2015, 10:23 AM   #17
splain's Avatar
The new version is 3.8 I think and it should say if you are up to date on the Sync page. Make sure you are registered on Ford Sync. You can also follow directions on there that show how to check which version you have installed.
Old 11-12-2015, 10:30 AM   #18
splain's Avatar
Coyote6.. make sure you have registered your car and cell phone number with sync in order to do a vehicle health check. Also make sure nothing is plugged into your ODB port. They also have live chat on there which was a help to me. I got the same " must have 200 miles deal but had 3500 on mine". As far as the update goes make sure you open the folder on your desktop first and drag the items to your USB stick...hope this helps
Old 11-12-2015, 10:57 AM   #19
Thanks very much!
Old 11-13-2015, 10:57 AM   #20
WJBertrand's Avatar
Interesting. My version of sync is 4.4. Maybe I have the Siri eye functionality already?
-Jeff-
Ventura, CA
Ford Sync Update: About time... dseg 2011-2014 Mustang GT 19 06-30-2015 09:39 PM
SYNC Update au01st 2011-2014 V6 Mustang 102 05-06-2015 05:16 PM
Sync update made stereo not remember input jayochs 2011-2014 V6 Mustang 10 04-14-2015 03:48 PM
Sync update Ratraget 2011-2014 Mustang GT 3 08-06-2013 11:19 AM
Update to the update!!!!! Zebs5408 Pre-2005 V6 Mustang 19 01-29-2010 09:55 PM
10:00 PM
