Lowering my car - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 10-16-2015, 01:55 PM   #1
Lowering my car
Im planning on lowering my 16 gt. Any suggestions? I was thinking on just getting some lowering springs. Or will that mess up the stock shocks and struts?
Sent from my SM-N910P using Mustang Evolution mobile app
5inco is offline   Reply With Quote
Old 10-17-2015, 04:35 PM   #2
That depends on how low you go. An inch or inch and 1/2 on both front and rear, lowering springs alone will likely suffice.
DO get it aligned right away though.
Old 10-18-2015, 09:02 AM   #3
Lowering my car
I just added Steeda sport progressive. 2015 GT non performance pkg. no damper upgrade / no strut plate (?) upgrades. (Someday maybe but I'm very happy now.)
These lower the car 1.125 in front and 1 in rear They are two stage and offer comfortable ride (stock like but better handling) in normal situations and the second stage comes into play during cornering and during fast launches and stops. The car now has barely any nose dive or squat during acceleration or hard braking. This is directly related to springs I'm sure.
Did a few other things so Im experiencing additional improvements at least partially attributable to other components. I'll post in a bit.
I did a lot of research on these springs, and I'm very happy with Steeda. I ordered directly from Steeda (great) but CJ Pony is great too and carries them. They also (CJ Pony) has a YouTube video of installation. I can recommend these springs without any reservation.
COYOTE6 is offline   Reply With Quote
Old 10-18-2015, 08:27 PM   #4
tj@steeda's Avatar
We appreciate your support & either way you go ... CJ/Steeda will help you through your ordering process!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
Win A $300 Gift Card
tj@steeda is offline   Reply With Quote
Old 10-18-2015, 08:36 PM   #5
Best Regards,
TJ
Thanks for all the help TJ. My ride is STEEDA! all the way. Much appreciation.
Old 11-27-2015, 08:30 PM   #6
Well I've added BMR sway bar end links and had to get new dampers went w FOMOCO M-18000-F. glad to be Steeda as much as I could at this point.
Old 11-27-2015, 09:20 PM   #7
tj@steeda's Avatar
Well have plenty more down the pipeline!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 11-28-2015, 02:03 AM   #8
Philly2304's Avatar
I am new to the site. I have been out of the car game for about 10 years and finally got a mustang again. I have a 2015 gt w/PP. I love the Steeda stuff. I want to buy lowering springs but I want to hide some of that open wheel well with 19 in rims. Do the Steeda springs lower it enough or do I need to get something else? It is a daily driver so I still want it to be drive able on normal roads. I just want the look with a little better performance. If anyone has some pics with Steeda springs and the stock PP wheels that would be awesome. Thanks.
Philly2304 is offline   Reply With Quote
Old 11-28-2015, 10:35 PM   #9
tj@steeda's Avatar
Steeda Linear Springs:
Steeda Progressive Springs:
Shoot me a note to tim@steeda.com and I can help put you in the spring that will best suit your needs.
You can check out our full line of suspension parts here:
http://www.steeda.com/2015-suspension/
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 11-29-2015, 12:40 AM   #10
Philly2304's Avatar
Thanks TJ I will be in touch soon. I will definitely drop you a note after the holidays. Thanks for the help.
Old 11-30-2015, 04:41 PM   #11
Junior Member
Best Regards,
TJ
Hey TJ,
Is there a different specification for the UK GT? Mine is on order and want to get the ride dropped slightly to close the arch gap, but keep the stock dampers. I don't want the pogo stick effect so nothing major, probably something like 15-20mm. What can you recommend?
Here's one of the first UK GTs I saw yesterday at my local dealer - looks great but rides too high. Thanks in advance!
naughts4187 is offline   Reply With Quote
Old 12-02-2015, 08:17 PM   #12
I wrote about the pogo'ing effect. This is on the Yolo Causeway. It's bouncy as it is, for any car. It's just amplified a bit now.
I'm glad I dropped an inch. 20 mm would not do much. I could stick w as is under normal conditions, but I want a smooth, firm, high perf ride at speed, so I'm going to upgrade the dampers now cause I just want to get it right and done.
I recommend doing it all at once (springs/dampers/jounce bumpers/ caster/camber plates). Unless you really like wrenching. I'll have do do another alignment as well as redo just about everything. Hopefully no new issues.
The Causeway will still cause some bounce -on any car- but expect much less w new dampers.
Old 12-02-2015, 09:27 PM   #13
tj@steeda's Avatar
Hello Naughts,
We don't think there will be an issue but we have not been able to confirm.
Send me your contact info & we will talk about your options - you can email me at tim@steeda.com.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
put lowering springs on my car and raised it? electricstang Pre-2005 V6 Mustang 23 07-14-2006 05:18 PM
lowering the car OXstang11 Pre-2005 V6 Mustang 29 10-29-2005 09:43 PM
Lowering my car eddied Pre-2005 V6 Mustang 6 11-26-2004 12:58 PM
Lowering car question leo95 1979-1995 Mustang GT 9 11-11-2004 04:00 AM
Lowering my car? white99 Pre-2005 V6 Mustang 7 03-16-2004 11:20 AM
08:51 AM
