The new Car and Driver has THE test on its cover -- GT vs SS. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 10-31-2015, 05:46 PM   #1
Well, of course the new Car and Driver has THE test on its cover.................Camaro 207 points, Mustang 205. Mustang 11 category wins, Camaro 12......................BUT the Camaro has an automatic trans, and the Mustang the manual. So, in all of the acceleration tests, the Camaro got to downshift significantly, while the Mustang is locked in 6th. This skewed the results a LOT when it comes to "acceleration in top gear!" as well as, perhaps the mpg ratings win for the SS...............
I call foul!
Old 11-11-2015, 03:02 PM   #2
Road Dog's Avatar
I thought the article leaned too far in its attempt to paint the New Camaro as superior when at the same time the honest numbers showed very little performance difference. But then as test results they reported the top gear 30-50 time as 9.1 sec and 50-70 time as 8.6 sec for the manual transmission Mustang while the 8spd Auto Camaro ran 2.3 sec and 2.7 sec.
Mind you the gear ratio in top gear for both cars is .65 and the Camaro rear is 2.77 vs the 3.73 Mustang.
2016 GT Vert, SB, AT, 3:55s Weathertech, JLT, Steeda, Colgan, Velossa Tech, Coyote Spacers, Diode Dynamics, Shelby GT350 SW, Curt, Goodridge, aFe, MRT, BMR, Kooks, Mishimoto
Road Dog is offline   Reply With Quote
Old 11-11-2015, 03:16 PM   #3
natestang07's Avatar
Car and driver is always a bit gm biased, aren't they?
Old 11-11-2015, 03:23 PM   #4
I know how quickly and easily, with only a gear or two kickdown, our A6 Mustang accelerates from 50 to 90. The test results should have made more of the A6/Manual handicap for the Mustang.
I too thought that the Mustang did itself proud overall.
Old 11-11-2015, 03:25 PM   #5
dave73's Avatar
Those test results don't make sense to me not that I really care anyway. 30-50 in 9 seconds???If it goes 0-60 in 4.4 seconds how could it take 9 seconds to go 30-50
dave73 is offline   Reply With Quote
Old 11-11-2015, 03:29 PM   #6
dave73's Avatar
Double post
Old 11-11-2015, 03:40 PM   #7
I believe that is locked into its highest gear
Old 11-11-2015, 04:38 PM   #8
dave73's Avatar
Ok that would explain it but seems like a stupid test me. If I'm evaluating a car I'm going to optimize the cars functions (choose the right gear) to get the best time with whatever vehicle I'm driving.
Old 11-11-2015, 04:51 PM   #9
Rapinator126's Avatar
Stop winning GM is on top yet again. I have said it b4 all you "Bolton" coyotes are about to get your a$$ drug by GM again.
Going to need some real tunes for your coyotes now.
🍼and 🌽 fed coyote.
Old 11-11-2015, 04:56 PM   #10
Just praying they fix their visibility issue by 2020
Old 11-11-2015, 04:56 PM   #11
dave73's Avatar
🍼and 🌽 fed coyote.
I could care less I was just wondering what kind of test that was. My car is plenty fast I have enough. What's stock numbers anyway mean? Make a few changes spend a few bucks you change them. Either platform will work
Old 11-11-2015, 05:13 PM   #12
Flooring a manual transmission in 6th gear at 50 mph -- vs -- flooring an automatic 6 speed and then timing both to any speed is going to massively favor the automatic and its ability to kick down two or three gears.
It was kind of rediculous for them to test these two cars against each other for those speed tests, as well as the mpg test, which the Mustang might have won with the A6 in it.
Put the manual GT in 2nd or 3rd gear, and lets see how fast it gets from 50 to 70!
Old 11-11-2015, 05:16 PM   #13
dave73's Avatar
Well yes that seems to be what they have done and that's stupid. You would have to lock the automatic in 6th to have comparable results!
Old 11-11-2015, 05:31 PM   #14
Ish416's Avatar
I haven't seen the article but on the Mustang side, isn't the manual Mustang faster than the auto, stock for stock? It was in the S197.
Old 11-11-2015, 06:26 PM   #15
Looking at the specs of the new Camaro. I don't doubt it will be faster than the Mustang. Weighs like 150lbs less. And puts down around 410/420 bone stock.
Old 11-11-2015, 07:09 PM   #16
Road Dog's Avatar
Soccer
Correction, the car they had was only 57 lbs lighter. Plus they spec it at 455hp only 20 Hp advantage. Where the Camaro has the real advantage is in the use of the magnetorheological shocks that provides instant suspension tuning while in motion.
Old 11-11-2015, 07:12 PM   #17
dave73's Avatar
Magnahecktawhat shocks? Is that really what they call them?
Old 11-11-2015, 07:35 PM   #18
Ish416's Avatar
Originally Posted by Road Dog View Post
Soccer
Torque ... you forgot that.
The 2016 Camaro makes more torque at the wheels, at just 1750 RPM (360 wtq) ... than the 2015+ Coyote makes at any RPM (358 peak).
Again .. this is stock for stock.
Old 11-11-2015, 07:38 PM   #19
dave73's Avatar
It's also a 6.2 liter Motor vs 5.0...
Old 11-11-2015, 08:01 PM   #20
Ish416's Avatar
You are looking at 3 wtq per liter difference between the two cars. That is nothing.
The fact that the new GM LT1 makes more torque at just 1750 RPM and carries it (and more) from there to 6500 RPM is an absolutely impressive powerband.
If you want to go the per liter route, the mighty Mustang 5.0 makes less torque per liter than a 2.4L Honda Accord (174 wtq) ... at the tires.
See how silly your argument is?
Old 11-11-2015, 08:40 PM   #21
dave73's Avatar
Did I argue? all I'm saying is GM has always had to put more cubes for similar results. I could give 2 craps less on the torque rating of a Honda Accord I'm still not driving one. So if you guys want put Camaro's or Hondas on a pedestal have at it! Go buy one buy em both. Me and my Mustang have a deeper relationship than that I'm sticking with it.
Old 11-11-2015, 09:51 PM   #22
JOberlander's Avatar
Manual vs automatic. Stoppped reading right there.
JOberlander is offline   Reply With Quote
Old 11-12-2015, 05:31 AM   #23
Road Dog's Avatar
I had not bought that magazine for the past 30 years. After reading that article I remembered why.
Old 11-12-2015, 05:42 AM   #24
Strange Mud's Avatar
C&D is mostly about performance and the new Camaro is somewhat better. I'd be happy to own either, but, w/o having driven the new models I believe the Mustang would get my vote again as at 6'3"+ I'm sure the Camaro wouldn't work for me.
I've said it before "it's another Golden Age of automobiles"
Old 11-13-2015, 10:55 AM   #25
VTECLol's Avatar
Ok the new camaro is faster. So what. Is it really that impressive when gm had to use the corvette motor and Cadillac chassis to beat the mustang? Outstanding work Chevy.
2015 Race Red GT 6MT
VTECLol is offline   Reply With Quote
Old 11-13-2015, 11:12 AM   #26
Ish416's Avatar
A better engine and a better chassis generally makes a better car.
The chassis was designed from the beginning to be used for the 6th gen Camaro along with the shorter wheelbase ATS. Ford does this also.
The LT1 engine is just a performance version of their truck engines, same basic thing that Ford does.
Old 11-13-2015, 04:01 PM   #27
dave73's Avatar
None of those stock test results mean ****. You can make any platform you like fast just spend money. They have a Pinto down at the track that runs 9's does that mean the Pinto is the better car? I would rather have the 5.0 over the 6.2 and it has all the potential I'll ever need.
Old 11-13-2015, 04:20 PM   #28
I like when people get all but hurt defending the mustang. It's funny
🍼and 🌽 fed coyote.
Old 11-13-2015, 04:34 PM   #29
NewMtang's Avatar
No Christmas Cards for You...
🍼and 🌽 fed coyote.
________________
Keep it up Rap, the Mustang Whiners will take your name off of their Christmas Card List.
Old 11-13-2015, 04:46 PM   #30
dave73's Avatar
I used to be a big fan of GM and I would never buy another one the newer stuff is junk. They are not reliable my 09 Silverado was crap. I had tons of problems with it. I had a 99 Firebird it had electrical problems I had a 2002 Camaro it caught on fire because of an electrical issue. My Silverado had to be towed at least 4 times for various issues. What sold me on Ford was the company vehicles I drove were Fords and were dependable as hell. I like the older GM stuff that's it. Even when I raced and I owned the Camaro it seemed like the Fords would take more punishment and responded to mods better. If you want a Camaro or Corvette buy one your not going to hurt my feelings.
Old 11-13-2015, 05:00 PM   #31
Soccer
Depends on manual or automatic and base or fully loaded for the weight.
As for the power, the number i said was the test to the wheels. It looks like Chevy under-rated the engine as it puts down more than it should to the wheels, i didn't pull that number out of thin air.
Old 11-13-2015, 05:00 PM   #32
All my GMs were/are very dependable. I guess some have luck with them and some don't.
Pick your poison.
Recon is online now   Reply With Quote
Old 11-13-2015, 05:14 PM   #33
dave73's Avatar
Pick your poison.
I used to have luck with them but the bad taste left in my mouth from that 09 truck was pretty bad. It was officially the WORST vehicle I have ever owned. I had better luck with 1000 dollar clunkers off the side of the road than that $45,000 new truck.
Old 11-13-2015, 05:17 PM   #34
Hm, that's unfortunate.
Pick your poison.
Old 11-13-2015, 05:24 PM   #35
dave73's Avatar
It had 88,000 miles on it when I got rid of it and the rear end, transmission, 2 alternators, 3 batteries, water pump, 2 throttle bodies, and it had a tick that sounded like a collapsed lifter. It burned a quart of oil about every 10 days which they said was normal for that engine. About once a week the check engine and stabilitrac light would come on and it would go in limp mode and if have to pull over and reset it and nobody could figure that out. I was glad to get rid of that
Bolt on test 5.0 Mustangs & FF Mag test Oct 2012 thoughts & questions Spiney General Mustang Discussion 0 09-04-2012 11:23 PM
Its all about the driver Texasstang General Mustang Discussion 3 04-30-2012 03:29 PM
Will i be able to trade my 2011 mustang in after it has been in a wreck and now has a car fax? Sior General Mustang Discussion 5 07-19-2011 06:40 AM
Is a1986 Ford Mustang LX a good car? its my first real car and im worried. its had 2 owners.? annawan 1979-1995 Mustang GT 5 03-25-2010 06:53 AM
WTB: driver's side valve cover, 01+ tire Mustang Parts for Sale and Wanted 0 02-16-2004 09:00 AM
02:20 PM
