Backspacing and offset - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 11-21-2015, 05:17 AM   #1
99_GRUMPY_GT's Avatar
I am upgrading right now as we speak as my 2015 GT PERFORMANCE PACKAGE is in the body shop for a few things I wanted done. I want to purchase this week a staggered set of Niche Millan M134's. I'm going with 20x10.5 w/315/35/20 in the back and 19x9.5 w/275/40/19 up front. Can someone tell me the correct backspacing and offset for the front set? Is the offset 35mm or 45mm? Or what? Thanks in advance.
Sent from my LG-H811 using Mustang Evolution mobile app
2015 Race Red Performance Package GT 5.0 (435hp) stock
Still in the making Updates coming soon!
99_GRUMPY_GT is offline   Reply With Quote
Old 11-23-2015, 07:57 PM   #2
Road Dog's Avatar
35mm is all Niche Makes in M134 for 4.5" bolt pattern
Niche makes the 19X9.5 M134 for the Mustang fitment in one offset, 35mm. The 35mm should move the rim edge 16.35mm closer to the fender line than your stock wheel. The stock PP wheel is 9" and 45mm offset. As I do the math this puts the outer rim edge .643" farther out. But I would check with the wheel dealer its likely they have sold hundreds of 9.5s to Mustang owners and they may even have some pics.
As an example I am dealing with Get Your Wheels and that are selling 19X10 square fitments with 275/40zr19. They sent me lots of pics of S550s with that setup. But these are Forgestar wheels. Regardless your dealer should be able to show what the Niche wheel would look like on your car. In any case I looked at the Niche website to find the measurement and thats where I see they only have one listing in the Mustang fitment for the 19x9.5 M134.
Road Dog is offline   Reply With Quote
Old 11-24-2015, 04:30 AM   #3
I live in Puerto Rico now and when I mention offset and back spacing they look at me like I'm a regard. Here aftermarket is with the ricers not American muscle. So resources are limited. Sure I can buy in line, but shipping is ridiculous and for these wheels it's almost 800.00. That's the price of 2 rims. Ugggh
Old 11-24-2015, 01:37 PM   #4
Road Dog's Avatar
Unhappy Whoa there!
Did you mean to say the shipping for 4 wheels to Puerto Rico is like $800???
Old 11-24-2015, 04:50 PM   #5
Road Dog's Avatar
Really decent car you have
I forgot to tell you you have a real looker there in the picture.
Mine won't look that good ever.
Old 11-24-2015, 08:25 PM   #6
Diehard's Avatar
Road Dog appears to be right on the money except I see the 20" have a 40mm offset.
Why you're going with 20" rears and 19" fronts I can only guess you want to use your existing rear tires for the front on you new set-up. (?)
As you probably already know, your rear tires will have a larger diameter than stock and would result in a -3.56% speed error and must be corrected.
Looks like the front tires will end up being about 5/8" bigger in diameter resulting in a relatively small speed error to your ABS brake system (-2.28%) Probably not enough to worry about. (?)
The following site will allow you to compare existing wheels and tires to new wheels and tires.
Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
Did you check out Amazon.com for these wheels?
Old 11-26-2015, 03:39 AM   #7
Yes
Old 11-26-2015, 03:57 AM   #8
No I like the setup of different size rims front and rear as I had on my 99 GT. The tires and rims are going to be new. No using the crappy Pirelli Zero's. I bought Continental Contisportcontact VMAX tires already. Rears are 315/35/20 and fronts are 275/40/19. The max on offset for the rear 20x10.5 is 30mm and the front 19x9.5 is 35mm. So I am guessing by your all's input that it is going to push the set up outward. The correct offset for this set up is rear 59mm and front is 45mm. Also there is a hub bore difference too. My car has a 70.6 hub bore, the vote on the rims is 72.6, a difference of 2mm. That's not a lot of difference so I don't know if I should make my own 2nd rings or just leave it alone being it only is 2mm.
Backspacing Thomas11CS5.0 Mustang Wheels & Tires 1 02-20-2013 03:22 AM
Drag radials and backspacing tea84 2011-2014 Mustang GT 9 09-27-2012 11:17 AM
Measure Backspacing question? runvsofthisbull Pre-2005 V6 Mustang 3 07-23-2010 04:15 PM
What is the backspacing on the '00 17x8s? MustangMatt Mustang Wheels & Tires 2 09-11-2005 10:10 AM
Backspacing question Black00GT The Bar 0 07-29-2004 12:49 PM
05:27 PM
