Steeda's S550 Tri-Ax Race Short Throw Shifter is Here! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 12-10-2015, 08:10 PM   #1
tj@steeda's Avatar
Thought we just focused on suspension? Drivetrain is our forte as well!
Steeda's S550 MT-82 Tri-Ax Race Short Throw Shifter is a full factory shifter assembly replacement for your 2015-2016 Mustang GT or EcoBoost. Our race short throw shifter eliminates all slop and deflection of the factory shifter, and still retains the factory shift knob, pull-up style reverse lockout and backup camera functionality.
Product Benefits
- 30% throw reduction
- 20% lighter than the competition
- Eliminates slop and shifter deflection
- Shift knob sits 1" lower for ideal 'power shifting' position
- Top-loaded installation with adjustable springs, in-car assembly
- Retains factory pull-up reverse lockout, OE thread pitch, and back-up camera functionality
- Includes Steeda's shifter base bushing bracket
- Precision-fit bushings for a direct positive feeling shift
- Steeda blue anodized finish
- Lifetime Steeda warranty
- Made in the USA
Steeda S550 Tri-Ax Race Short Throw Shifter - GT | 555-3717
Steeda S550 Tri-Ax Race Short Throw Shifter - EcoBoost | 555-3718
With the replacement of your factory shifter assembly with our short throw shifter, you will notice a 30% reduction in throw between gears. Our shifter assembly will also lower the shift knob by 1", putting it in a better 'power' shifting position. Our Steeda S550 Mustang Tri-Ax Race Short Throw Shifter is quieter than the stock shifter during daily driving, although during race applications you may notice a slight NVH increase.
One of the great benefits to this shifter assembly is that it's completely top-loaded. Our short throw shifter for your 2015-2016 Mustang GT or EcoBoost comes with 2 different spring set options for a fully adjustable shifting experience. The kit comes complete with 2 medium-resistance springs and 2 high-resistance springs. The Steeda Tri-Ax has adjustable return springs to fit every drivers' preference on shifter feel. Using an offset spring tension ensures that you hit your 2nd-3rd gear change every time. Since our S550 MT-82 short shifter is top-loaded, once the base plate is mounted, you can change all of your springs, levers and other options all from inside the car without taking out the full shifter assembly!
Our Tri-Ax shifter features rigid mounting in the front and Steeda poly bushing in the rear, virtually eliminating slop and shifter deflection. With less deflection you will feel a much more direct gear change. The assembly is transmission and chassis-mounted so you don't get the 'walking' affect of a fully transmission-mounted assembly, all while still gaining a more rigid shifter feel. Factory shift shaft bushings are replaced with wider, high-quality machine-finished, low-friction bushings. Tolerances are controlled up to a half thousandth of an inch to ensure OE-quality fitment, alignment and shaft actuation. These features alone make our Steeda Tri-Ax one of the most positive feeling shifters on the market today. To top it all off, our Steeda Mustang GT shifter assembly includes Dynamat sound-deadening material to close out your transmission tunnel and ensures your S550 stays as quiet as the stock assembly.
Steeda's S550 Mustang MT-82 Tri-Ax Race Short Throw Shifter is manufactured from high-quality aircraft-grade aluminum making it 20% lighter than the competitions' shifter assemblies. The shift lever itself on our Tri-Ax is made from heat-treated and nickel-plated 4140 steel, making it the strongest part out on the market. All hardware is stainless steel for the highest corrosion-resistance possible. Included in our kit is hardware to tighten up the factory shift knob perfectly into a locking position. These parts have been put to the test on the street and the track and are proven not to bind under extreme conditions or temperatures.
Priced competitively at $439.95 and backed by a lifetime warranty, pick-up one of our Tri-Ax shifters today and shift with confidence!
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Steeda Adding More S550 Parts Weekly - Steeda S550 Mustang Rear IRS Subframe Support tj@steeda 2015 Mustang GT 0 03-21-2015 08:52 AM
Steeda Tri-Ax Short Throw Shifter Kit Coyote2820 2011-2014 Mustang GT 5 02-27-2015 06:16 PM
MGW or Steeda short throw shifter? Gobabygo67 1996-2004 Mustang GT 4 12-02-2011 02:14 PM
Steeda Tri ax short shifter install..... rinfield2004 SVT Mustang 10 09-02-2011 12:40 AM
Steeda Tri-Ax Short Throw Shifter for T-3550 USMCSS Mustang Parts for Sale and Wanted 4 04-23-2007 08:09 AM
01:09 PM
