Air/Fuel Ration when coasting. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 12-19-2015, 04:02 PM   #1
cboyd's Avatar
So I accidentally hit the rev limiter for probably a good 2 or 3 seconds today, and of course I'm now paranoid that a hurt something. So I switched over to my gauge mode and noticed the air fuel fluctuating around 13-14 but when I let off the throttle and coast it jumps up to 20. It may have alway done that but I never payed any attention so I was just wandering what others experience.
Thanks
cboyd is offline   Reply With Quote
Old 12-19-2015, 04:37 PM   #2
ponie1992's Avatar
I think I noticed that on mine as well.
Jeremy
2016 Ruby Red PP GT
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 12-19-2015, 05:18 PM   #3
Same here, goes to 20 when coasting, fluctuates throughout the RPM range.
la pantera is offline   Reply With Quote
Old 12-19-2015, 05:19 PM   #4
That's the point of the rev limiter. Your fine.
Mcturd81 is offline   Reply With Quote
Old 12-19-2015, 06:27 PM   #5
cboyd's Avatar
That's what I like to hear!
Old 12-19-2015, 06:28 PM   #6
Old 12-19-2015, 09:32 PM   #7
Region: New Mexico
The deceleration function basically stops the gas flow. ..
yes 20 is right, it's part of the program.
Sent from my SM-G900P using Mustang Evolution mobile app
slimguns is offline   Reply With Quote
Old 12-19-2015, 10:11 PM   #8
Trevorhart3's Avatar
I went and drove my car to check. Anywhere from 2.5-15 with the pedal down depending on how far down it is, 20 when coasting.
Trevorhart3 is offline   Reply With Quote
Old 12-20-2015, 08:49 AM   #9
JimC's Avatar
Coasting the engine is just an air pump so 20 is normal. Steady cruising 14 high 13 is also normal.
Wide open throttle is where you want to be in the lower 12's -11's. WOT is where you are worried about running lean.
JimC is offline   Reply With Quote
Old 12-20-2015, 10:11 PM   #10
cboyd's Avatar
Cool. Thank you all
need help with custom fuel rails, fittings, fuel pressure gauge tire Pre-2005 V6 Mustang 2 07-13-2015 03:32 PM
mustang v6 2012 air condition after use the hot air do not blow cold air blackout2012 2011-2014 V6 Mustang 5 12-14-2014 07:17 AM
Coasting in Netrual tgmeyer General Mustang Discussion 5 10-06-2012 04:27 PM
High speed coasting issue BaSohol 2005-2010 Mustang GT 6 10-01-2012 01:58 PM
19LB Fuel Injectors; 190-255LPH Walbro Fuel Pump Brent Mustang Parts for Sale and Wanted 5 05-11-2005 11:04 PM
09:37 AM
