Steeda spring question - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 12-30-2015, 09:39 AM   #1
Philly2304's Avatar
Can some tell me what the difference between the Steeda linear and progressive springs? I know there is a little difference in the drop bit is there anything else? My car is a daily driver anyone recommend one over the other? TJ?
Philly2304 is offline   Reply With Quote
Old 12-30-2015, 10:56 AM   #2
tj@steeda's Avatar
Hello Philly,
In short - Steeda’s progressive lowering springs for the S550 use a dual-rate spring with two linear rates connected by a rate transition range. The springs are more predictable and easier to tune.
Our progressive springs were designed and tuned for a setup consisting of one to two people at 200 lbs each with a full tank of gas in the car. From our experience, a linear spring doesn’t provide as much roll control as a progressive spring. Think of our progressives as a high-tech dual-rate spring.
Spring rates - our progressive springs are 10% stiffer than the PP springs at curb and provide a 40% increase in roll stiffness over the PP springs when you lean into it and the spring compresses.
Let me know if I can help with a set ... you can read our reviews here:
Steeda Mustang Sport Springs - Progressive (2015-2016 GT/V6 Coupe) 555-8210 | Free Shipping!
Steeda Progressive Spring review
So Steeda recently installed a set of Progressive springs on my GT PP and I am impressed, the new ride profile is just awesome. The lack of wheel gap makes things look much cleaner and more aggressive. the ride is a huge change and I must say it did take some getting used to. It changes from the bouncy bunny hop to a choppy affect sort of like there are chains holding the car from bouncing too high. The vehicles vertical travel has been reduced by about 40-50% which has made cornering much better. Once I got used to the new ride feel I became more confident in the cars ability to "hug" the road. Over all this was a great add to an already great car. If you are looking for a single upgrade that makes a huge change this is definitely the way to go!
Best Regards,
TJ[COLOR="Silver"]
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 12-30-2015, 11:57 AM   #3
Philly2304's Avatar
TJ, is there one of the two you would recommend more for daily driving or does it not matter?
Old 12-30-2015, 01:14 PM   #4
tj@steeda's Avatar
I would recommend the progressive springs for daily driving - ride quality is as comfortable as stock & they provide sharper steering response, improved vehicle handling/stability, and noticeable reduction in nosedive.
I will p.m. you a forum code for your purchase!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 12-30-2015, 01:37 PM   #5
Rosco3's Avatar
How does one acquire the Steeda forum code?
Ingot Silver Metallic 2013 Mustang 5.0 Premium, Flowmaster Outlaw Exhaust, Airaid CAI, JLT Oil Separator, MMD Black Zeven Wheels
Rosco3 is offline   Reply With Quote
Old 01-23-2016, 04:03 PM   #6
TGC
I was speaking to a rep from Steeda regarding the Progressive Lowering springs affecting rear camber and was told that even though they now sell adjustable camber plates, aside from one instance, all purchasers have been able to get their wheels back into spec with no camber plates needed. That being said, since I will not be bringing my car to a track to necessitate any adjustments, I just want to avoid having to put them on after the fact due to problems with alignment. Anyone experience any problems with camber or does the car seem to fall back into spec with an allignment from a good shop? Thanks!
TGC is offline   Reply With Quote
Old 01-23-2016, 04:12 PM   #7
There's adjustable camber built in the rear
Mcturd81 is offline   Reply With Quote
Old 01-24-2016, 07:04 AM   #8
Philly2304's Avatar
Springs with no camber plates? I am kind of new with mustangs but I have always been told that it you lower a car with springs the camber would always be out. Is this not true? I have been putting off buying springs because I thought I would have to buy camber plates to and I wanted to do other things with the money. Maybe TJ can weigh in and confirm this?
Old 01-24-2016, 12:14 PM   #9
tj@steeda's Avatar
With the new S550 chassis Ford has given the Mustang 7 degrees of camber straight from the factory!
Any more caster added to this system will actually pull the front suspension out of its ideal camber gain range and cause us to begin losing grip in the front end.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 01-24-2016, 12:16 PM   #10
tj@steeda's Avatar
Philly - plenty of savings there to get you into the Steeda Springs!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 01-24-2016, 12:27 PM   #11
Diehard's Avatar
Originally Posted by tj@steeda View Post
With the new S550 chassis Ford has given the Mustang 7 degrees of camber straight from the factory! Did you mean Caster?
Best Regards,
TJ
Old 01-24-2016, 02:45 PM   #12
Philly2304's Avatar
Ok so if I get this straight, I can get Steeda progressive springs and an alignment and I would be just fine with camber and caster? I know what camber and caster are but when you guys start talking about how many degrees I am not that smart on that. Thanks for the help guys.
Old 01-26-2016, 09:55 PM   #13
You'll be fine. Just rub some dirt on it and get back out there!
Old 01-26-2016, 10:03 PM   #14
tj@steeda's Avatar
Yes, 7 degrees of caster ... thank you for the catch.
Also, regarding the alignment - If you are just looking to get your car back into factory alignment specifications, then yes, this is totally do-able with factory hardware.
Happy to help place an order for our springs ... you can email me directly at tim@steeda.com.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Spring compressor for strut/shock spring installation liv4spd 2011-2014 V6 Mustang 9 07-24-2015 12:21 AM
Lowering Spring Installation - No Spring Compressor?? Mean14 2011-2014 V6 Mustang 12 05-22-2015 01:48 AM
Wanted: Steeda sport spring and Steeda HD mounts paintmann111 Mustang Parts for Sale and Wanted 0 03-17-2015 06:03 PM
Steeda Sport Spring or Ultralite Springs Randeezy23 2011-2014 Mustang GT 34 10-20-2014 04:54 PM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 05:11 PM
» Members Mustangs
Joe's GT
jhealy608
Red
Red89
Add your Mustang
02:00 AM
