Tire Size - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 02-15-2016, 04:30 PM   #1
VTHokiez's Avatar
Tire Size
Hey guys/gals,
Anyone have 275/35r20 all the way around, or know if I'd have any issue? I have the Pirelli summer tires and want to go to the Continental DWS Extremes to "wear" year round (Pirellis are downright scary in wet conditions). Any thoughts?
Thanks, Adam
VTHokiez is offline   Reply With Quote
Old 02-15-2016, 05:06 PM   #2
Senior Member
dgc333's Avatar
The factory offers 265/35-20s as an option, they are the same overall diameter as the stock tires. The 275s are going to be slightly larger in overall diameter.
Dave
dgc333 is offline   Reply With Quote
Old 02-15-2016, 05:26 PM   #3
VTHokiez's Avatar
Originally Posted by dgc333 View Post
The factory offers 265/35-20s as an option, they are the same overall diameter as the stock tires. The 275s are going to be slightly smaller in overall diameter.
Dave
Hey Dave - I actually have the 265/35r20 option on mine, just curious if I could go slightly wider. If so, should I adjust up to 275/40r20 to compensate for the decreased diameter? Plugged it into a tire calculator, and seems comparable.
Old 02-16-2016, 12:44 AM   #4
Trevorhart3's Avatar
Tire Size
275/35-20 will fit in the front on the 11-15 (from personal experience can't talk about earlier years) and obviously will fit in the rear as well. Offset and width of the rim is important as well as diameter of tire as I'm sure you know.
Trevorhart3 is offline   Reply With Quote
Old 02-16-2016, 01:56 AM   #5
On my '16 I have 275/35/20's all around on 20"x10" wheels. No issues with anything.
la pantera is offline   Reply With Quote
Old 02-16-2016, 05:17 AM   #6
VTHokiez's Avatar
Thanks all - I am taking wheel width into consideration. Panther, would you mind snapping a few photos to share what your tires look like from the side and rear? Would love to see the stance.
Old 02-16-2016, 05:46 AM   #7
Already got 'em. Look up Niche Targa wheels on '16 GT PP on this site. Or something like that. They fill out the fender wells nicer than stock, and leave enough room for lowering it. (Which I am doing when it gets a little warmer).
Old 02-16-2016, 06:06 AM   #8
VTHokiez's Avatar
Solid! Found 'em - looks great!
Old 02-16-2016, 12:01 PM   #9
Diehard's Avatar
Hopefully you are aware of it by now but the 275/40R20 is an increase in diameter and is further away from your stock diameter.
Old 02-16-2016, 01:02 PM   #10
Jbone007's Avatar
My Saleen has 275 40 R20's on the back and 35's on the front! But not sure what the offset is on the Saleen Wheels.
Jbone007 is offline   Reply With Quote
Old 02-16-2016, 01:22 PM   #11
VTHokiez's Avatar
Thanks for the reminder. I'm factoring that into the decision as well.
Old 02-16-2016, 05:05 PM   #12
Senior Member
dgc333's Avatar
A 275/40-20 is about an 1.5 inches larger in diameter than the factory size 265/35-20. A 275/40-20 would be closer to the factory in diameter, just slightly taller.
Dave
Old 02-16-2016, 06:34 PM   #13
Road Dog's Avatar
Dave
That should read a 275/35-20 would be closer to the factory in diameter. Just .3" taller.
2016 GT Vert, SB, AT, 3:55s Weathertech, JLT, Steeda, Colgan, Velossa Tech, Coyote Spacers, Diode Dynamics, Shelby GT350 SW, Curt, Goodridge, aFe, MRT, BMR, Kooks, Mishimoto
Road Dog is offline   Reply With Quote
Old 02-16-2016, 06:49 PM   #14
VTHokiez's Avatar
Thanks! I like the way Panther's setup looks. Probably will commit to the 275/35r20
Old 02-17-2016, 06:43 AM   #15
275-35 is taller than your stock tire. There is no decreased diameter. 275-35 should be fine. I run a 275-35-19 on a 19x9 rim in the front with no issues.
Mcturd81 is offline   Reply With Quote
Old 02-17-2016, 11:06 AM   #16
Senior Member
dgc333's Avatar
You would be right, seems I can't type anything right in this thread.
Dave
Old 02-18-2016, 06:16 AM   #17
Smoked50's Avatar
My car came stock with 255-45-19 (28.04 dia) I am running 275-35-20 (27.58 dia) and 295-35-20 (28.13 dia) on 20x9x35mm and 20x10x41mm on a 1" - 1-1/2" lowered car and they fit perfect with room to spare.
Whipple 2.9 Stage II, Dual Fans, 132mm TB, open AB, , UPR Catch can with clean side separator,KW-KV1 Coil Overs, IRS Subframe Alignment Bushings, Rear IRS Subframe Bushings, Adjustable Rear Toe Links, Billet Aluminum Vertical Links, Adjustable Differential Bushing Insert System, DSS 3-1/2" Alum D/S, Cervintis hood and rear wing spoiler, Magnaflow 3” Street Series Catbacks, CDC Outlaws 20x10R, 20x9F with Nitto Invos’s 295x35x20R, 275x35x20F.
Smoked50 is offline   Reply With Quote
what size rims and what size slicks for 2005 GT? inzain Mustang Wheels & Tires 3 11-30-2013 08:37 PM
Biggest rear tire size on 18" tire ChrisMustangs Mustang Wheels & Tires 6 06-24-2013 02:46 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
Tire size Help 35thAniVertible Mustang Audio & Video 1 11-03-2003 01:23 PM
05:48 PM
