Supercharger. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 02-16-2016, 03:06 PM   #1
Supercharger.
Will be getting a supercharger soon. Leaning towards vmp, paxton or vortech. Which one are you guys running? Whats easiest to install? Better numbers
Sent from my SM-N910P using Mustang Evolution mobile app
5inco is offline   Reply With Quote
Old 02-16-2016, 10:30 PM   #2
The_Chech's Avatar
VMP for sure! I have one sitting in my living room as we speak. You get so much out of these kits it's crazy. Click image for larger version
Name:	ImageUploadedByMustang Evolution1455686989.849472.jpg
2011 Kona Blue Gt
IG - The_Chech
Oxford White Roush Stage 1 SN# 6925--SOLD but never forgotten!
Kona Blue GT premium - Slammed on BC's and BMR's full rear suspension
The_Chech is offline   Reply With Quote
Old 02-16-2016, 10:44 PM   #3
I can get a vmp for 6900. Is that a good deal? Or a paxton with injectors nd pump for 5500
Old 02-16-2016, 10:53 PM   #4
The_Chech's Avatar
Where are you looking at the VMP kit for that much? I got mine for way less. Also the Paxton's are great kits but really lack in the torque department. For what you get out of the VMP setup and both being around the same price you get, if you will the most "Bang for your buck". Both install wise can be done on a weekend and really aren't to complex. VMP's kit already comes with a wiring harness so no need to de-pin any of the wires.
2011 Kona Blue Gt
IG - The_Chech
Old 02-16-2016, 11:14 PM   #5
Its a stage 2 vmp. So 6900 is too much? Where did you get yours ? Also what else do you have to upgrade? Driveshaft? The vmp is faster than vortech nd paxton?
Old 02-17-2016, 06:04 AM   #6
Sterlingbeast5.0's Avatar
the Paxton I have is awesome. I love it. I have only driven one twin scre but seemed even harder to launch. I actually like the minimal spool I get. Launch quick then kicks in. I can tell you that if the block can handle it (and it will someday when I do some internal work) the Paxton can get to a higher output than the twins... MAYBE the Mamouth K&B woud be close but it is way to expensve lol. I got mine with plugs, maxflow BOV ID 10000 injetors, JLT CAI and boss adapter for 6700
BTW I did Driveshaft at same time but that was mainly because went to Tremec transmission also
Old 02-17-2016, 10:03 AM   #7
The_Chech's Avatar
I got my VMP kit for around 5600 out the door. I didn't want the phase 2 because I'm going a different route then the VMP boost a pump, different injectors, and I already have smaller pulleys laying around. I already have a fully adjustable suspension and a good set of tires sitting in the garage. So I'll be able to get all the power to the ground with out issue. It's really comes down to what you want out of the system. Both type blowers are going to be great. I just personally wanted a PD blower that I could really grow into.
2011 Kona Blue Gt
IG - The_Chech
Old 02-17-2016, 06:25 PM   #8
Mstablein's Avatar
Have my Vortech on order from Beefcake Racing, can't wait till it gets here....
2015 GT Premium Triple Yellow
Niche Essen Staggered
JLT with tune
Borla ATAk cat back
Mstablein is offline   Reply With Quote
Old 02-17-2016, 06:51 PM   #9
Famine's Avatar
Region: South Dakota
My neighbor is going with the 2.8 whipple, but I have yet to research to back up his claim of it being the best route to go. I look forward to hearing how it goes for him.
Famine is offline   Reply With Quote
Old 02-17-2016, 06:56 PM   #10
Mstablein's Avatar
They all have their pros and cons
Old 02-17-2016, 07:09 PM   #11
Rapinator126's Avatar
He most have ordered the only one available.
LSX 408 FTW
Dragging your a$$
Old 02-17-2016, 07:19 PM   #12
Famine's Avatar
LSX 408 FTW
Dragging your a$$
What do you mean?
Old 02-17-2016, 07:22 PM   #13
Supercharger.
What do you mean?
Whipple does not make a 2.8
KB does though.
LSX 408 FTW
Dragging your a$$
Old 02-17-2016, 07:35 PM   #14
The_Chech's Avatar
Whipple makes a 2.9 though and that thing screams
2011 Kona Blue Gt
IG - The_Chech
Old 02-17-2016, 08:41 PM   #15
Famine's Avatar
KB does though.
LSX 408 FTW
Dragging your a$$
Sorry. Typo. That's what I meant
Old 02-17-2016, 09:01 PM   #16
I think im going with whipple. Was offered a kit for 7500 installed and 500 for a dyno tune.
Old 02-17-2016, 09:02 PM   #17
What other mods should i do to back up the power? I hear half shafts break easily and driveshafts. Should i look into that or only if im going to be tracking the car?
Old 02-17-2016, 09:27 PM   #18
The_Chech's Avatar
Every thing from the clutch, driveshaft, and half shafts. I'm doing billet oil pump gears and timing chain sprockets when my blower goes on just for good measure.
2011 Kona Blue Gt
IG - The_Chech
Old 02-18-2016, 03:52 AM   #19
Smoked50's Avatar
Whipple 2.9 here,,, 50 state carb legal, Whipple tune, 132mm TB upgrade, 93 octane 651 RWHP with my auto. Drives better than stock and is crazy fast at about 1/4 throttle when the boost starts kicking in.. They all have good systems but Whipple has my vote and their tune is hard to beat on power and drivability for a DD.
Whipple 2.9 Stage II, Dual Fans, 132mm TB, open AB, , UPR Catch can with clean side separator,KW-KV1 Coil Overs, IRS Subframe Alignment Bushings, Rear IRS Subframe Bushings, Adjustable Rear Toe Links, Billet Aluminum Vertical Links, Adjustable Differential Bushing Insert System, DSS 3-1/2" Alum D/S, Cervintis hood and rear wing spoiler, Magnaflow 3” Street Series Catbacks, CDC Outlaws 20x10R, 20x9F with Nitto Invos’s 295x35x20R, 275x35x20F.
Smoked50 is offline   Reply With Quote
Old 02-18-2016, 07:22 AM   #20
Did you go with their tune or dyno tuned? Also what else did you upgrade?
Old 02-18-2016, 08:25 AM   #21
Smoked50's Avatar
Whipple tune, 132mm TB and dual fan upgrades from Whipple. I have a MF 3" street catback system too. Other than that stock and I have Whipples warranty good for $5000 on engine. They now offer 72# injectors for more HP if you want. I have the 58#. If you plan to add LT's or maybe a pulley drop that would keep you good for about another 100RWHP with their tune. Their system is not the cheapest but their technology is ahead of the pack in my opinion and there are some good deals out there for forum members.
Old 02-18-2016, 10:02 AM   #22
Ok cool thanks for the info man. How much did you get your whipple for? And installation if you dont mind.
Old 02-19-2016, 05:07 AM   #23
Smoked50's Avatar
"Ok cool thanks for the info man. How much did you get your whipple for? And installation if you dont mind."
PM'ed sorry for the PM just noticed you are in Cal.. Whipple has the best price around on installs.
Old 02-19-2016, 07:33 AM   #24
TTmustang10's Avatar
Supercharger.
They make a KB mammoth for our 5.0 ??? 😍
TTmustang10 is offline   Reply With Quote
Old 02-19-2016, 10:49 PM   #25
the new 2.9L front fed whipple is the best kit out there for the 15's right now. no cutting is involved with install. the vmp/roush blowers require you to shave down your valve chain cover and to cut your k-brace.
also the new 2.9L whipple is by far the most capable for the price. puts down big numbers.
2015 Whipple Supercharger Ford Mustang SC System
5liter is offline   Reply With Quote
Old 02-20-2016, 12:02 AM   #26
I have the pp with 3.73 gears. Would that be an issue with a supercharger
Old 02-20-2016, 05:01 AM   #27
Smoked50's Avatar
No just somewhere around 690-700rwhp if you like that and drive better than stock if you get the 132mm tb upgrade and Whipples tune.
Old 02-20-2016, 04:15 PM   #28
I advise against whipples tune. If you want to be fast that is.
LSX 408 FTW
Dragging your a$$
Old 02-20-2016, 04:51 PM   #29
LSX 408 FTW
Dragging your a$$
I think whipple will void their warranty if you dont use their tune
Old 02-21-2016, 08:09 AM   #30
The_Chech's Avatar
Gotta pay to play haha
2011 Kona Blue Gt
Old 02-22-2016, 03:59 AM   #31
Smoked50's Avatar
LSX 408 FTW
Dragging your a$$
Depends on what your goal is, there is a guy in Texas running 10.5 @ 134 on whipples tune, could you get more out of it? LR is running 9.7 at 151 with theirs. Yes but would it be reliable? Drive as good? etc, etc? its your choice on what you want and the warranty is only good with whipple tune and you can't change without them knowing they lock it.
Old 02-22-2016, 07:11 AM   #32
Lol
LSX 408 FTW
Dragging your a$$
Old 02-22-2016, 12:38 PM   #33
I think ill be happy with 10s for now lol.
Old 02-22-2016, 12:39 PM   #34
Lol
LSX 408 FTW
Dragging your a$$
Rapinator what's your set up
Old 02-22-2016, 12:50 PM   #35
natestang07's Avatar
He doesn't have one anymore :p he used to spray though
Root style Supercharger vs Centrifugal Supercharger jackiegnat 2015 Mustang GT 12 03-27-2015 11:05 AM
Next Gen Electric Supercharger??? Rellik Pre-2005 V6 Mustang 31 10-13-2003 07:03 AM
supercharger el cheapo Pre-2005 V6 Mustang 0 08-20-2003 10:34 PM
$200+ complete supercharger, help Stang01 Pre-2005 V6 Mustang 3 07-20-2003 04:07 PM
Supercharger or Nitrous? ERICK Pre-2005 V6 Mustang 8 05-12-2003 02:41 PM
03:43 PM
