Long tubes ? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 02-18-2016, 11:56 AM   #1
TTmustang10's Avatar
Long tubes ?
Kooks 1-7/8
Or
Kooks 1-3/4
TTmustang10 is offline   Reply With Quote
Old 02-18-2016, 12:33 PM   #2
2014Vert's Avatar
Bigger if going to supercharge, smaller if not. That is a super basic/generalized answer with no other knowledge of your car, setup, or plans.
2014Vert is offline   Reply With Quote
Old 02-18-2016, 12:43 PM   #3
Will be going supercharged
Old 02-18-2016, 12:57 PM   #4
2014Vert's Avatar
Bigger primaries will allow for more air out.
Old 02-18-2016, 03:32 PM   #5
I'll be going 1-7/8
Old 02-18-2016, 04:18 PM   #6
My mechanic/tuner (which works for Nascar) said that bigger does not always equal better. He said 95% of street cars run 1 3/4, there is no reason to do 1 7/8 unless you push your car extremely far. He said any extra money for them is a waste. I am currently at 617RWHP supercharged and plan on being around 650 to 675 within a few weeks. Hope this helps
Phase 3 upgrade including CAI, Fuel pump voltage regulator, (648rwhp), 582 torque, Kooks LT headers with off road H pipe, Vossen CV3's, ID1000's, Steeda Heat Exchanger, BMR LCA's,relocation brackets, adjustable Panhard bar, Rear sway bar, Steeda Aluminum driveshaft, X-brace, Differential cover, torque box brace/frame rails, Shelby trans cooler, Mcleod RST clutch/lightweight steel flywheel w/SS clutch line, RP fluids, whiteline transmission bushing,MGW race spec short shifter,Ford racing twin 65mm throttle body, Pro Dyno tuned
jamyzd30 is offline   Reply With Quote
Old 02-18-2016, 10:24 PM   #7
It's only $20 between the two price difference.
Old 02-18-2016, 11:52 PM   #8
Headers are overall just a pain in the *** to install, so the bigger they are, the tighter the squeeze....he was probably just trying to explain in to make the install easier, lol. Either way, they are bad *** sounding and will add some serious torque after tune. Enjoy!
Old 02-19-2016, 08:57 AM   #9
I'm already paying a lot better get the bang for the buck right only $20 more which isn't bad difference in price.
Next on my list is CAI/tuner and Driveshaft.
Then the wait for warranty to end then my supercharger.
Old 02-19-2016, 09:08 AM   #10
2014Vert's Avatar
Warranties are overrated. I voided mine as soon as I got the car.
Old 02-19-2016, 09:16 AM   #11
natestang07's Avatar
Your warranty could be toast when you tune.
Old 02-19-2016, 09:50 AM   #12
I work at a dealership unless they can prove the tune made something go wrong I'm covered.
Old 02-19-2016, 10:07 AM   #13
There are way too many arguments and concerns over warranty, don't turn this into one. With that being said bro, you best tune it the same time you put headers on it. Most people dyno before and after so they can actually see the benefit of their hard earned money. Headers is a major job though, not something you are going to switch back and forth. You notice most of the noise under throttle, at idle is isn't all that much different. Are you changing the exhaust all the way back? I went with an off road H pipe, most people prefer the X. It's rare when headers are the start of modding. No point in paying multiple times to get tuned, just grab your CAI, Tune, and headers all at the same time. Dyno it and get it dialed in, enjoy bud!
Old 02-19-2016, 11:48 AM   #14
Dyno tuning for mild bolt ons? I too like to toss money into a burning barrel.
Old 02-19-2016, 11:55 AM   #15
Famine's Avatar
Region: South Dakota
Long tube headers, which Primary size is 'best'?
Famine is offline   Reply With Quote
Old 02-19-2016, 12:05 PM   #16
Really buddy....I have had my car tuned a few times, dyno runs are always included in price of tune. Maybe u only have availability in your location to email tunes? Tunes normally run me around 400 including 3 pulls on dyno. You pay how much for email tunes? Headers a mild bolt on? Maybe not major, but cost a few thousand. You are not really answering any questions, more so chiming in with dumb *** comments.
Old 02-19-2016, 02:52 PM   #17
Already have X pipe and axle backs 👌🏻
Getting the drive shaft put in while putting long tubes in.
Going with a bama tune
Old 02-19-2016, 03:38 PM   #18
Gotcha man, as for the X pipe, catless? What axle backs you running? Mine is a 2014, so I am not 100% sure about yours. But my RS3 after the H pipe is only 2.5 inch, so if you only have an axle back, you might want to look at opening it up a bit more. I am not sure if 15 is 3 inch or not. But opening up that restriction may help a little as well. A friend claimed to have added 30RWHP by going from his 2.5 to 3 inch setup. As for tune, I am sure you did your research....but most people on here seem to highly recommend justin at VMP or Shaun at AED. I have read a ton of mixed reviews on bama....More bad than good. I also switched to 1 piece DS, great upgrade!! Much lighter and the tires seemed to break loose even faster than before, ha. Keep us posted with everything, them are some great upgrade choices!!!
Old 02-20-2016, 05:37 AM   #19
Grabber Blue5.0's Avatar
Dyno tunes are not necessary for a basic bolt on car. I tune my own car on the street in real world time as well as a few local guys I've helped. Cost is 0.
Old 02-20-2016, 07:42 AM   #20
Was this thread started to ask if dyno tunes were necessary? I say when tuning your car, if dyno pulls are included to make fine tune adjustments, then great, thats a bonus! If not, oh well. If youre a tuner in the real world, why not offer advice on the actual thread? At least you were respectful though. As for other peoples comments, maybe we should stick to the actual post and not be a ******.
Old 02-20-2016, 09:45 AM   #21
Famine's Avatar
Dyno tuning will just allow you to get those small adjustments here and there to get that little bit more out of it. You have know way to tell that on the street.
Old 02-20-2016, 04:13 PM   #22
You buy the tuner through AM get free tunes why not run it. They've been good to me in the past.
Once I get my supercharger I'll Find a good tuner to dial her in right.
Bama tune should be fine for long tubes CAI and the Carbon Fiber DS. With the exhaust I've got now.
As for 2.5" or 3" I'm just going to get E Cut outs less expensive then getting custom 3" pipes made.
Unless I go all aluminum to cut weight then maybe 3"
Old 02-21-2016, 08:40 AM   #23
B.S. How many cars have you tuned where you arrived to this conclusion? Tuning on the street in "real world conditions" is the way to go.
Old 02-21-2016, 02:44 PM   #24
Just because some guy has a Dyno does not mean you are getting a quality tune. Want real world experience? Message Alrefire and ask him how his reputable Dyno tuner did for him.
Old 02-22-2016, 11:20 AM   #25
Famine's Avatar
No, both are the way to go.
Ps, you obviously have to have a reputable tuner, or a dyno or a street tune argument is obsolete.
Old 02-22-2016, 12:53 PM   #26
Rosariors3's Avatar
I'm debating whether or not to do the long tubes and x or h pipe cause I like the sound of the roush axle back so much. How did it change the sound after u installed those 2?
I might not know as much as you but i know how to drive better than you!!!
Rosariors3 is offline   Reply With Quote
Old 02-22-2016, 01:06 PM   #27
P.S. I tuned my own car on the street and 6 others to date. How many have you tuned again?
Back on topic. Go with the 1 7/8 primaries.
Old 02-22-2016, 01:28 PM   #28
The sound didnt change entirely much at idle. When they pulled the car up I actually expected more. Then he revved it and brought an instant smile to my face! Under throttle it is SICK!!! Nascar sounding under wide open throttle. Its great on highway if someone is drifring into lane. You rev it some and they run off road scared. At cold start it can be annoyingly loud, but it settles down after 20 seconds or so. In my opinion headers are a must have! I love them! The added power after tune was impressive as well. Honestly though the 2.5 inch roush exhaust is probably a little restrictive. I sort of want the kooks cat back now. Thats 3 inch all the way back and i want to keep roush tips. It would probably quiet it down some im sure. As you though, i love the roush sound, very unique tone. I might go kooks all the way, not sure. I dont want it quieter per say....ill keep u posted. The one roush Guy went to 3 inch exhaust and claimed to gain 30rwhp....i think that might be exaggerating, its one for sale on ebay, race built around 79k. I love it! I wish mine was forged, i might be pushing limits now....and cant afford a new motor. Injextors id 1000 and heat exchanger along with retune next week.
Old 02-22-2016, 02:02 PM   #29
Rosariors3's Avatar
R you on 82 mm pulley?
Old 02-22-2016, 02:15 PM   #30
80mm , Roush phase 3 kits comes with smaller pulley, VMP does not for some reason. There are a few options for me if i end up running E85 though, so potentially back to 82 mm pulley if i get a bigger BAP. I might end up running a different fuel system though, not sure
Old 02-22-2016, 02:18 PM   #31
Rosariors3's Avatar
Vmp phase 3 comes with 82mm. I was thinking going to 79mm but I don't know if I want to risk it.
Old 02-22-2016, 02:33 PM   #32
Famine's Avatar
I don't tune. If you want, argue with Shaun at AED. A REAL tuner.
But you're right, back on topic and agreed, go with the 1 7/8
Old 02-22-2016, 03:37 PM   #33
I wouldn't get an x pipe with a Roush axleback personally. Big pile of raspy mess
Old 02-22-2016, 03:48 PM   #34
Rosariors3's Avatar
Yea that's what I'm trying to avoid. Thanks for the heads up
Old 02-22-2016, 04:16 PM   #35
Famine's Avatar
How does this sound?
http://vid1352.photobucket.com/album...psrzfrqs4j.mp4
Having second thoughts on Long Tubes USMCSS 1996-2004 Mustang GT 12 02-09-2007 03:09 PM
*gauging interest* mac long tubes and catted h pipe... dark Mustang Parts for Sale and Wanted 7 06-12-2006 10:44 AM
long tubes kraz3y Pre-2005 V6 Mustang 14 03-02-2006 05:43 AM
v6 long tubes and h pipe joebadguy Mustang Parts for Sale and Wanted 10 10-26-2004 10:45 PM
long tubes? timpryor Pre-2005 V6 Mustang 18 07-04-2004 07:59 PM
06:22 PM
