Steeda Hood Struts? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 03-08-2016, 02:03 PM   #1
Steeda Hood Struts?
Hello all:
I bought some Steeda Hood Struts for my 2015 GT Convertible. Installed them as per Steedas instructions. They work fine. The hood stays up as expected.
The issue is the brackets that attach to the top of the fender inside the engine compartment are crooked. It's like Steeda skimped on 20 cents worth of metal. I spoke with Steeda and them seem remarkably uninterested! Any one else having this type of issue?
15redvertgt is offline   Reply With Quote
Old 03-08-2016, 06:27 PM   #2
Pics?
I bought struts as well, but there are not any lower brackets on mine as the fastener goes through the pre-existing hole in the fender and then tightens from below. The lower part of the strut then just snaps on to the bracket.
Old 03-08-2016, 08:13 PM   #3
Name:	ImageUploadedByMustang Evolution1457493225.402726.jpg
Old 03-08-2016, 08:16 PM   #4
Guard5.0, I even tried using marine grade silicone adhesive to get the brackets to stay in place. They stayed straight until I closed the hood, then they went crooked again. They work fine, but I dislike the look.
Old 03-08-2016, 08:20 PM   #5
tj@steeda's Avatar
Hello RedvertGT,
Please send me your order number, photos & whom you spoke with on the phone - you can send directly to tim@steeda.com.
I apologize for the inconveniences you are experiencing, I will do my best to make the situation right.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 03-10-2016, 05:03 AM   #6
That's to be expected. My mmd hood struts did the same thing. It's a design flaw. Redline hood struts don't do this.
Mcturd81 is offline   Reply With Quote
Old 03-10-2016, 06:09 AM   #7
That looks like complete **** honestly... I'd get a set that doesn't do it. If the Redlines don't, return the Steedas and get the Redline.
Old 03-10-2016, 07:45 AM   #8
oxfordwhite's Avatar
I bought the Redlines, Fit is absolutely perfect. So easy to install. They look and work like they were original equipment
oxfordwhite is offline   Reply With Quote
Old 03-10-2016, 06:25 PM   #9
Redline ftw!
Old 03-11-2016, 09:59 AM   #10
tj@steeda's Avatar
For the record, still haven't heard from the OP ... happy to help if I can.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 03-11-2016, 11:11 AM   #11
Best Regards,
TJ
Kinda hard to help em if they don't call ya back huh?
Old 03-11-2016, 12:57 PM   #12
Sorry for the late reply! Had to go to the warehouse and uncover the car and take more pics of the struts and brackets.
You asked me to reply to you via your email and I will later today!
Old 03-14-2016, 06:07 PM   #13
For the record I have replied to Tim at Steeda and am waiting to hear back from him!
Old 03-14-2016, 06:12 PM   #14
tj@steeda's Avatar
Hello Redvertgt,
I just checked my inbox & spam folder - nothing.
When you re-send, shoot me a p.m. so I know when it comes in.
Thank you.
TJ
---------- Post added at 07:12 PM ---------- Previous post was at 07:12 PM ----------
Hello Redvertgt,
Thank you.
TJ
Steeda Autosports
www.steeda.com
Old 03-14-2016, 06:42 PM   #15
I will resend in 1 minute!
Thanks
---------- Post added at 12:42 AM ---------- Previous post was at 12:42 AM ----------
Resent
Old 03-14-2016, 06:54 PM   #16
tj@steeda's Avatar
Still nothing, let's start again. Are you sending to tim@steeda.com? Send me a test email first then attach photos ... maybe the size of the photos are causing issues?
Steeda Autosports
www.steeda.com
Old 03-14-2016, 07:00 PM   #17
Okay I tried again from a new email address.
Old 03-14-2016, 07:23 PM   #18
Spoke with Tim @ Steeda and we will see what can be done. More to follow!
Old 03-15-2016, 04:12 AM   #19
Smoked50's Avatar
Sorry for you problems, I have had this Steeda set on my car for almost a year and I now have the Cervintis hood which is much heavier and mine have been perfect. I installed / torqued like they said and they have never moved or loosened.
Whipple 2.9 Stage II, Dual Fans, 132mm TB, open AB, , UPR Catch can with clean side separator,KW-KV1 Coil Overs, IRS Subframe Alignment Bushings, Rear IRS Subframe Bushings, Adjustable Rear Toe Links, Billet Aluminum Vertical Links, Adjustable Differential Bushing Insert System, DSS 3-1/2" Alum D/S, Cervintis hood and rear wing spoiler, Magnaflow 3” Street Series Catbacks, CDC Outlaws 20x10R, 20x9F with Nitto Invos’s 295x35x20R, 275x35x20F.
Smoked50 is offline   Reply With Quote
Old 03-15-2016, 06:31 AM   #20
Every time I tried to increase the torque the brackets moved to give it that lopsided look. Not sure how you did it but it didn't work for me.
Old 03-15-2016, 10:01 AM   #21
Did you try switching brackets to the opposite sides?
Old 03-15-2016, 10:28 AM   #22
No I did not. Not sure that you can do that with these brackets. The ball has to face out.
Old 03-15-2016, 12:08 PM   #23
I don't see a locating tang in the picture, looks like you could put them on either side.
Old 03-15-2016, 01:37 PM   #24
You probably can, but I do not see the point. If I have to remove them again it will be a permanent solution. Done this twice already.
Old 03-16-2016, 07:03 PM   #25
Working with Steeda to sort this out. So far they have been great! We will see how it all ends up.
Old 04-08-2016, 06:44 PM   #26
Okay I sanded the backs of the brackets and reattached them to the fenders. Used 15 lbs of torque instead of 13. It's been a week and all is well. I am just happy that they work! I really didn't want to return them.
Steeda and American Muscle were great to work with during the process.
Thanks!
Old 04-08-2016, 08:21 PM   #27
tj@steeda's Avatar
Thank you for posting your update & appreciate the follow-up emails.
Have a great weekend!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 04-09-2016, 04:54 AM   #28
TigerStang's Avatar
Region: Rhode Island
hey guys, i was interested in these hood struts, but i don't buy anything until i understand how it gets put in. i see that one plate has 2 holes in it, and the other plate does not have 2 holes in it. is there a reason for this? also, if anyone has any pictures of the bottom half of their redline kit installed, please post em up, ty.
TigerStang is offline   Reply With Quote
Old 04-09-2016, 06:37 AM   #29
Rosco3's Avatar
AM doesn't show instructions. It looks like they install really easy and don't require any skill compared to the other ones where you have to disassemble the existing bracket/hinge. Been wanting some of these for a while. So like 10 min install?
Ingot Silver Metallic 2013 Mustang 5.0 Premium, Flowmaster Outlaw Exhaust, Airaid CAI, JLT Oil Separator, MMD Black Zeven Wheels
Rosco3 is offline   Reply With Quote
Old 04-09-2016, 07:31 AM   #30
tj@steeda's Avatar
This is the best I can do:
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 04-15-2016, 01:17 PM   #31
White5ohhhhh's Avatar
It's so annoying how we don't get hood struts stock
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
2016 Oxford White GT PP-Roush Catback,GT350 Shift knob,MGW Race Spec
White5ohhhhh is offline   Reply With Quote
Old 04-15-2016, 01:22 PM   #32
tj@steeda's Avatar
We're okay with it
TJ
Steeda Autosports
www.steeda.com
Old 04-16-2016, 03:26 PM   #33
Diehard's Avatar
We're okay with it
TJ
Old 04-17-2016, 05:12 AM   #34
Mstablein's Avatar
I put the Redlines on last year, fit perfectly and quick and easy to install.Click image for larger version
Name:	ImageUploadedByMustang Evolution1460891490.085524.jpg
ID:	199906Click image for larger version
Name:	ImageUploadedByMustang Evolution1460891513.137334.jpg
ID:	199907Click image for larger version
Name:	ImageUploadedByMustang Evolution1460891539.724233.jpg
2015 GT Premium Triple Yellow
Niche Essen Staggered
Paxton Supercharged
Borla ATAk cat back
Mstablein is offline   Reply With Quote
hood struts and hood pins emery2483 Mustang Paint, Appearance & Detailing 10 03-15-2016 05:19 AM
Koni Shocks and Struts 25% off (steeda.com) Logiq 2011-2014 Mustang GT 112 03-12-2015 08:57 AM
Hood struts on a cervinis hood? Rm360 General Mustang Discussion 8 06-19-2013 02:34 PM
Steeda shock and struts AGmustang11 2005-2010 Mustang GT 28 01-09-2013 01:04 PM
ProLift Hood Struts Installed Rygen Pre-2005 V6 Mustang 2 02-19-2006 05:37 AM
07:57 AM
