Uneven ride height after lowered spring - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 03-12-2016, 09:30 PM   #1
Hey guys,
I installed a set of new Steeda 1' lowering spring on my S550 today and immediately after the installation, I noticed a ride height difference between the driver rear and the passenger rear. The driver rear is about 1/2 inch lower than the passenger rear. I had the spring installed by shop. Now I could easily tuck in 3 fingers with the passenger rear but only 2.5 fingers with the driver side.
Is it normal to have such a difference in ride height? Does the spring need time to "settle in"? Please give me some advices! Thanks!
weiyuhan is offline   Reply With Quote
Old 03-12-2016, 09:35 PM   #2
oxford5pointoh's Avatar
My guess is they did not seat the spring correctly on the side that is higher. It's not normal for one side to be that off. It's normal for springs to take a few days to settle, but I'd take it back.
Old 03-13-2016, 05:52 AM   #3
Strange Mud's Avatar
+1..you may want to give it a few days to see if it seats but I would call them up Monday AM and talk with them.
I moved your thread too in hopes of more responses.
Old 03-13-2016, 09:48 AM   #4
DiESeven's Avatar
Are you parked on a flat surface when noticing the difference?
Instagram: @v6beast
Old 03-14-2016, 12:39 PM   #5
yes I was parking on flat surface. Is there an acceptable range of height difference? As there are many factors affecting the ride height including the spring itself and the rubber isolator..
Old 04-24-2016, 07:52 PM   #6
UOP Shadow's Avatar
+1 on the not seated properly. The instructions are very clear to pay close attention to this.
2013 Ford Mustang SVT 20th Anniversary Cobra Shelby GT500. Stock, almost.
UOP Shadow is offline   Reply With Quote
Old 04-24-2016, 09:30 PM   #7
Revvv's Avatar
The springs are not turned to sit correctly in the pocket. Its an easy mistake to make. The shop should be able to have you going within 30 minutes if you tell them you are coming.
Hopefully you used a reputable shop.
Lowered front/stock rear height question Leo513 Mustang DIY and Technical 0 03-12-2016 05:01 PM
Uneven After-Market AxleBack Exhaust weiyuhan Mustang 101 - Tech Basics | Ask an Expert 24 11-13-2015 12:24 AM
uneven ride hight... Voltage258 1996-2004 Mustang GT 16 03-20-2013 06:32 PM
2011+ Stock spring height Fintile 2011-2014 V6 Mustang 13 02-28-2013 12:26 AM
05:03 PM
