Blacked out emblems - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 03-18-2016, 04:10 PM   #1
Philly2304's Avatar
Blacked out emblems
I just bought the blacked out emblems to change out on my 2015. Just wondering of the guys out there who have changed theirs, is there any gotchas or tricks to getting the existing emblems off.
Philly2304 is offline   Reply With Quote
Old 03-18-2016, 04:20 PM   #2
VTECLol's Avatar
On other cars I've just used dental floss, windex and micro fiber towel to remove the old glue. Not a bad idea to use some painters tape as a marker for the new ones. I'm not sure if the 5.0 badges are pegged though. Hope that helps a little.
2015 Race Red GT 6MT
VTECLol is offline   Reply With Quote
Old 03-18-2016, 04:28 PM   #3
Philly2304's Avatar
VtecLol, thanks for the help. The new emblems do have pegs so it will be easy to put them back on. I'll try the dental floss. I've also heard of people using fishing line. Thanks again.
Old 03-18-2016, 06:24 PM   #4
fishing line works really good and some sticker remover
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 03-18-2016, 06:27 PM   #5
EastTNMustang's Avatar
Heat gun on low to medium setting to loosen the adhesive.
EastTNMustang is offline   Reply With Quote
Old 03-19-2016, 08:02 PM   #6
Region: New Hampshire
I did mine on my 2016. A little heat (hair dryer is fine), strong fishing line and Goo Gone will take any adhesive left off and clean the area at the same time for your new emblems. Not so sure about the dental floss, its just not strong enough.
Also use some thin gloves so the fishing line does not cut into your hands.
---------- Post added at 10:02 PM ---------- Previous post was at 10:02 PM ----------
mhagerty is offline   Reply With Quote
Old 03-19-2016, 09:02 PM   #7
heebe_geebe's Avatar
I used black plastic dip on my badges, mirrors and rear panel... easy. 18 month still good....
If I change my mind I'll peel it off...
2014 MCOA, V6 PREMIUM, PERFORMANCE PACKAGE, COMFORT PACKAGE, SECURITY PACKAGE, DEEP IMPACT BLUE WITH SILVER CUSTOM COBRA STYLE STRIPES, AIRAID TUBE, TINTED 35%, PIONEER 8000 NEX, REAR CAMERA, BORLA TOUR AXLE BACK, K&N FILTER. JLT OIL CATCH CAN, CUSTOM MADE HOOD STRUTS, BBK SHORTY CERAMIC
heebe_geebe is offline   Reply With Quote
Old 04-05-2016, 10:25 AM   #8
scott_0's Avatar
heat from a heat gun or hair dryer, with fishing line to cut through the double sided tape and wd40 is great for removing the glue residue
Old 04-05-2016, 03:20 PM   #9
Philly2304's Avatar
Job complete! Thanks for all the help. I used fishing line and a hair dryer. Worked awesome. The glue residue was find if a pain but WD-40 worked good. I used 80lb test fishing line the smaller line kept breaking. On to the next upgrade.
Old 04-10-2016, 03:40 PM   #10
Member
Does anyone know of a vendor that sells the whole emblem blackout set? Pony, both 5.0, and back GT badge?
Sent from my SM-N915V using Tapatalk
SR56 is offline   Reply With Quote
Old 04-10-2016, 05:57 PM   #11
Philly2304's Avatar
I got all four badges from CJ pony parts. They have the pkg deal or you can buy them individually.
Old 04-15-2016, 01:25 PM   #12
White5ohhhhh's Avatar
Anyone got a write up with photos for this project?
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
2016 Oxford White GT PP-Roush Catback,GT350 Shift knob,MGW Race Spec
White5ohhhhh is offline   Reply With Quote
Old 04-28-2016, 04:00 AM   #13
Heyzeus's Avatar
hello,
I did mine with plastidip and it looks awesome. the good thing about doing it that way is that you save money, you don't have to remove the emblems and.... if you want to go back to chrome - then you just peel it off - I have a video posted here on how I did the 5.0. it's easy - it looks great, it lasts, its cheap. fast forward to minute 2:03 to see how easy it is:
http://youtu.be/lG8Qd5gTQ7E
Heyzeus is offline   Reply With Quote
Old 04-28-2016, 04:59 AM   #14
Member
Just ordered mine from CJPP. I'm sure someone has a tutorial out there. Can't imagine the level of difficulty is too high. Biggest concern will be getting the good from the stock ones off the car.
2016 Magnetic GT PP
Steeda CAI & Tune
Corsa Sport Cat-Back
Old 04-28-2016, 05:19 PM   #15
Mstablein's Avatar
Like mentioned above, dental floss or some good fishing line. If you use a hair dryer to heat it up helps a lot.
2015 GT Premium Triple Yellow
Niche Essen Staggered
Paxton Supercharged
Borla ATAk cat back
Mstablein is offline   Reply With Quote
Old 04-28-2016, 06:08 PM   #16
Member
Is there a "best" product for removing the glue without harming the paint?
Old 04-28-2016, 06:26 PM   #17
Mstablein's Avatar
I use 3m adhesive remover, test someplace hidden first.
Paxton Supercharged
Borla ATAk cat back
Blacked out is played out KraftDinner General Mustang Discussion 171 02-03-2014 07:54 AM
blacked out vs chrome out? Giffmastaflex 2005-2010 V6 Mustang 8 04-17-2012 12:07 PM
02:30 AM
