Tire Size Question - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 03-27-2016, 07:04 AM   #1
VTHokiez's Avatar
Tire Size Question
Hey Guys/Gals
I have the 2015 GT (non pp) with the OEM 20 inch rims. While the original tires are 265/35r20, I was curious if I could safely move up to 275/35r20.
Thoughts?
Thanks,
Adam
VTHokiez is offline   Reply With Quote
Old 03-27-2016, 04:10 PM   #2
ponie1992's Avatar
They'd be taller. Throw off your speedometer, I would think.
Jeremy
2016 Ruby Red PP GT
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 03-27-2016, 04:11 PM   #3
VTHokiez's Avatar
Jeremy
2016 Ruby Red PP GT
Yeah, figured they'd throw off the speedo, I was more concerned with the width of the tire fitting on the rim.
Old 03-27-2016, 04:31 PM   #4
ponie1992's Avatar
That's only 10mm wider. I think you'll be fine.
Jeremy
2016 Ruby Red PP GT
Jeremy
2016 Ruby Red PP GT
Old 03-28-2016, 05:12 PM   #5
Diehard's Avatar
The difference in diameter between those 2 tire sizes is only about 1%. That's well within the recommended difference of +/-2 to 3%.
Would make a difference of approx. 0.6 mph at a speed of 60 mph.
Old 04-01-2016, 07:54 AM   #6
The width will not be a problem. I have the same rims and my tire shop mistakenly put 305/30/20' s which fit under the rear quarter panel just fine. Of course the distance of tire sticking out from the rim looked ridiculous.
15redvertgt is offline   Reply With Quote
Old 04-02-2016, 01:05 PM   #7
Brandonb2012's Avatar
Could someone tell me what is the recommended psi for the 2015-2016 base 5.0 wheels? According to the tag on the door jamb? Click image for larger version
Name:	ImageUploadedByMustang Evolution1459623938.720888.jpg
Brandonb2012 is offline   Reply With Quote
Old 04-02-2016, 01:09 PM   #8
VTECLol's Avatar
32 psi I believe
2015 Race Red GT 6MT
VTECLol is offline   Reply With Quote
Old 04-02-2016, 01:09 PM   #9
VTHokiez's Avatar
Originally Posted by VTECLol View Post
32 psi I believe
This is what mine says.
Old 04-02-2016, 01:23 PM   #10
Tire Size Question
Thanks guys! Do y'all run that pressure? I believe the tires say max 51psi?
Old 04-02-2016, 02:03 PM   #11
Diehard's Avatar
Pressure on the tire = Maximum design pressure.
Pressure on the door is the recommended pressure to maintain when cold.
Some people like to run slightly higher for one reason or another.
Higher pressures tend to cause car to ride harder and tend to wear center of tire more. While lower pressures tends to soften the ride, decreases gas mileage and tends to wear outer edges of tires more.
Tire pressure sensors are based on the recommended pressure and typically are set at or near 25% below for alarming purposes.
Biggest rear tire size on 18" tire ChrisMustangs Mustang Wheels & Tires 6 06-24-2013 02:46 PM
Tire size and rim size 96gt Lios 1996-2004 Mustang GT 9 04-22-2012 10:33 PM
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
yet another tire size question WhiteStang99 Mustang Wheels & Tires 38 07-19-2004 12:49 PM
Spare Size Tire Question Crispy Mustang Wheels & Tires 1 02-05-2004 05:59 PM
06:13 PM
