Steeda Clutch Spring - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 05-13-2016, 08:34 AM   #1
ZombieSlayer's Avatar
I was really excited to get this put in but I am finding this near impossible to do. Here is what I see when the clutch is fully pressed in but I cannot get the needle nose vise grips to get in there to compress the spring.
Any tips would be appreciated because I am about to give up.
Name:	ImageUploadedByMustang Evolution1463150046.282027.jpg
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 05-13-2016, 08:55 AM   #2
oxford5pointoh's Avatar
Try turning it so that you can get 2 coils facing you. Then you should be able to get the needle nose vise grips on it.
Old 05-13-2016, 09:11 AM   #3
Ok i got it to turn but I cant get the spring to compress.....at all. The factory spring is tough. Heck, i can compress the steeda spring with 2 fingers.
And i am using the needle nose vise grips.
Old 05-13-2016, 09:35 AM   #4
tj@steeda's Avatar
Does this help you?
We Test the Steeda Mustang Clutch Assist
I believe in you!
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 05-13-2016, 10:23 AM   #5
You don't need it to necessarily compress you are locking it in to a compressed state from when you pop it off. So once you have the needle nose locking pliers secured onto it then you pop it from the top and that will keep it from springing out like crazy and hitting you.
Old 05-13-2016, 10:36 AM   #6
I think the reason I am struggling is because I lack the muscle. Lol. Been bed rested in the hospital for the past week. Gonna ask a friend to help me out later. Two sets of hands might make it easier.
Old 05-13-2016, 03:19 PM   #7
Got the spring installed and went for a ride. Wow, the clutch pedal just feels so much better during the entire press and release. Sometimes on this s550 i would get some jerking of the car because the stock spring just gave a terrible sense of clutch engagement. Now, every shift is smooth because I feel more connected with the clutch now.
For $10, you are not going to beat this mod. Next up is a steeda trans bushing insert and shifter bracket to eliminate that clunkiness.
Old 05-13-2016, 03:32 PM   #8
kona010's Avatar
Anyone know if this would work with a 2010 gt? 4.6 5spd? I get jerky take offs way more than I want bc I can't feel it starting to slip
kona010 is offline   Reply With Quote
Old 05-13-2016, 03:38 PM   #9
It looks like Steeda only has the springs for the 11-16 GTs right now. (Might work on Ecos and V6s but not 100%)
Old 05-13-2016, 03:44 PM   #10
kona010's Avatar
Thanks that's what I saw too. Tbh I haven't even looked down to see if the 2010 model has one to begin with but if it does I want a different one. I was just looking to see if someone already knew of one.
Old 05-13-2016, 08:57 PM   #11
tj@steeda's Avatar
Yeah, the 2011 & + Mustangs have a completely different assembly ... we don't anticipate making one for earlier years because of the design.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 05-13-2016, 09:22 PM   #12
Does it make the pedal stiffer?
Gt350r is offline   Reply With Quote
Old 05-13-2016, 10:14 PM   #13
When you press the clutch down with the stock spring, you feel it get stiff.....about halfway down? With the Steeda spring, it maintains that consistent feel all the way down and back.
Old 05-14-2016, 02:09 PM   #14
Senior Member
dgc333's Avatar
Sure you can, just take the stock spring out and save the $10. I have had the stock spring out on my 15 for over 25k miles now. The feel is far superior to the spring.
When I first got the car I would miss shifts to 3rd or 5th during aggressive driving all to often. I installed the Steeda Trans bushing and haven't missed one since. The best thing I have done for the notchiness of the tyranny was swapping the fluid to Royal Purple SyncroMax.
dgc333 is offline   Reply With Quote
Old 05-14-2016, 02:22 PM   #15
Your going to wear out your slave cylinder that way. That's the whole purpose of steeda making that spring.
Old 05-15-2016, 03:45 PM   #16
Senior Member
dgc333's Avatar
If you really believe that you are pretty naive.
Dave
Old 05-15-2016, 04:03 PM   #17
Dave
Yes because ford went to all that trouble to add a spring for no reason. Lol.
Old 05-15-2016, 04:16 PM   #18
Rapinator126's Avatar
We'll never ran the spring in my car. And the new owner still with no spring. 🤔 but hey for $10 if someone wants the piece of mind vs getting rid of it. then it's a steal.
LSX 408 FTW
Dragging your a$$
Old 05-16-2016, 05:25 AM   #19
Senior Member
dgc333's Avatar
The spring is an over center spring to reduce the effort required to push the pedal. Based on the number of people replacing it or removing it they didn't get it right.
It is not there to prevent the slave cylinder from wearing out. The pressure in the system remains the same regardless of whether there is a spring or not.
Dave
Old 05-16-2016, 05:49 AM   #20
shunc01's Avatar
Hmmm interesting.. Thanks for the idea kev.. I wish there's a notification button somewhere, so that I can follow you whenever you post something..
Sent from my SM-G935P using Mustang Evolution mobile app
2016 GT RACE RED MANUAL aka " RAGING BULL"
Mods:
Borla stypes cat back exhaust, tint kit all lights, 5.0 race red shift knob, MMD V SERIES SPOILER... and more to come...
shunc01 is offline   Reply With Quote
Old 05-16-2016, 06:53 AM   #21
Dave
Right...but without the spring the clutch pedal never fully returns to its normal position causing added stress on the slave cylinder.
Old 05-16-2016, 06:59 AM   #22
I did notice after installing the Steeda spring, there is a little play in the clutch pedal now. Like, I can move it maybe an inch or so back and forth very easily with just 1 finger. Will that cause any problems?
Old 05-16-2016, 07:28 AM   #23
You might want to check the specs on the rotary girder just to be safe.
Old 05-16-2016, 07:50 AM   #24
You might want to check the specs on the roto-gurter just to be safe.
What is that? I tried to google it and nothing came up for it.
Old 05-16-2016, 07:57 AM   #25
Sorry I spelled it wrong.
Name:	ImageUploadedByMustang Evolution1463407009.229926.jpg
Old 05-16-2016, 10:08 AM   #26
Senior Member
dgc333's Avatar
For the past 25k miles mine has returned fully every time. Plus I have never heard from anyone that has removed the spring having an issue with it returning.
Only after Steeda announced that it was an issue in their marketing propaganda for their spring did this become an issue.
Dave
Old 05-16-2016, 01:05 PM   #27
Dave
Because everytime you shift you get down there and check? Seems dangerous man.
---------- Post added at 07:05 PM ---------- Previous post was at 07:05 PM ----------
Nothing man? Come on that was funny.
Old 05-16-2016, 01:19 PM   #28
It was!!!
Old 05-16-2016, 02:06 PM   #29
scott_0's Avatar
lol ok, just how did you come to that conclusion??
hahahaha it's for a softer pedal, you really thought it was something else?
Dave
lol right!
Sent from my Galaxy S7 using Tapatalk
Old 05-16-2016, 03:42 PM   #30
lol right!
My slave cylinder started leaking because my clutch wasn't fully depressing.
Old 05-16-2016, 04:15 PM   #31
scott_0's Avatar
lol which had absolutely NOTHING to do with the clutch spring being removed, it was nothing more than a coincidence
Old 05-16-2016, 04:43 PM   #32
Oh...didn't realize you owned my car.
Old 05-16-2016, 06:50 PM   #33
And...you have an A6. Aren't you forgetting you only have a go pedal and a stop pedal? There is no gas assist spring.
Old 05-16-2016, 07:52 PM   #34
scott_0's Avatar
lol this is my first auto Mustang, NOT my first Mustang, my 2011 GT was an M6 with no spring for 3yrs, with no issues, guess they built them better back then huh?
Old 05-17-2016, 06:30 AM   #35
Senior Member
dgc333's Avatar
Not dangerous at all, just hook your toe under the pedal to check.
When I first heard folks claim the pedal didn't return all the way I started checking with my toe. I did it long enough to convince myself that it does return.
Dave
Now Available -Steeda S197 Mustang Clutch Spring Assist 95 lb/in (11-14 All) tj@steeda 2011-2014 Mustang GT 36 06-17-2016 10:46 PM
Steeda's S550 Mustang Clutch Spring Assist 35 lb/in - Now Available! tj@steeda 2015 Mustang GT 1 02-11-2016 07:37 AM
Wanted: Steeda sport spring and Steeda HD mounts paintmann111 Mustang Parts for Sale and Wanted 0 03-17-2015 05:03 PM
Spongy clutch after removing clutch assist spring. Fax22 2011-2014 Mustang GT 2 09-06-2014 10:19 PM
stock spring spring Scut95 1979-1995 Mustang GT 2 09-15-2005 04:11 PM
09:55 PM
