JLT Oil Catch Can for 2015/2016 GT - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 05-22-2016, 08:55 AM   #1
ZombieSlayer's Avatar
Hello everyone,
So I installed a JLT Oil Catch Can on my 5.0 around 200 miles. Now I have 1,500 miles and decided to open it to see if it needed emptied. And there is like.....no oil in it. lol
Is this normal? I know the car is new and all but I figured it would catch something. Unless these cars are that much more improved? On my 2014 3.7, I would get a bunch of oil every 1,000 miles.
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 05-22-2016, 10:18 AM   #2
Road Dog's Avatar
Nope, something's up
That is not normal. If you installed it correctly there should be oil in it the next day. It is not possible that your engine doesn't have oil vapors accumulating under that valve cover. They are going some where. Is the hose plugged?
2016 GT Vert, SB, AT, 3:55s Weathertech, JLT, Steeda, Colgan, Velossa Tech, Coyote Spacers, Diode Dynamics, Shelby GT350 SW, Curt, Goodridge, aFe, MRT, BMR, Kooks, Mishimoto
Road Dog is offline   Reply With Quote
Old 05-22-2016, 10:31 AM   #3
king_13's Avatar
Is it leaking? Is your car an auto?
2014 Oxford White 5.0 Premium
2015 Maroon Chevy Cruze LTZ
2011 Performance White V6 Premium SOLD
king_13 is offline   Reply With Quote
Old 05-22-2016, 10:49 AM   #4
Road Dog's Avatar
Check the driver side hose, I'll bet there is oil in that one.
Old 05-22-2016, 11:21 AM   #5
TTmustang10's Avatar
I have the catch can on my passengers side and after 200 miles there was a little in there.
JLT said they are making the drivers side soon.
Mine is an auto and just checked it again. The catch can is working.
TTmustang10 is offline   Reply With Quote
Old 05-22-2016, 11:26 AM   #6
It is installed and each side/clamp is secure. This is the passenger side catch can and my car is a manual.
There is a very light coating of oil at the bottom of the catch can. But nothing to really dump out.
Old 05-22-2016, 11:29 AM   #7
Check to see if they have any plugs in yours.
Engine shouldn't matter auto or standard.
Mine works just fine, they don't have drivers side available yet.
Old 05-22-2016, 11:47 AM   #8
Plugs? Like being clogged?
Old 05-22-2016, 11:51 AM   #9
Some times when I buy things they have plastic clips or plugs so dust and stuff don't get in the tubes type of deal.
Old 05-22-2016, 01:57 PM   #10
I took off the catch can and I don't see any items that need to be removed. There was a few droplets of oil covering the bottom so that tells me SOMETHING is moving through it.
I ran a pretty good amount of water through it and did not find any leaks or anything and it seems to flow ok throughout it. So maybe the car is not moving much oil at this time?
Old 05-22-2016, 02:15 PM   #11
oxford5pointoh's Avatar
I sure hope you dried that thing out good. You don't want it sucking in water/ condensation and putting that in your intake 😱
Old 05-22-2016, 02:21 PM   #12
I did. But is it safe to say the car and catch can is ok for now?
Old 05-22-2016, 02:43 PM   #13
Might explode. Good thing you got that extended warranty...oh wait never mind 😜
Old 05-22-2016, 02:46 PM   #14
My JLT catch can on the passenger side (A6 3.55's 5.0) has been in a little over 3,000 miles, and was installed at about 7,000 miles. I've emptied it every 1,000 miles, and each time there was about 3/4 of an inch of oil in it.
I would say something odd is going on with yours if it is catching no oil, or even nearly none.
For those here who have one of these on both sides.............does the driver's side catch can collect as much as the passenger side does?
Is it worth getting both?
EDIT:
JLT does not offer a driver's side separator for our engine..............odd.........maybe they will soon?
Old 05-22-2016, 05:34 PM   #15
Road Dog's Avatar
Some guys have modded their plumbing to allow the can to service both sides of the engine. I'm not entirely sure this is needed on the 6G. I will go out a trace the path of the Drivers side hose tonight. But I do know that there should be more than a film of oil in a properly installed catch can after over a 1000 miles.
Okay after looking at my 5.0 I know now that the Drivers side is an intake for the fresh air to enter the top of the engine. The tube runs to the valve cover from the air intake, there is no vacuum there because it's on the outside of the Throttle body. So no need for a second catch can.
Old 05-22-2016, 06:40 PM   #16
Road Dog..............nice to have someone here who is technically proficient. The lines must be different than the 2010-2014 engine, huh? They do offer driver's side separators for those engines.
VERY nice to know we don't need one ---- thanks!
Old 05-23-2016, 11:51 AM   #17
scurfie's Avatar
I have a JLT that is working. I've had it for about a year. I see that there's two types of filters that can be installed on the JLT. I have the silver mesh type. Does anybody use the cylinder screen? Should I switch to the cylinder version?
scurfie is offline   Reply With Quote
Old 05-23-2016, 12:36 PM   #18
Hey everyone,
So I removed the catch can and looked into the port/connection on the passenger side of the engine/valve cover and saw this inside. Not sure if this is some sort of check valve or something else.
On my 2014, I don't remember that being there.
I tried to get a normal picture and tried to use Flash to try and make it as noticeable as possible.
ID:	201437   Click image for larger version
Old 05-23-2016, 02:01 PM   #19
Well, whatever that little black valve thing is, it seems to be attached to whatever is in there. I tried looking around and I can't find any pictures, videos, or threads of anyone mentioning it. So I wonder if it is new? Unless someone can pop off their catch can and look inside the passenger side engine connection to confirm with me.
Old 05-23-2016, 05:14 PM   #20
Road Dog's Avatar
that is a valve mechanism, it is a one way system.
Old 05-23-2016, 05:19 PM   #21
Ok that is good. Puts my mind at ease. Thank you!
Old 05-23-2016, 08:01 PM   #22
king_13's Avatar
That's also present on my 14, I noticed it when I applied new thread tape last weekend.
Old 05-29-2016, 06:30 PM   #23
Drove another 300 miles and now the catch can is picking up a decent amount of oil.
So all set here.
Old 06-01-2016, 07:01 PM   #24
Road Dog's Avatar
Well thats the end of this thread. Congrats, you are now a normal GT owner.
Old 06-05-2016, 02:14 PM   #25
Blue302's Avatar
So all set here.
Zombie just to give you a comparison I've been logging the amount of oil in mine (JLT on passenger side only).
1091 miles, 2 mL
2280 miles, 2 mL
4650 miles, 4 mL
Blue302 is offline   Reply With Quote
Old 06-11-2016, 06:26 AM   #26
On my 2015 GT with auto trans I installed the JLT Oil Separator on the passenger side at 100 miles. The first time I checked it at about 2,000 miles it was about one third full.
billy396 is offline   Reply With Quote
Jlt catch can on supercharged v6 elkoritaNAY 2011-2014 V6 Mustang 5 01-05-2016 07:53 AM
JLT Oil separator -catch can b2673ad 2011-2014 V6 Mustang 83 06-14-2015 06:00 PM
Jlt oil catch can Matts14fp6 2011-2014 V6 Mustang 7 02-14-2015 10:29 PM
For Sale: JLT oil catch can 11-14 v6 Whitelightning Mustang Parts for Sale and Wanted 3 12-16-2014 02:03 PM
For Sale: BBK 73mm throttle body and JLT catch can for '14 3.7 mustang dlm Mustang Parts for Sale and Wanted 11 12-12-2014 07:15 PM
09:20 PM
