Odd noise from the stereo speakers when I open the door. - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 06-02-2016, 10:10 AM   #1
This only happens when the car has been sitting for more than a couple of days......
When I open the driver's door, there is a very low frequency "VFVFVFVPHPH"......sound that comes out of the driver's door speaker. It only last for about half a second. REALLY an odd sound.........and I am betting that perhaps I am the only one?
Old 06-02-2016, 10:22 AM   #2
Strange Mud's Avatar
hinge noise? does it stop if you just crack the door?
makes more sense than spkr noise
Old 06-02-2016, 10:43 AM   #3
Yeah, I thought about hinge noise too.....but from everything I can tell, it's the driver's door speaker that hums this noise, and it happens even if I only open the door a little bit, or open it quickly all the way..............strange, right?
The noise is really low frequency -- and if it was the hinge, I think it would happen all the time -- but this is only when it's been sitting for more than a day or two.....
Old 06-02-2016, 10:50 AM   #4
hit the hinge with wd-40 simple no harm test.
rust from sitting?
Old 06-02-2016, 11:00 AM   #5
Jbone007's Avatar
Do you have the Power Subs in the Doors? May be issue with one of the Amps if you do.
Jbone007 is offline   Reply With Quote
Old 06-02-2016, 11:27 AM   #6
rust from sitting?
Covered in the garage -- likely not rust.........but I'll try the WD40 test as well....you can even feel the vibration in the rest of the door when it does this.
There are power subs in the door for the Premier option?
Old 06-04-2016, 05:24 AM   #7
RBK
I have a 2012 with the shaker audio and occasionally when I first turn on the radio I get a sound, like static, out of the base speaker in the drivers door. It stops after about 10 seconds and is fine after that. I removed the speaker and all the connections seem fine so I'm at a loss as to what causes it.
RBK is offline   Reply With Quote
Old 06-04-2016, 05:37 AM   #8
Mstablein's Avatar
Most likely when the accessory power is coming on and your head unit powers up.
2015 GT Premium Triple Yellow
Niche Essen Staggered
Paxton Supercharged
Borla ATAk cat back
Mstablein is offline   Reply With Quote
Old 06-04-2016, 08:03 AM   #9
Thanks for all of the replies, guys...........I am sure it is nothing serious, just WIERD!
And the sound is more of a VVMMMMPH, and again lasts only a 1/2 a second.....
Odd transmission (?) noise after repair tym_v6 2011-2014 V6 Mustang 89 10-22-2015 10:36 AM
car making odd noise nymustang 2005-2010 V6 Mustang 0 01-01-2015 12:18 PM
removing mach460 amps/speakers, running new amp to door speakers with stock wiring? paradigm 1996-2004 Mustang GT 0 07-31-2013 04:04 AM
Odd noise and RPM issues. 96smoke 1996-2004 Mustang GT 10 07-05-2013 09:37 AM
Need help with stereo and speakers. 94 GT 5.0 SVT Mustang 2 06-24-2013 04:00 PM
11:57 AM
