Swapped Out Air Intake - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 06-03-2016, 11:34 AM   #1
ZombieSlayer's Avatar
So as a few of you might know, I just recently went through a big layoff at my previous job. So money is tight right now but the mod struggle is real.
I wanted to swap my intake but I wanted to keep it tasteful and not be messy. I also could not afford a $350 kit.
So the items for my project included...
Airaid Modular Intake Tube - Picked this up for $140
AEM Dry Intake Filter - $50
Blowfish Sound Tube Delete - $10
Sanding Paper - $1
Strong glue that worked on plastic - $4
Cutting utility - Already had this
So the normal intake tube has the accordion piece for flexibility (maybe other things but who cares). The normal intake tube also has a baffle underneath it. Also, the air inlet duct has another huge baffle on it. Not to mention the sound tube being annoying.
So my ultimate goal was to give the air more of a straight shot through the intake and delete the sound tube.
I cut off the baffle on the air inlet. Sanded the small circular area down. And Capped it off with a durable piece of plastic.
Then I replaced the stock intake filter.
Afterwards, I was going to remove the entire sound tube. But I only removed the first half and capped off both sides. The Airaid tube came with a sound tube cap, and I used the blowfish sound tube delete on the sound tube itself. This way, if I ever want to add it back, I only have to plug in the first half instead of trying to get my hand behind the engine. Which on the 2015-2016, is a tight fit.
Plus the 2nd half of the sound tube has 2 mounting points that is still connected so it is very secure.
The final part was replacing the Intake tube itself.
All in all, took my 1 hour for everything.
Now my experience after the install. And I have driven it for 2 days now. Throttle response is better and smoother. Used to, the car would choke a bit when trying to take off in 2nd gear. Unless I gave it plenty of gas. And this is with 3.73s.
Now, taking off in 2nd is very smooth. I use this now instead of 1st gear usually.
The car just feels more responsive now throughout the entire low range. Definitely worth the $205 spent.
Now, I don't hear the swooshing sound of the intake. Because I am still using the stock intake box (I wanted a covered intake anyways). But now I don't hear the fake noise from the sound tube so I can enjoy listening to what the V8 really sounds like and the exhaust.
I had my wife rev it yesterday and the exhaust sounds just a hair deeper and just a hair louder. The normal person wouldn't notice but since I have driven the car throughout all of its changes so far, I can notice. And I get a nice deep POP if I rev it high enough. Which I did not get before. drive-by anyone?
Name:	5.0 engine.jpg
ID:	201904   Click image for larger version
Name:	Airaid Intake Tube, AEM Filter, and Sound Tube Delete Installed.jpg
Name:	Air Inlet Baffle Removed.JPG
ID:	201906   Click image for larger version
Name:	Intake Finished.JPG
2016 Mustang GT: Guard Metallic w/ manual transmission; Performance Pack and Backup Sensors
ZombieSlayer is offline   Reply With Quote
Old 06-03-2016, 11:47 AM   #2
oxford5pointoh's Avatar
The 10.00 blowfish sound tube delete is about the only thing I see worth doing in this entire setup IMO
Old 06-03-2016, 11:55 AM   #3
I appreciate all the love! lol
This small project did accomplish all of my goals though that involved the air intake. So I am happy.
Old 06-03-2016, 12:06 PM   #4
That's all that matters. I'm glad you are happy 👍🏻
Old 06-03-2016, 12:15 PM   #5
It's not a bedazzled GT350 intake but it will pass?
Old 06-03-2016, 12:16 PM   #6
Hmm, seems the final pic is showing corrupt on the mobile app and desktop site. Gonna repost it just in case.
Name:	ImageUploadedByMustang Evolution1464977782.353864.jpg
Old 06-04-2016, 03:54 AM   #7
0440thgt's Avatar
Wow these new 5.0s have a really small panel filter in them don't they?
Glad you are happy with your intake.
0440thgt is offline   Reply With Quote
Old 06-05-2016, 12:13 PM   #8
TTmustang10's Avatar
Forgive me but what is the sound tube for ? I see it's connected to the CAI and know it's hard to get the firewall bolt out.
The sound tube delete does what? For cabin pressure ?
TTmustang10 is offline   Reply With Quote
Old 06-05-2016, 01:00 PM   #9
DiESeven's Avatar
Ignore the bolt and just yank it out. That's how I got my friend's sound tube out. The plastic tab that holds the sound tube to the bolt will flex enough for it to come right off.
Old 06-05-2016, 01:06 PM   #10
What's the purpose of it ? Just to get engine noise to the cabin ? Reduce noise ?
Old 06-05-2016, 01:10 PM   #11
It's to get rid of that fake loud engine/intake noise that pumps into the cabin. So you can hear the engine and exhaust better.
Swapped V8 out from my V6 -~$7.5k ArtU 2011-2014 V6 Mustang 47 03-23-2014 04:55 PM
Post a vid of your swapped out stang Varasios 1979-1995 Mustang GT 0 10-07-2013 05:15 AM
94gt factory cold air intake vs aftermkt cold air intake justjake94boss 1979-1995 Mustang GT 1 04-15-2012 11:22 AM
Can't find the squeeking! 65 Mustang w/swapped out V8 par65 Classic Mustangs 6 05-29-2010 10:30 PM
waterpump gettin swapped out today Zim 1979-1995 Mustang GT 4 10-03-2005 07:29 PM
07:54 PM
