Lowering springs question - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 06-07-2016, 07:33 AM   #1
drivinglesson's Avatar
Hi all, I am getting ready to order to some springs, and I was wondering if I need caster camber plates on these S550 Mustangs? In the past it was necessary, but I don't hear too many people doing it any more. I am looking at a one inch drop.
2016 Mustang GT
drivinglesson is offline   Reply With Quote
Old 06-08-2016, 05:06 AM   #2
Philly2304's Avatar
I have Steeda progressive springs. They are approximately a 1 inch drop all the way around. The springs are awesome. Much improved ride and great aggressive look. I have know camber plates. The camber can be set within factoy specs. Just get an alignment after the install. Talk to TJ from Steeda. He is on the forum. He is a great help. Good luck.
Philly2304 is offline   Reply With Quote
Old 06-09-2016, 07:59 PM   #3
Road Dog's Avatar
It has been done by a lot of guys when they do the spring install. It is a toss up whether or not your car will align easily without them or not. My observation is the guys that buy the caster/camber plates to add along with new springs are the track/autoX crowd who need the flexibility that comes with the plates. So it's up to you, what are you going to do with the car?
2016 GT Vert, SB, AT, 3:55s Weathertech, JLT, Steeda, Colgan, Velossa Tech, Coyote Spacers, Diode Dynamics, Shelby GT350 SW, Curt, Goodridge, aFe, MRT, BMR, Kooks, Mishimoto
Road Dog is offline   Reply With Quote
Old 06-09-2016, 09:15 PM   #4
tj@steeda's Avatar
The Steeda Difference: S550 Camber Plates | Steeda Blog
Here is a great article on our caster camber plates that will show the Steeda difference.
We have a lot customer running them that are both lowered & tracking their cars ...
Our Steeda S550 camber plates are made right here in the USA and are great for both street and track use. Our camber plates come into play especially when lowering your vehicle. With the addition of our new adjustable strut mounts on your lowered S550 you will be able to correct excessive negative camber and increase your front steering response. If you lowered your daily driven S550 Mustang, running the correct camber will eliminate uneven tire wear.
Shoot me an email with your future plans & I can speak to our build expert as to when you should implement them.
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
tj@steeda is offline   Reply With Quote
Old 06-10-2016, 07:16 AM   #5
ponie1992's Avatar
You can also get camber bolts instead of plates.
Jeremy
2016 Ruby Red PP GT
Jeremy
2016 Ruby Red PP GT
ponie1992 is offline   Reply With Quote
Old 06-10-2016, 07:40 AM   #6
Dog,
Thanks for your input, I really appreciate your advice. It's been about 15 years since I've autocrossed, but I still like having my cars setup for spirited driving... One is never too old for that. This is a daily driver for me, and I am mainly looking to drop it down an inch or so for looks and improved cornering; I am not a straight line guy.
2016 Mustang GT
Old 06-10-2016, 07:48 AM   #7
TJ,
Thanks for your input, I will take a look at your article. Unfortunately, I had some bad luck with Steeda parts, so I don't feel that I can use your produts. No bad feelings, I just would rather purchase a different brand.
2016 Mustang GT
Old 06-10-2016, 07:49 AM   #8
Jeremy,
That is interesting, I will look into that. Thank you for your input.
2016 Mustang GT
Old 06-10-2016, 08:23 AM   #9
scott_0's Avatar
all cars are different, some cars will have more negative camber after lowering, some will have less, my car was close to 2 degrees negative after installing my BMR performance springs 1.2" front drop, I couldn't have gotten the car in spec without installing my maximum motorsports cc plates, some will recommend camber bolts, I for one, do not trust them
Sent from my Galaxy S7 using Tapatalk
Old 06-10-2016, 08:24 AM   #10
ponie1992's Avatar
Jeremy,
No problem. I have BMR performance springs and the BMR camber bolts. I believe these springs drop the front just over an inch. No issues reported from using the bolts from my alignment guy. He's been doing this for I think 30 some odd years.
Jeremy
2016 Ruby Red PP GT
Jeremy
2016 Ruby Red PP GT
Old 06-16-2016, 08:04 PM   #11
I am looking at the eibach sportlines. Will I need camber plates or just the camber bolts
Sent from my SAMSUNG-SM-N910A using Mustang Evolution mobile app
tkhoury77 is offline   Reply With Quote
Old 06-16-2016, 08:22 PM   #12
I decided on the on caster camber plates and the sport lines.
2016 Mustang GT
Old 06-17-2016, 07:38 AM   #13
tj@steeda's Avatar
Appreciate your feedback & if you would like to give me the backstory ... I would be happy to share with my leadership team - always trying to make things right.
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Old 06-17-2016, 09:17 AM   #14
Appreciate that TJ. I had purchased two Tri-Ax shifters for two different cars, an 03 Cobra and '11 GT. I felt that both were worse than stock, and ended up going with a Pro 5.0 on the Cobra, and a MGW on the '11 GT. I feel like it's an engineering issue, and I also fell like I gave Steeda a second chance.
To be fair, Steeda's customer service was awesome when I called them, they offered to replace them. That's not my style; I shot both shifters and their remains lay on my desk at work. I have them there as a reminder to my guys that if they perform substandard, I'll shoot them.
2016 Mustang GT
Old 06-17-2016, 09:39 AM   #15
tj@steeda's Avatar
Interesting feedback - most of the customers I speak with find the Tri-Ax to be a tremendous upgrade over their stock uni - completely understand your point & thank you for providing your feedback.
If in the future, you want to give us another shot ... you can email me at tim@steeda.com. I am positive, no other part will remain shot up & laying on your desk!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
Lowering springs/shocks and struts Question mustangmar2001 1996-2004 Mustang GT 4 01-05-2013 08:06 AM
Question on lowering springs Warbot 1996-2004 Mustang GT 23 11-21-2012 07:03 PM
Lowering springs or factory springs fordracing63857 1979-1995 Mustang GT 3 06-27-2012 08:42 PM
question about 02-04 gt lowering springs th3famous1 1996-2004 Mustang GT 11 11-15-2008 12:28 PM
FRPP Lowering Springs - G Springs Stangthang Pre-2005 V6 Mustang 9 02-23-2005 03:57 PM
06:45 PM
