New Product Release - Steeda's S550 Pro Action Shocks & Struts - Now Available! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 06-08-2016, 09:51 PM   #1
tj@steeda's Avatar
Hello All!
Searching for the ultimate combination between ride quality and performance for your 2015-2016+ S550 Mustang? Look no further than our Steeda Pro-Action shocks and struts. These dampers feature street and track-proven technology which have been methodically tested and tuned to achieve optimum compression valving, giving you that quick sports car reaction on the road with easily adjustable rebound damping at the twist of a knob. From soft and comfortable to stiff and aggressive, these Pro-Action shocks have more adjustability than you will ever need!
Steeda S550 Mustang Pro-Action Shocks and Struts (15-16 GT/V6/EcoBoost) | 555-8147
Key Benefits:
- Steeda proprietary shock valving
- Specifically designed for lowered S550 Mustangs
- Rebound adjustable for the ultimate in tunability
- Reduce wheel hop, squat, body roll and body oscillation
- Less damper friction, less sideloading on the shafts, lower internal pressures
- Huge range of tire, wheel, and spring fitment combinations backed with Steeda’s limited warranty
Incorporate your stock or aftermarket spring package to these adjustable dampers for the perfect ride quality. Eliminate the choppy stock ride, reduce dive, squat and body roll, and eradicate wheel hop once and for all! Steeda’s Pro-Action dampers are the highest quality twin tube dampers on the market, and include a separate compression piston internally to give you the same compression force as a standard damper with significantly less gas and internal pressures - this means less internal stress on the components, less friction, more repeatability and a lighter overall package! Coupled with our extremely strong steel housing, our twin tube setup provides bulletproof reliability, lower bending loads on the damper shafts and increased performance! As always, our kit is backed by our Steeda limited warranty.
This robust system was design to keep your options open. Tire fitment starts at 295 in the front and can go as high as 315 in the front with the correct offset, while 315’s fit easily on the rear. With this range of setup options these, dampers are perfect for daily drivers, road racers and drag racers alike.
We will also offer just the fronts and just the rears, stay tuned! Switch to the Steeda Pro-Action shocks and struts for the pinnacle of performance, ride quality and reliability!
In stock and ready to ship! Steeda S550 Mustang Pro-Action Shocks and Struts (15-16 GT/V6/EcoBoost) | 555-8147
Best Regards,
TJ
Steeda Autosports
Valdosta, GA & Pompano Beach, FL
Mustang Performance Products
Private Message Me About Special Discount Codes
www.steeda.com
Win A $300 Gift Card
tj@steeda is offline   Reply With Quote
Old 06-14-2016, 10:22 AM   #2
tj@steeda's Avatar
Hello Guys & Gals - these are moving very nicely & have had some happy customers already install them on another forum.
Let me know if I can assist with any questions or concerns you may have!
Best Regards,
TJ
Steeda Autosports
www.steeda.com
New Product Release - Steeda S550 Mustang NHRA Legal Driveshaft Safety Loop (15-16 Al tj@steeda 2015 Mustang GT 0 05-13-2016 10:40 AM
New Product - Steeda S550 Heel/Toe Pedal and Covers Now Available! tj@steeda 2015 Mustang GT 8 03-25-2015 08:43 PM
Steeda Adding More S550 Parts Weekly - Steeda S550 Mustang Rear IRS Subframe Support tj@steeda 2015 Mustang GT 0 03-21-2015 09:52 AM
New Product - Steeda S550 Adjustable Rear Toe Links (2015 All) - Now Available! tj@steeda 2015 Mustang GT 0 03-11-2015 11:46 AM
Save 10% on Steeda Pro Action Shocks & Ultra Lite Springs tj@steeda 2011-2014 Mustang GT 1 11-10-2013 08:25 PM
09:25 AM
