Anyone else try NT555 G2 tires? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 07-07-2016, 03:01 AM   #1
TigerStang's Avatar
Region: Rhode Island
I just ordered a pair of these for my rear tires, wondering if they're going to live up to the hype Steeda gave them.
I really wanted NT05 tires, but when I requested 275/40R19 Nitto told me to pretty much get bent
Sent from my SAMSUNG-SM-G920A using Mustang Evolution mobile app
TigerStang is offline   Reply With Quote
Old 07-07-2016, 07:09 AM   #2
showsomeskin's Avatar
You can go bigger I have 305/35/19 nt05
showsomeskin is offline   Reply With Quote
Old 07-07-2016, 07:52 AM   #3
TigerStang's Avatar
On stock PP wheels with guaranteed no issues with warranty?
Old 07-07-2016, 07:52 AM   #4
Yes sir
Old 07-07-2016, 07:54 AM   #5
The nt05r is in my opinion the best street/strip tire on the market. Well worth the money
Old 07-07-2016, 08:18 AM   #6
JimC's Avatar
I have the 555 G2. Good street tires. Not enough grip though for the drag strip compared to drag radials.
Sent from my SM-G930P using Tapatalk
JimC is offline   Reply With Quote
Old 07-07-2016, 09:55 AM   #7
TigerStang's Avatar
Ok cool, I'll ask them about the tires Wednesday then, ty
Old 07-08-2016, 03:47 PM   #8
Did you find out more about your tires?
Old 07-08-2016, 05:17 PM   #9
TigerStang's Avatar
Yeah I did, they pretty much told me no matter what I do, unless I bought the factory and size pirelli zero tires, I am going to pay for any repairs directly caused by the new tires...
BS if you ask me, but the 555 tires were already on order when I posted so I'm stuck with them
Old 07-08-2016, 06:34 PM   #10
jeno's Avatar
I'm running the 555 g2 all around 315 in the rear they work very well
Sent from my SM-N910T using Mustang Evolution mobile app
jeno is offline   Reply With Quote
Old 07-09-2016, 07:57 AM   #11
TigerStang's Avatar
Jeno
The issue I'm trying to eliminate here with tires is wheel hop, my 98 never did it, why should my dream car do it lol
Old 07-09-2016, 09:54 AM   #12
jeno's Avatar
Tigerstang have you looked at your suspension for wheel hop I definitely do not have any most of the time wheel hop is suspension related
Old 07-09-2016, 10:59 AM   #13
TigerStang's Avatar
Yeah, I've got a few more pieces to buy to eliminate it, but my stock tires are worn now, so I wanted to replace those first
Old 07-09-2016, 12:04 PM   #14
jeno's Avatar
Tire's no matter what but beef up that suspension to get rid of wheel hop
Old 07-09-2016, 01:05 PM   #15
TigerStang's Avatar
Already did the Steeda bushing support system and the differential bushing kit, next on my list is the subframe connector kit that bolts to the differential cradle
Old 07-09-2016, 02:16 PM   #16
In my case tires helped wheel hop more than any of my other parts. I did the tires first thing after the supercharger
Sent from my IPhone at 120mph in 3rd@10psi
Old 07-10-2016, 05:34 AM   #17
TigerStang's Avatar
Originally Posted by showsomeskin View Post
I my case tires helped wheel hop more than any of my other parts. I did the tires first thing after the supercharger
And I've heard that more often than not, so if the 555 G2 doesn't work out, I'll buy the NT05s in your size next
Old 07-11-2016, 06:28 PM   #18
Honestly the Michelin as3+ will out perform this tire. It's a good tire, and I actually tested them prior to the release date, but at the end of the day...it's a nitto and it's not that great.
The nt05 is a good tire if you don't mind only getting about 5k miles before they sound like plastic tonka truck tires.
Doyal_McNeff is offline   Reply With Quote
Old 07-11-2016, 06:31 PM   #19
Noodles76's Avatar
I just ordered a staggered set. Should have them on by next week.
Noodles76 is offline   Reply With Quote
Old 07-12-2016, 02:39 AM   #20
TigerStang's Avatar
Still waiting for mine to show up as well, I'll be sure to post my b review after a few days of use
Old 07-12-2016, 06:23 PM   #21
Noodles76's Avatar
How would tires cause damage to your vehicle? Sounds like they want you to buy from them.
Old 07-12-2016, 07:49 PM   #22
TigerStang's Avatar
Added grip means more torque on your half shafts, differential, etc. Expensive pieces I don't want to pay for
Old 07-13-2016, 03:29 AM   #23
Noodles76's Avatar
Is it a stock engine? I don't see a stock motor with a bigger set of this causing damage to those parts. But maybe I'm wrong.
Old 07-13-2016, 04:39 AM   #24
TigerStang's Avatar
Bone stock, not even a tune. But since when do you buy a car with a warranty, if you don't think anything will ever break?
I don't think the axles will break the first time I launch the thing, but I don't need to give them excuses for me to be paying 700/mo for a broken car...
Call me a little more paranoid than most, but I don't have $2000 sitting around for the Ford racing axles.
Any dealer you go to will tell you the same verbiage, but it's clear as mud. "If the modification directly causes the damage, the effected parts will be repaired at cost to the customer"
Technically, even just putting in bushings could "directly cause the damage" even though if anything, stiffening the rear suspension for wheel hop elimination will result in LESS hard torque to the axles due to them not constantly getting snapped tight and loose again.
You know?
Old 07-13-2016, 04:54 AM   #25
Strange Mud's Avatar
as far as wtty fears (paranoia) If your dealer covers a bone stock car under wtty you've got a good one.
fwiw I do my own service (except wtty stuff) but I make it a point to go in and buy oil filters from the dealer I would bring it to for wtty work and I say "hello" to sales & service every time to make them my friends. A good bit of wtty work is determined the relationship between you and the dealer.
side note: just under one week left of my 5yr/60K powertrain wtty.
Old 07-13-2016, 06:37 AM   #26
TigerStang's Avatar
I purposefully bring it to them myself for oil changes. Now tires, etc. I'll probably end up doing my own brakes, but I have good rapport with the sales manager. But his workers change like every time I'm in there. I also do double the amount of maintenance required lol every 5000 miles, not every 10 and yes I too did a break in oil change
Old 07-15-2016, 06:22 AM   #27
TigerStang's Avatar
Update:
Tires went on yesterday, and at first impression, I'm not very impressed. There's a huge noticeable difference in contact patch, but the pirelli zeros had a much stronger sidewall. Personally, I like that in a tire... we drive 3800lb cars, you gotta have a solid sidewall.
The Nittos ride pretty smooth, they are quiet but idgaf about noise, I don't drive a Mercedes for a reason... they look a lot more aggressive than the pirelli, but I feel like the pirelli was a lot more stable side to side.
One thing I will say though, is that the Nittos have really solid straight line grip. Feels like a lot less parasitic loss to the wheels. But personally, I care about lot more about cornering. I hope after a few hundred miles the tires will stiffen up some on the sides and ride a lot straighter. Will post updates later
Old 07-15-2016, 07:05 AM   #28
jeno's Avatar
Update:
Hmm mine grip like nobody's business straight line and in the corners too maybe yours need to broken in a little
Old 07-15-2016, 07:10 AM   #29
jeno's Avatar
Hmm mine grip like nobody's business straight line and in the corners too maybe yours need to be broken in a little
Old 07-15-2016, 07:56 AM   #30
What is the P.S.I set at?
Old 07-15-2016, 08:27 AM   #31
TigerStang's Avatar
36psi all the way around
Old 07-15-2016, 05:35 PM   #32
Update:
You get what you pay for. Nitto's are not a track tire. All nitto's except the nt05 have soft side walls.
Old 07-15-2016, 07:10 PM   #33
TigerStang's Avatar
So would you recommend spending the money on the Michelin super sports?
Old 07-15-2016, 07:34 PM   #34
I purchased a pair of nt05's because I wanted to save money, and 4 weeks later I bought mpss's. So...I ended up spending way more than I originally would have if just got the mpss to begin with. At the end of the day, they're about $300 more for the set, but it's a phenomenal tire.
I actually recently purchased some Michelin pilot sport a/s 3+ tires and they grip just as well as the mpss in a straight line. The side wall isn't as stiff, but its much better than every nitto street tire except the nt05.
Old 07-16-2016, 04:56 AM   #35
TigerStang's Avatar
Good to know. Everything I saw online was "the Nittos are so loud" I personally don't care about noise and comfort in a tire.
My problem is, the NT05 doesn't come in 275/40R19. The dealership is looking into if it's gonna mess anything up if I go to 305/35.
I know mechanically, nothing will be severely affected, BUT the S550 GT Performance package comes with specially tuned EPAS, stability control and traction control. If changing what the electronics are supposed to read messes with the system, it's a good possibility you could actually LOSE handling performance.
There are only 3 tires out there as far as I'm concerned worth a damn in my size.
The pirelli zero
Nitto's NT555 G2.
I'll probably be replacing the 555 G2 before they wear out and I'll just sell them and buy the Michelin and try them.
Wanted: NT555 used Tires houston arturo55 Mustang Parts for Sale and Wanted 1 06-27-2013 01:02 PM
trade/sell 20" lorenzo wl19 nitto nt555 tires BigHead2010 Mustang Parts for Sale and Wanted 6 02-13-2013 06:14 PM
Nt555 Doe_Rae_mi 1996-2004 Mustang GT 15 12-09-2012 04:56 AM
nitto nt555 Ballard281 Mustang Wheels & Tires 6 04-07-2012 01:17 AM
2 Brand new Nitto NT555 tires for sale... DFW area !!! xtremejc Mustang Parts for Sale and Wanted 1 11-06-2007 06:20 AM
10:47 AM
