Camber question - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 07-10-2016, 01:57 PM   #1
Philly2304's Avatar
Camber question
With Steeda progressive springs and no camber plates, can I get 20 in wheels with 255/35/20s on the front and 295/35/20 on the back. The front wheels have a 32 mm offset and the back has a 45mm offset. Do I need camber plates or can I just get an alignment?
Philly2304 is offline   Reply With Quote
Old 07-10-2016, 04:46 PM   #2
Road Dog's Avatar
What is the width of the wheels you plan to use on the front?
I have heard of 10.5" wide with less offset than what you mention.
The tire size you mention shouldn't give any issues, its the width and the offset that are the issue. In any case if you have the wheels already. Mount one on the car without the tire and check for the clearance of the brake caliper, and the strut.
2016 GT Vert, SB, AT, 3:55s Weathertech, JLT, Steeda, Colgan, Velossa Tech, Coyote Spacers, Diode Dynamics, Shelby GT350 SW, Curt, Goodridge, aFe, MRT, BMR, Kooks, Mishimoto
Road Dog is offline   Reply With Quote
Old 07-10-2016, 07:47 PM   #3
Philly2304's Avatar
The front wheel is a 20x9 and the back is 20x10.5. It says it has a backspacing of 6.26 in the front and 7.52 in the rear. I don't what that means though. I don't have the wheels yet. I just want to make sure before I buy them.
Old 07-10-2016, 08:17 PM   #4
Road Dog's Avatar
Those wheels should fit fine and won't give you any issues provided they clear the front brake calipers. If they are listed as fitting the S550 Mustang you shouldn't need to realign the car nor will you need caster/camber plates.
Here is a diagram explaining the wheel dimensions:
Old 07-10-2016, 08:38 PM   #5
Philly2304's Avatar
Thanks Road Dog. It's good to get educated on this stuff. I am pretty knowledgeable under the hood but I could really use some suspension help. Thanks again.
Camber plate question Staytru06 General Mustang Discussion 0 01-27-2014 03:41 AM
Camber Bolt Question KARgt13 2011-2014 Mustang GT 9 04-30-2013 08:22 PM
Camber Bolt Question. Mustang 4pt0 2005-2010 V6 Mustang 0 04-21-2013 12:59 PM
Caster Camber Plates or Camber Bolts OutlawGT 2005-2010 Mustang GT 18 04-05-2012 04:55 PM
Camber plates question Venomouz831 Pre-2005 V6 Mustang 17 12-18-2011 03:03 AM
03:01 AM
