New owner - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 07-15-2016, 08:50 AM   #1
New owner
Any one know what all you have to purchase for 4.10 upgrade on a 2015 Mustang GT from a 3.13 gear, other than ring , pinion, install kit... do I need to get a new traction lok or will the stock one in place suffice?
Mark Marley is offline   Reply With Quote
Old 07-15-2016, 09:18 AM   #2
Is it an auto?
Old 07-15-2016, 10:42 AM   #3
New Owner
Yes it is an automatic 6 speed
Old 07-15-2016, 10:55 AM   #4
New owner
It'll be slower. The 3.15 is perfect for the auto. Put a good converter on it.
Old 07-15-2016, 02:43 PM   #5
What is a good converter for the auto?
pike1346 is offline   Reply With Quote
Old 07-15-2016, 04:19 PM   #6
Street or strip?.......and if you go too high and don't run the right tires for traction when you launch, you will have wasted the $$'s on the converter.
First gear and second gear in the A6 are extremely low, which is why folks are telling you that 4.11's are too deep. To test this, turn off your traction control, shift into gear and power brake with your current gears for just a second, and then release the brake while you floor it.........you will go up in smoke literally standing still. So, if you leave your TC on with a high converter and the rest of your current setup the same, all you are going to do is work your TC harder -- to almost no advantage.
I would not go any deeper than a 2,500 rpm stall converter.....and even then you are going to need a very good, sticky drag slick......and hardened half shafts too.
Guard 5.0 is online now   Reply With Quote
Old 07-16-2016, 07:22 AM   #7
Grabber Blue5.0's Avatar
The auto carriers with 3.15's are to small to do any gear change. You would need to purchase a whole new carrier and would also have to buy the Whipple flare tool to make the appropriate change in the BCM or the car won't run.
Also there are no 4.10 carriers available for the new 2016+ Mustangs.
Changing the gears from anything over the stock 3.15's would be pointless and money just thrown down the drain from a performance standpoint.
Old 07-16-2016, 07:24 AM   #8
Circle D. Don't go with anything less than a 3600 stall.
New owner and new to forums timle8n1 New Member Introductions & Greetings 0 11-05-2013 02:19 PM
New guy/new stang owner 93 lx Houston, tx bjeff2007 New Member Introductions & Greetings 11 02-13-2013 11:18 AM
New owner from Rockland County New York Jeffola New Member Introductions & Greetings 10 08-29-2011 07:51 PM
New member, not a new owner Ripastanky New Member Introductions & Greetings 7 01-07-2011 02:18 PM
not a new owner, just new to this forum sdsguy New Member Introductions & Greetings 11 05-21-2008 10:59 AM
09:40 AM
