Does putting the transmission in Sport mode change the traction control? - Mustang Evolution
Go Back   Mustang Evolution > 1979-2015 Mustang GT || Tech and Talk > 2015 Mustang GT
Old 09-20-2016, 11:16 AM   #1
I put the trans into "S" mode last night before taking a gradual corner (just a little sharper than an S curve) aggressively in second gear. When I hit the throttle, the car snapped sideways more and more quickly than I have ever seen it do before.
I was able to counter steer and back out of the throttle, but the car surprised me when it did this. I really felt like if I'd stayed in the throttle the car would have swapped ends.....
I have turned off the traction control before and seen how easily it spins the tires, but did not touch the traction control toggle this time other than having the trans in "S".
As stated in the title --- does the "S" trans setting remap the traction control?
Old 09-20-2016, 01:59 PM   #2
Sterlingbeast5.0's Avatar
I believe S on Auto just means you can manually shift up and down with the buttons on the side of the shifter. I dont think it changes anything else. Dont quote me though going off girlfriends I have a manual
Old 09-20-2016, 02:41 PM   #3
oxfordwhite's Avatar
Was it damp outside Guard? I ask because that has happened to me also a couple of times when it was damp or wet when using S mode. Waiting for more replies.
oxfordwhite is offline   Reply With Quote
Old 09-20-2016, 03:21 PM   #4
VTHokiez's Avatar
It's my understanding that Sport mode allows more YAW prior to engaging traction control, hence the reason you're losing the back end easier. Track mode allows even more.
VTHokiez is offline   Reply With Quote
Old 09-20-2016, 03:49 PM   #5
This is the 2015 section, what you are talking about is select shift on the 13-14.
Old 09-20-2016, 05:29 PM   #6
Sorry bout that mt bad
Sent from my SM-G930P using Mustang Evolution mobile app
Old 09-20-2016, 06:03 PM   #7
Not damp --- but the temps were in the lower 50's. I have the standard 18" Pirellis so if they get this slick (like super high performance tires are known to do) when cold, that would surprise me...............
Old 09-20-2016, 06:06 PM   #8
Yes, I know that the various options in the dash for suspension adjustment operate that way --- but I am wondering if moving ONLY the transmission selector into the "S" setting does the same thing.
Old 09-20-2016, 06:21 PM   #9
C013RA's Avatar
Were you stopped when you put it in Sport mode? I am thinking maybe if not it suddenly went into it. BTW they make an after market paddle shifter kit for that.
little blurb from Ford on that; https://owner.ford.com/how-tos/vehic...nsmission.html
Had 6 Mustangs. I now have a 2016 GT350. I don't see myself getting anything else now. Only mods are a resonator delete, and a GT350R wing. I love the power, and the handling. Prior to that I had a 2015 Performance Pack GT with the MT82 and a lot of mods, a 2012 GT/CS with the 6R80. To me that was a mistake. Only Mustang I ever had with an auto. Before that a 2001 Premuim GT with lots of mods. Before that a 2000 V6 My 1st Mustang mistake. Should have stuck with V8's. Before that a 1965 convertible also with a lot of mods.
C013RA is offline   Reply With Quote
Old 09-20-2016, 08:09 PM   #10
c_rizzle's Avatar
S-197 / 2013-2014 - S mode makes the transmission shift more aggressively hold gears longer, which in turn gives you more power to break the wheels loose. I do not believe it affects the Traction control at all. I drove my 2014 almost exclusively in S mode for the more responsiveness, but never bothered with the +- for manually changing gears.
c_rizzle is offline   Reply With Quote
Old 09-20-2016, 11:11 PM   #11
I was moving when I put it into "S" mode......and our cars come with paddle shifters......didn't touch those.
Old 09-21-2016, 02:50 PM   #12
Road Dog's Avatar
Here's what Ford Says
Sport (S)
Putting your vehicle in sport (S):
• Provides additional engine braking and extends lower gear operation to enhance performance for uphill climbs, hilly terrain or mountainous areas. This will increase engine RPM during engine braking.
• Provides additional lower gear operation through the automatic transmission shift strategy.
• Provides gear selection more quickly and at higher engine speeds.
Nothing in there about turning off electronic safety systems.
So it seems you were Hooning and didn't know it.
2016 GT Vert, SB, AT, 3:55s Weathertech, JLT, Steeda, Colgan, Velossa Tech, Coyote Spacers, Diode Dynamics, Shelby GT350 SW, Curt, Goodridge, aFe, MRT, BMR, Kooks, Mishimoto
Road Dog is offline   Reply With Quote
Old 09-23-2016, 11:36 AM   #13
I have been trying to compare the transmission setting in "D" to "S" on the same corner, in the same gear at the same speed.
The corner is a very tricky one that is both off camber (slanted the wrong way) and slightly peaked at the apex, so it is a challenge for the car's traction control (TC) to intervene quickly enough. The rear of the car unloads at the apex as you accelerate through.
That said, holding second gear in "D" as I accelerate through the corner, the TC drives the car through the corner in complete control -- about 7 degrees sideways, and I can stay on the throttle.........doing the same thing in "S", and the car snaps sideways way further (and faster) than that, and I have to back out of the throttle or risk spinning out, at least according to my butt dyno.
I do believe that this is NOT a TC issue now. It is the throttle mapping that is so much more aggressive when in "S" mode. The same inch of throttle pedal travel in "D" that may get you to 1/4 throttle gets you to 1/2 throttle or more when in "S" mode. This brings on the HP and torque so much more quickly that the TC can struggle in certain situations to intervene quickly enough...........over and out......
Old 09-23-2016, 12:19 PM   #14
Very nicely written description Guard. Thank you
How does Ford limit wheelspin with traction control on? Guard 5.0 2015 Mustang GT 1 07-05-2015 09:50 AM
Traction control etc. light change??? brad_04mustang 1996-2004 Mustang GT 11 03-19-2014 09:34 PM
Sport mode mrkrabz 2011-2014 V6 Mustang 62 11-14-2012 07:58 PM
Sport Mode Rileychan01 2011-2014 V6 Mustang 3 08-04-2012 04:34 PM
Sport Mode Ravnus 2011-2014 Mustang GT 48 08-03-2011 11:29 AM
07:00 PM
