Latest news on the 2015 Mustang!!! - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2015+ Mustang Ecoboost (and V6)
Old 08-15-2013, 04:28 PM   #1
blackbeast12's Avatar
Region: Delaware
According to Ford inside sources reporting to Edmunds.com, The 2015 Mustang is set to loose at least 400lbs off the current body weight, but that’s not all.
A 400LBS Lighter, 15 Inch Shorter 2015 Mustang
Up until now, we have only been able to speculate about the next generation S550 Mustang being a smaller, more nimble vehicle. Now we have some solid evidence to support the findings. In addition to dropping 400 pounds in curb weight, the same inside source is also reporting a smaller in length 2015 Mustang–slicing off ~15 inches from the total size. This will undoubtedly have a positive impact on the 6th generation Mustang’s gas mileage and MPG. How much it will impact fuel efficiency, is still a mystery.
How this will play out with regards to interior space is yet to be seen, but given the tight constraints of the current Mustang’s back seats, one would wonder how much more room there is to loose from the interior compartment. For those of us who keep the rear seat belts buckled year-round, the prospect of loosing a little more real estate isn’t much of a concern, especially if that means dropping 400lbs.
2015 Mustang Dimensions vs The 2014 Mustang
Width: The 2015 is said to have a “10%” (~6.5 inches) shorter in width compared to the 2014 Mustang.
2014 Mustang: 73.9 inches wide — 2015 Mustang: 67.4 inches wide
Length: The 2015: 8% (~15 inches) shorter.
2014 Mustang: 188.5 inches in length and rides on a 107.1-inch wheelbase — 2015 Mustang: 173.5 inches in overall length
Weight: 2015 is set to loose ~400lbs curb weight.
2014 Mustang: 3,617.8lbs curb weight (V8 GT with Auto transmission) — 2015 Mustang GT: 3,217lbs curb weight
Pairing Less Weight With the EcoBoost 4-Cylinder Mustang
The drop in curb weight was brought on by two developments on the automotive world–Ford’s need for a more fuel-efficient fleet of vehicles and Europe’s tight vehicle sizing constraints. Given that we’ve heard reports and we have a video of the 2015 Mustang with a turbo’d 4 cylinder under the hood, its only natural to speculate how this new “SVO” will perform.
If the Edmunds report is true and the new Mustang sheds 400lbs of weight–not including the motor–the turbo 4-cylinder would have a curb weight of around 3,000lbs and be pushing somewhere around 300-350 horsepower. Comparatively, the last 4-cylinder turbo’d Mustangs–the 1986 SVO–came in at a curb weight of 3,049lbs and had a power output of 200 hp (149 kW) @ 5000 rpm 240 lb·ft (330 N·m) @ 3200 rpm. Throw in the addition of an IRS and shorter overall length, you have one completely overhauled pony car. Look out, there might be one formidable 4-banger with Mustang logos blowing the doors off older v8s when the 2015 model year Mustangs start rolling out.
The Coyote V8 Will Return in 2015
It’s not all a loss for the die-hard V8 crowd–in addition to a turbo 4-cylinder, the 2015 Mustang will also be produced with the current Coyote motor, possibly with a bump in power to between 450-475HP. A 2015 prototype videotaped doing test runs around the Dearborn, MI area had a V8 and sounded as good as ever, producing the low, muscle car growl we’ve come to expect from the beloved Mustang. The current V6 is set to return as the base model Mustang. The turbo 4 would be the middle ground while the V8 GTs would still be the premium model.
2016 Gt/Cs autowith 3:55', mbrp cat back and a n/a build on the way!...
blackbeast12 is offline   Reply With Quote
Old 08-15-2013, 04:30 PM   #2
MidnightBlueGT's Avatar
Im excited!
Old 08-15-2013, 04:39 PM   #3
McQueen's Avatar
I can't wait to test drive one
McQueen is offline   Reply With Quote
Old 08-15-2013, 04:41 PM   #4
I don't want to because ill buy one without $!
Old 08-15-2013, 04:43 PM   #5
Sounds good.
Old 08-15-2013, 05:57 PM   #6
tc x 4's Avatar
Glad I bought a 12 if it's true.
Old 08-15-2013, 07:03 PM   #7
Uncle Rusty's Avatar
If this is all true, there's no question in my mind I'll be upgrading the moment these are released. I mean wow, if the new 5.0 is in fact ~3200lbs w/ 450HP or so, she'd be competitive with the new Stingray.
2013 GT, 6MT w/ Track Package
Stage 2 VMP TVS, 82MM, ID1000's on E85
Eibach Suspension, X-Brace, Subframes, Control Arms, Balljoints etc...
Uncle Rusty is offline   Reply With Quote
Old 08-15-2013, 07:27 PM   #8
Termi's Avatar
Does it say anything bout a shelby or a new cobra?
Termi is offline   Reply With Quote
Old 08-15-2013, 08:06 PM   #9
Rynarok's Avatar
Is the model shown still a concept? If it is, I am glad that I've got a '13. I respect the weight loss and power bump, but the looks are too....Audi? for my tastes.
Marcie; Black 2013 GT. MT82, .373, track + brembo, JLT CF CAI, Boss Manifold, MGW StS, Blowfish Trans Bracket & Driveshaft Loop, Whiteline trans bushing, RP motor & tranny oils, Flowmaster Outlaws, BMR UCA w/ mount, LCA w/ relo brackets, panhard, SR springs, KONI oranges, J&M CC plates, staggered leguna secas, MT street comps
***A good driver is the best method to get more performance out of any car. ***
AXLEBACKS THREADS =
Rynarok is offline   Reply With Quote
Old 08-15-2013, 08:11 PM   #10
1lowGT's Avatar
I hope they stay with Shelby name. I think cobras should stay new edge and later
Old 08-15-2013, 08:48 PM   #11
alrefire's Avatar
I think the cobra should come back
But that's just me
I'd like to see the return of the Mach first
Old 08-15-2013, 08:49 PM   #12
I want to see what svt has in store for the newer cobras
Old 08-15-2013, 08:53 PM   #13
08Mustang's Avatar
Me too! I kept reading rumors of an all motor SVT cobra! Now that'd be sick!!
08Mustang is offline   Reply With Quote
Old 08-16-2013, 10:30 PM   #14
All I'm going to say is bring the Mach 1 back out!
Patrickandberry is offline   Reply With Quote
Old 08-16-2013, 10:31 PM   #15
Doe_Rae_mi's Avatar
Bring back the machs and cobras that what we Want dammit
Old 08-17-2013, 01:04 AM   #16
Termi's Avatar
From my understanding, the mach 1 is coming back for but it will be for 2016 or 2017 and also in 2016 or 2017, the gt350 will be an actual ford model since theres no more gt500. And apparently the gt is coming back too before the decade is out. Apparently this has all been "confirmed", but you know how that goes
Old 08-17-2013, 07:52 PM   #17
dobypaw3's Avatar
Here my 2 cents. If the picture is an indication of what is to be. Then the euro stye is definitely there. Making it smaller and lighter makes me think Ford is going to faze out the V8 and make room for the eco 6 as the premium in the future. The biggest upside is the 3200 pound 450+ HP GT... The Camaro and Challenger will need to up HP to 525 or lose about 800 pounds just to try and keep up!!! Other than the new GT being a beast. I am 100% satisfied in purchasing my 2014 GT.
---------- Post added at 09:52 PM ---------- Previous post was at 09:48 PM ----------
I also heard a rumor from the salesman at the dealership. That Ford is manufacturing 1000 2014 1/2 Mustangs to commemorate the true 50th. Has anyone heard this rumor?
dobypaw3 is offline   Reply With Quote
Old 08-17-2013, 10:19 PM   #18
Termi's Avatar
Yeah ive read that online
Old 08-18-2013, 11:18 AM   #19
I don't think ford will ever get rid of the V8, the technology now gives it the power and gas mileage. I could see a lot of mustang fans going ape s*it if ford puts more focus on the v6
Old 08-18-2013, 11:42 AM   #20
JimmyMosqueda's Avatar
Ford needs to quit playing and dump a V10 in a mustang lol.
JimmyMosqueda is offline   Reply With Quote
Old 08-18-2013, 11:45 AM   #21
Region: Delaware
Im at 19 mpg city with 629 hp on tap ...got no complaints!
---------- Post added at 01:45 PM ---------- Previous post was at 01:42 PM ----------
To much weight, they should put a naturally aspirated 5.8 in the new mustang!
Old 08-18-2013, 11:56 AM   #22
1lowGT's Avatar
To much weight, they should put a naturally aspirated 5.8 in the new mustang![/QUOTE]
Exactly!!
Old 08-18-2013, 12:01 PM   #23
alrefire's Avatar
But with the IRS? Can't be too much ;p
Old 08-18-2013, 12:06 PM   #24
Region: Delaware
The reason why you dont see anyone putting a v-10 in a mustang is because the extra weight would create a poor handling situation even with a rear irs set up!
Old 08-18-2013, 12:15 PM   #25
alrefire's Avatar
Hmmm
Turn it into a 2 seater with a mid mounted engine? Or read mounted.
But by then it's not a mustang :p
Old 08-18-2013, 12:15 PM   #26
I've driven a v10 fox. Seemed about right to me.
Old 08-18-2013, 01:48 PM   #27
Region: Delaware
You wont see anything from Ford bigger then a 5.0 after the 2015 model hits the lots..fabrication allows all possibillities including a 5.8 swap. This would be my engine of choice if i had unlimited funds and know how!
Old 08-18-2013, 02:21 PM   #28
08Mustang's Avatar
There will never be a V10 in a muscle car...it's just not what a muscle car is
Old 08-18-2013, 02:27 PM   #29
dobypaw3's Avatar
Right... But there will be a I4 in 2015. How does that belong in a muscle car? That is if you want to get technical.
Old 08-18-2013, 03:19 PM   #30
Termi's Avatar
I think an I4 performance engine would be cool for the mustang. Technically the mustang isnt really even a true muscle car, plus the backbone of the mustangs popularity was because it was the first car with a huge options list. Thats the whole point of the mustang... A little something for everyone
Old 08-18-2013, 03:46 PM   #31
dobypaw3's Avatar
Mustang is not a true muscle. I'm assuming you said this because of the various engine options less the V8. Then you can say pretty much all the late sixty and early seventy cars and cars of today that have an optional V8 are not true muscle cars as well. Most or all of them had the option of 6 or 4 cylinder.
What does muscle in Muscle Car mean? A: Big power V8.
So your telling me the 429 cobra jet is not a true muscle car because it is a mustang. Or the 662hp GT500 is not a true muscle car because it is a mustang. I guess the Camaro is not as well seeing how it is the Mustangs direct competition same with the Challenger.
I guess American Muscle has to change their name to American Almost Muscle. don't take me serious just joking!!!
Old 08-18-2013, 04:18 PM   #32
FortyBrandon's Avatar
Hmmm if my dad was alive I'd ask him how much muscle his 69 428cj mach 1 or 67 390 s code had. I asked his friend who is a Chevy only guy he honestly said that the 428 was the fastest thing he ever sat in.
FortyBrandon is offline   Reply With Quote
Old 08-18-2013, 04:43 PM   #33
alrefire's Avatar
+100
---------- Post added at 05:43 PM ---------- Previous post was at 05:42 PM ----------
I always thought of the pony cars as a sub-category of the muscle cars
It's a different type of muscle
Plus, if mustangs weren't muscle cars, then why is AM called American MUSCLE????
Old 08-18-2013, 05:23 PM   #34
The Merriam-Webster dictionary defines muscle cars as "any of a group of American-made 2-door sports coupes with powerful engines designed for high-performance driving."
Sounds like Mustangs fit this description pretty well.
Old 08-18-2013, 05:28 PM   #35
What else would be considered a muscle car if mustangs arent?
2015 mustang
10:52 AM
