2015 V6...stupid question - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2015+ Mustang Ecoboost (and V6)
Old 10-19-2014, 07:20 PM   #1
grom80's Avatar
If the engine on the new 2015 V6 is the same 3.7 than the 2014...why 300hp instead of 305hp ???
grom80 is offline   Reply With Quote
Old 10-19-2014, 07:29 PM   #2
white14v6's Avatar
They are trying to get more to buy the ecoboost.
white14v6 is offline   Reply With Quote
Old 10-19-2014, 07:31 PM   #3
It's the same engine and in the big picture 5 Hp doesn't mean much. Most likely it's a different tune but could also be from different intake/ exhaust.
You have to remember too the 15's are heaver so it you put the exhaust same engine/ drivetrian its going to get less MPG's. At the end of the day it doesn't even matter. It's like GM guys who argue about the LS1's cubic inches. Technically its a 346 and some change and not a 'True' 350. But if someone asks you just say 5.7 or 350 as nobody really cares about 3.xx cubic inches. Just like nobody that likes the V6 better then the EB is going to not buy the V6 because it makes 300 instead of 305. just not realistic. And likely even if the S197's would have been a longer production run Ford would have made small changes through the production run even if they kept the same actual engine.
StarzTA17 is offline   Reply With Quote
Old 10-19-2014, 07:42 PM   #4
grom80's Avatar
I agree with white14v6...
Old 10-19-2014, 11:10 PM   #5
Bear376's Avatar
They are pushing the Ecoboost and are making the V6 more bare bones for the comparison. They also retuned the engine slightly for better gas mileage and more power at low rpms. However, the listed gas mileage is not showing an increase for several possible reasons. Some of it may have to do with the legal headaches from the hybrids.
2013 MCA Edition-Sterling Grey
Roush body kit - Splitters/hood scoop
Whiteline suspension w/Koni shocks
Bear376 is offline   Reply With Quote
Old 10-20-2014, 10:56 AM   #6
grom80's Avatar
Because it's heavier...that's why it ain't showing a better mileage.
Old 10-20-2014, 05:33 PM   #7
UltArc's Avatar
He asked about HP...not MPG...lol.
My guess is nothing. Maybe they did make a change, but I doubt they would waste their time when they can just say 300. People get mad when a "300 HP " car only has 250. No one gets made when a "300 HP" car has 350. Same with MPG.
Luke 11:9-10 “So I say to you ...*search and you will find; knock and the door will be opened to you.
2012 Mustang EPA: 19/29
2012 AeroStang: 40/46
My sponsor, Tokkyo Nutrition, offers 50% off your entire order with the code "PowerHouse"
UltArc is offline   Reply With Quote
Old 10-20-2014, 05:42 PM   #8
Rapinator126's Avatar
Different intake manifold. Ford has said this a few times, you will not notice 5 hp anyways
Old 10-20-2014, 07:19 PM   #9
+1 Ive read this in an article, intake revision for the hood clearance.
Bigshow14 is offline   Reply With Quote
Old 10-20-2014, 11:02 PM   #10
Driven5's Avatar
I'm pretty sure that the shorter standard final drive ratio (3.15 vs 2.73) has more to do with the fuel economy hit than the (31lb MT / 12lb AT) weight gain.
-Justin
You can follow my Ford based 'Locost' build at:
GarageOdyssey.blogspot.com
GarageOdyssey.tumblr.com
@GarageOdyssey (instagram and twitter)
Driven5 is offline   Reply With Quote
Old 10-21-2014, 03:48 AM   #11
UltArc's Avatar
I have not
Heard about this at all. Thanks for the heads up, I'll have to look into it.
2015 Mustang GT PP vs 2015 Camaro 1LE Ish416 2015 Mustang GT 111 06-12-2015 04:52 PM
Wheel Question / possibly stupid question Rogue Slider Mustang Wheels & Tires 8 05-29-2012 12:21 PM
Stupid Stupid Bonds bluemustang The Bar 8 02-07-2007 09:39 AM
Stupid stupid stupid!!!! lowflyn The Bar 10 10-23-2004 07:33 PM
stupid question. DropTop_Stang The Bar 2 11-04-2003 08:18 PM
11:42 PM
