2015 3.7 v6 no new add ons yet - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2015+ Mustang Ecoboost (and V6)
Old 01-04-2015, 12:57 PM   #1
I have a 2015 3.7 v6 mustang hopefully someone can help
no 3.73 gears available yet
no cai available yet
I have a sct x4 tuner but no program from sct as of yet they haven't made one yet
oh I was able to do a catback magnaflow from my local exhaust shop.
anyone have any ideas.
in the mean time ill just hurry up and wait
thanks
rickb9ol is offline   Reply With Quote
Old 01-04-2015, 02:11 PM   #2
Should be the same 8.8 as the older cars. I believe the only thing that changed was going from a straight axle to the IRS. The center section should be the same. It won't do you any good until you can tune the car for the gear swap to correct the speedo and trans if auto.
Bigshow14 is offline   Reply With Quote
Old 01-05-2015, 01:45 PM   #3
davekro's Avatar
I am actually wondering what would be involved in possibly changing to a higher gear ratio. Hopefully to get back the MPG decrease from the 2014's V6. 2014 has a 2.73 ratio vs. the 2015's 3.15 ratio. Anyone know if the differential in the 2014 straight axle would actually be the exact same? Meaning a 2014 2.73 ring and pinion gear set could be put into a 2015 IRS axle?
How are the ring and pinions actually changed for the respective axles? Is it an accessible rear cover removal and (relatively) easily swap ring and pinion sets?
Thanks in advance. I'm new to mustangs.
davekro is offline   Reply With Quote
Old 01-05-2015, 05:49 PM   #4
on your 2014 you have to pull the axles out.its an easy job takes about 4 hours last time I did it
Old 01-05-2015, 05:52 PM   #5
i found 3.73 gears for the 2015 in Houston. they have 2 sets left.it is a special part number for the IRS
2015 no new add ons rickb9ol 2011-2014 Mustang GT 0 01-04-2015 12:51 PM
USB plug or other add ons in Edge blank dash buttons. brooksyx Pre-2005 V6 Mustang 9 01-02-2013 09:39 AM
add-ons to 98 cobra southernstang00 1996-2004 Mustang GT 0 06-16-2012 05:04 AM
Cold Air Intake Add-ons?? tvsr Pre-2005 V6 Mustang 2 10-10-2010 09:38 PM
2010 v6 Mustang performance add ons? Camaro Eater Pre-2005 V6 Mustang 3 06-04-2010 07:01 PM
06:06 PM
