????? Need help - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2015+ Mustang Ecoboost (and V6)
Old 05-31-2015, 04:02 AM   #1
stangs4l1f3's Avatar
????? Need help
So when I first got my car with regular gas (87OCT) it would tell me I had 295 miles to empty. Then when I finally got it to empty and filled it up for the first time with 93 octane it would say I had 260 miles to empty. And now every time I fill up it always changes it'll go from 230 miles to empty one fill up, then to 270 the next fill up I have about 1500 miles on my car it's an ecoboost mustang by the way do you think it's still breaking in or something or?? Any help welcome thanks!πŸ‘πŸΌ
stangs4l1f3 is offline   Reply With Quote
Old 05-31-2015, 07:02 AM   #2
Grabber Blue's Avatar
The computer isn't the most actuate thing in the world. When going between fill ups from empty to empty write down the actual milage of the car when you first fill up till your next fill up. See how many miles you did and you'll get a better idea of your avg mgp/ miles per tank. This way you can see if there is anything wrong with the car.
Grabber Blue is offline   Reply With Quote
Old 05-31-2015, 08:02 AM   #3
oxford5pointoh's Avatar
It's just taking what you are currently averaging per gallon and multiplying that by how many gallons are in the tank.
So drive like a mad man and average 17mpg it's going to take that x say 14 gal and say that's your DTE.
Make sense?
And on the same note if you drive like a crazy person and the DTE is low, then you drive conservative and start averaging 30mpg it will start to adjust the DTE.
I log all my gas fill ups and what I average per tank vs the DTE and it's actually very accurate if you stay consistent.
IG @Oxford5pointoh
Old 05-31-2015, 09:36 AM   #4
JimC's Avatar
Manually calculating isn't any more accurate than the computer. You are assuming that every time you fill up the pump pressure is exactly the same, the delivery of fuel is coming in at the same rate, the temperature is exactly the same, and that you are only putting exactly the same amount of fuel as you burned. Both the manual calculation and the computer are estimates - and I find both are so close that it really doesn't make a difference. Just clear the computer at each fill up and start from "0" and it is just as accurate as your pencil and paper system (maybe more since it is measuring the gas that goes through the injectors)
JimC is offline   Reply With Quote
Old 05-31-2015, 02:04 PM   #5
Thanks for the help guys! I appreciate it πŸ™ŒπŸΌπŸ™ŒπŸΌπŸ‘πŸΌ
Need quick help! Need to find 4.10 gears for 2010 v6 mustang?? Camaro Eater Pre-2005 V6 Mustang 2 06-08-2010 05:31 AM
Guys need help.. going to get new engine.. need advice Skyes97Stang Pre-2005 V6 Mustang 9 11-28-2009 12:35 AM
need some help from the electrically inclined (need to find a power transformer) fast64 The Bar 5 05-26-2006 03:58 PM
Need to choose new tires..need help KyleUSAF Mustang Wheels & Tires 13 11-29-2005 11:13 AM
Need Help with Viruses on my COMPUTER! HELP ASAP!! Autobadges.com The Bar 41 02-05-2004 09:53 PM
09:57 AM
