2015 mustang performance - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2015+ Mustang Ecoboost (and V6)
Old 11-13-2015, 11:23 AM   #1
Region: New Mexico
Hello all,
I recently bought a '15 V6 and decided I want to do a little performance work to it. So I started looking around and found very few performance parts.
Ideally I would like to dual charge with a super and a turbo. I found a supercharger for the car, but cannot find a turbo for it.
My question for my fellow mustang owners is, can I take a turbo for a 2014 V6 (like a hellion) and put it in the 2015, since it is the same engine, just in a different body?
Thanks you all in advance for responses.
Hannya is offline   Reply With Quote
Old 11-15-2015, 09:23 PM   #2
No, bolt on parts are different as the body is different. Intakes, exhaust, etc will all be difference. Not to say it couldnt be made to work with fabrication but It would not bolt up like it would a 2014
StarzTA17 is offline   Reply With Quote
Old 11-16-2015, 03:30 PM   #3
Voltwings's Avatar
Your idea is flawed on several levels, and i honestly cannot recommend you try to do this. The biggest reason plain and simple is that a compound system normally works with a positive displacement supercharger, of which there are none for the 3.7L, and a rather large turbo. The Positive displacement supercharger essentially looks to eliminate the lag of the larger turbo, and the larger turbo increases the efficiency of the supercharger by force feeding it. The two offset the weakness of the other.
The only supercharger available for the 3.7L is a centrifugal supercharger, which does not build large amounts of low end torque like a positive displacement blower. So basically trying to compound this with a turbo you would end up with massive amounts of lag from the nature of the centrifugal supercharger compounded with a large turbo, or by running a small enough turbo to negate any lag you would be incredibly limited on the exhaust side of this set up to warrant the time, money, and effort that has gone into it.
2015 mustang
2015 Mustang GT PP vs 2015 Camaro 1LE Ish416 2015 Mustang GT 111 06-12-2015 04:52 PM
2015 mustang gt performance pkg first 500miles kraus164 2015 Mustang GT 5 01-01-2015 03:18 PM
Bama Performance sets record for WORLDS FASTEST NA 2015 Mustang GT! AMAlexLazarus 2015 Mustang GT 24 11-10-2014 06:01 PM
Bama Performance Tunes AmericanMuscle's 2015 Mustang GT with JLT Cold Air Intake! AMAlexLazarus 2015 Mustang GT 3 11-03-2014 04:05 PM
NEW 2015 Mustang Parts from JLT Performance at AmericanMuscle! AMAlexLazarus AmericanMuscle 0 10-07-2014 03:19 PM
08:05 PM
