Shift knob - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs || Tech and Talk > 2015+ Mustang Ecoboost (and V6)
Old 08-18-2016, 03:41 AM   #1
Hampton CIT's Avatar
Shift knob
So before I pose my simple question, you get a brief story to mitigate the laughing. My last Mustang was a 14 and I had to have a cue ball shift knob. It ended up being my $500 knob. When I installed it, it stuck and in muscling it off I ended up twisting some detents in the shifter mechanism so much so that I had to replace the entire assembly. I did replace it with a Barton short throw shifter but those purchases aren't as fun with you break something and have to do it. There's a longer funnier version of this story but you get the context.
Fast forward to now. I picked up a new ecoboost to replace my 14'. I met an older gentleman who drove a Cadillac.. suddenly aka got T-boned and my '14 was totaled. So I go to replace the shift knob and that rascal is on tight. I'm reluctant to muscle it off in the context of above. Does anyone know if it is locktighted on or something like that or should I just man up and wrench it off.
2016 Premium Eco w/ PP - Roush Quarter Window Scoops, Side Scoops, Rear Spoiler; Modded GT Mesh Grilles; FP Strut Tower Brace; Eibach Pro-Kit Springs; Steeda IRS Bushings; BMR Billet Delrin/Spherical Vertical Links; Mishimoto Oil Separator; MAPerformance CAI; Mishimoto Intercooler/Aluminum Charge Pipes; Turbosmart Kompact Dual Port BOV; Turbosmart IWG75 Wastegate (10 PSI); Mishimoto Coolant Tank; JLT Engine Cover; Mishimoto Downpipe with modded MBRP XP Catbacks for TRUE 3" exhaust from turbo to tips; Drilled/Slotted Brake Rotors
Hampton CIT is offline   Reply With Quote
Old 08-18-2016, 04:12 AM   #2
Strange Mud's Avatar
Do the new ones press down to go in reverse or do you pull up a release? On the push down I would pull the boot down and either put a wrench on the flat of the shaft (if it has one) or rubber strap wrench/channel locks with rubber cushion if it doesn't have flats to prevent the shaft from twisting. w/o insulting look for set screw on knob but I don't remember one on my 2012. If you pull up idk if there is a trick to it.
Do NOT use loctite when replacing try Teflon tape instead
Old 08-18-2016, 07:00 PM   #3
This one is a pull up to defeat the reverse lock out.
03/04 Cobra Knob & MGW Radio Knob Matt@StangMods Mustang Parts for Sale and Wanted 0 07-21-2004 02:11 PM
Blah...shift knob. Dom Mustang Audio & Video 3 02-26-2004 11:49 AM
Shift knob question dUckPhrEak Mustang Audio & Video 2 11-24-2003 08:48 PM
Auto shift knob DropTop_Stang Mustang Audio & Video 9 11-02-2003 06:30 PM
removing auto shift knob Dave Pre-2005 V6 Mustang 5 07-28-2003 10:40 PM
12:13 AM
