Pony lights? - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 05-13-2015, 03:23 PM   #1
mylittlepony12's Avatar
Pony lights?
I bet there is already a whole discussion somewhere but I have yet to find it.
I want to add Pony lights, but I want them too look like the actual lights you get from Ford, but maybe not cost as much as Ford would charge.
Also, can I wire them differently so it's not only when the doors are open, maybe to a switch? Any suggestions are so welcome
Thanks!
Sent from mylittlepony12's iPhone using Mustang Evolution
mylittlepony12 is offline   Reply With Quote
Old 05-13-2015, 03:57 PM   #2
Kevin.Cook
Guest
Posts: n/a
This would involve precise cutting into the bottom of your side mirrors to allow the OEM pony lights to shine through. I believe they go for 40-50 each on ebay. Then you would need to tap in to some wiring in your door to get them to come on.
About the same as the Starkey puddle lamps install, except you get no template but at the same time, you have to be precise you will will have an ugly gap or something.
Old 05-28-2015, 01:03 PM   #3
oxford5pointoh's Avatar
I have seen this done. The mirrors actually have the outline of where you would cut. The parts can be had on eBay or from ford obviously. Then you would just need to tap into the wire already in your door. I believe it's a purple wire. I had the raxiom ones and they were cool but I didn't like how they hung down.
IG @Oxford5pointoh
Old 05-28-2015, 02:10 PM   #4
WJBertrand's Avatar
In the OEM set up the pony lights are switched on and off with the dome light / dash dimmer control next to the head light switch.
-Jeff-
Ventura, CA
2013 GT Premium Brembo
MGW, Blow Fish, AM Hood Struts
Tinted, Borla Touring AB, ProCal Tune
Full Shelby/Kicker Audio Upgrade
WJBertrand is offline   Reply With Quote
Old 05-29-2015, 07:08 AM   #5
Kevin.Cook
Guest
Posts: n/a
If you need help finding the parts or anything, let us know!
Old 06-04-2015, 11:09 AM   #6
sid719e's Avatar
You can get the oem puddle lamps from Ford White Bear Lake for less than $20 a piece. Don't get the eBay crap.
Right side:
PUDDLE LAMP | Genuine Ford | DR3Z-13B374-B
Left side:
http://parts.autonationfordwhitebear...rd/dr3z13b375b
sid719e is offline   Reply With Quote
Old 07-28-2015, 11:50 AM   #7
So I finally got them, they are not perfect and they are as far out on the mirror as you can go but the image still is disrupted by the bump in the door :-/ I'm ok with it because they look so cool! let me know what you all think!Click image for larger version
Name:	ImageUploadedByMustang Evolution1438105772.134989.jpg
ID:	188196Click image for larger version
Name:	ImageUploadedByMustang Evolution1438105786.430819.jpg
ID:	188197Click image for larger version
Name:	ImageUploadedByMustang Evolution1438105809.094651.jpg
Old 07-28-2015, 11:51 AM   #8
Kevin.Cook
Guest
Posts: n/a
Yea I wouldnt imagine those would look the best under the mirror. Those are meant for under the door if I remember right.
Old 07-28-2015, 01:49 PM   #9
tym_v6's Avatar
Is there a way to adjust the tilt of the lamp inside the mirror housing? You might be able to aim it so it doesn't hit the door.
Old 07-29-2015, 08:38 AM   #10
I was thinking of trying to angle them with some kind of shim, we will see. No, they are advertised and sold as mirror insert lights, not running lights.
A clean pony is a happy pony 245ciPony 2005-2010 Mustang GT 34 03-19-2013 08:28 PM
pony projection lights D2theJ2theC General Mustang Discussion 3 08-10-2012 10:47 AM
Pony Package Fog Lights 08Mustang 2005-2010 V6 Mustang 19 03-12-2012 01:58 PM
Chrome pony or black chrome pony shsfresh87 Mustang Paint, Appearance & Detailing 9 01-30-2012 09:58 PM
05 Pony Flood lights Mystang.GT 2005-2010 V6 Mustang 2 10-14-2011 02:26 PM
02:43 PM
