Fox Body - sagging driver's side rear suspension - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 05-26-2015, 05:40 PM   #1
BossDrew's Avatar
Region: West Virgina
I've got a '90 LX convertable with a sagging rear end on one side. The passenger side measures 3.5" between the top of the tire and the bottom of the wheel well and the drivers side only measures 2". I've got brand new shocks (last August) and I can't see any issues with the coils. I've been watching it for a couple of weeks after driving just to see if something would settle out, but the spacing has stayed the same after several weekend trips. What do I need to look into? I'm interested in some lowering springs, but first I need to figure out why the stock height is so off. Both fronts seem to measure the same. Thanks for your help!
_______________________________________
1990 LX Convertible / 25th Anniversary
BossDrew is offline   Reply With Quote
Old 05-28-2015, 02:20 PM   #2
oxford5pointoh's Avatar
Sounds like one of your rear springs could be bent or broken? It's hard to say without seeing some pictures. There are so many things that could contribute to it. Do you have any other symptoms?
Has the car ever been in a accident? It could have a bent frame or be tweaked from a collision in some way.
IG @Oxford5pointoh
Old 05-29-2015, 04:44 AM   #3
bucko's Avatar
If there's no apparent rust issues at the spring locations or physical frame damage, then I'd also suspect a weak spring at that side.
Old 05-30-2015, 05:05 PM   #4
Jon3.7's Avatar
I don't know if they had it back then, but if you had rubber isolators, the driver side might have broken into pieces and fell out. That would be around a 1" difference... Can you get up underneath the car and see?
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
fox body
sagging Jzelm10 1979-1995 Mustang GT 5 10-11-2013 05:03 PM
Sagging door Mustangman705 1996-2004 Mustang GT 2 10-03-2013 04:34 PM
1994 Mustang V6 sagging doors... HELP!!! devanslive Pre-2005 V6 Mustang 10 04-18-2013 12:28 PM
Driver side rear wheel bearing 10cches 1996-2004 Mustang GT 3 08-05-2012 01:51 PM
sagging doors :( 87blackonblack 1979-1995 Mustang GT 20 02-24-2012 10:32 PM
03:47 PM
