2006 2007 V6 Flexplate differences - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 05-31-2015, 07:13 PM   #1
Hi everyone. This is my first time posting and I was hoping someone could help me figure out what direction to take regarding my 2007 Mustang 4.0l automatic. I picked it up for cheap to use as a daily driver. It was cheap because the motor was seized (which I knew). I was able to pick up a 2006 4.0L with 80k on it for only $250 from a friend. The 2006 does not have a flexplate. After checking, I see the flexplates have different part # (2006=4R3Z6375AA; 2007=1L2Z6375CA), so it looks like I need to buy a 2006 flexplate, correct?
But I also see the torque converters are different too (2006=4R3Z7902AARM; 2007=7L2Z7902ARM). Do I also have to buy a 2006 torque converter and will the 2006 torque converter work with my 2007 transmission?
Thanks for the help!!
Steve
steveg23 is offline   Reply With Quote
Old 06-01-2015, 06:50 PM   #2
Jon3.7's Avatar
Where did you get the part numbers from?
Take it you called your local dealer? I would keep the torque convertor the same as the trans, fly wheels should, aka, should be the same.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-01-2015, 08:12 PM   #3
I did a search on a Ford dealership website to get the part numbers. The 2005-2006 4.0 V6 torque converters and flex plates had different part numbers than the ones for 2007-2010 Mustangs 4.0 V6. I can't seem to find the reason for the changes between 2006 and 2007. There must be reason why different part numbers are listed. Is there a balancing/weight difference?? I don't want to put everything back together only to find a vibration or some other issues and then have to tear things apart again.
Old 06-02-2015, 05:36 AM   #4
Jon3.7's Avatar
If you have all the parts for a 2007, put all the 2007 stuff on it.
Which car should I get? A 2006 Corolla S, 2006 Mazda 3i Sedan, or a 2005 Lancer Es? brant General Car Discussion 5 07-19-2011 04:23 AM
2007 Roush 427r :: 2007 Ford GT Roush 427r Roush427r Member Garages 0 06-15-2011 12:01 PM
Pony 2007 :: 2007 Ford Mustang V6 automatic blackbeauty Member Garages 0 06-15-2011 12:01 PM
2006 GTO or 2007 Mustang? boothe General Mustang Discussion 8 03-08-2010 07:47 PM
Which should I buy? A 2006 Nissan Altima SL? Or a 2006 Ford Mustang v6? sutton General Car Discussion 3 03-01-2010 09:57 AM
03:57 PM
