Best Way to Trace Rattles? - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 06-07-2015, 01:35 PM   #1
Hi all, I have a 2013 GT, and I have a couple of rattles. One is a tinny rattle that seems to come from under the car. It happens inconsistently, so it seems to be hard to diagnose. I thought it might be the heat shields, and it seems like there are 4 aluminium pieces on the bottom, of which, I removed two (easy to get to).
I'm asking on that one because there are two parts still there, and I kinda still hear the rattle. I wanted to see if there was anything else it could be.
The second one is from the Door. I have the premium sound package, and i hear a metal piece on some songs. if I push or tug on the door panel, it goes away. Also it comes from the middle of the door panel. There's nothing in the map holder, I checked. Any tips?
cougar618 is offline   Reply With Quote
Old 06-08-2015, 06:36 PM   #2
Jon3.7's Avatar
Question... does the rattling noise happen when driving? or can you physically move the car by pushing on it and hearing it
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-08-2015, 07:45 PM   #3
Hmm, it's more like it happens when the car is 'on'. I don't think I can reproduce that sound while off by moving it. It's still a pretty bad tinny sound rattle between 2k and 3k RPM.
Old 06-08-2015, 07:51 PM   #4
Might check the exhaust.
Adventure till you drop
Old 06-08-2015, 07:52 PM   #5
natestang07's Avatar
Loose hangar or bolt or something on the exhaust somewhere
Old 06-08-2015, 08:01 PM   #6
That's my thought too, but the exhaust should be somewhat floating anyways, right?
It seems to be a bit better since I was able to remove the rear heat shields... If I could have seen where the upper bolt was located for the front two, maybe I would have eliminated the rattle all together, or at least, had one less area to suspect.
Are there any common trouble areas for exhaust hanger vibrations on the S197?
Old 06-08-2015, 08:06 PM   #7
The rear hanger on one of my mufflers came loose once and rattled
Old 06-08-2015, 08:09 PM   #8
Ahh I see. I'll check that this weekend then. Thanks.
Old 06-09-2015, 03:43 AM   #9
Strange Mud's Avatar
a length of hose is often used as a mechanic's stethoscope. I would be leery of keeping heat shields off. If you isolate it to a shield 1st remove/remount it sometimes that is all it takes then if that doesn't work you can try putting a little bend in it. For the door panel look at some of the speaker install threads on how to remove the panel (hint there is a screw behind the handle) the panel comes off easy.
Good luck mine has several I deal with by doing the following:
1. Mash right pedal with aftermarket exhaust
2. Turn up radio
3. Ignore.
Old 06-13-2015, 10:51 PM   #10
tym_v6's Avatar
The linkages going to the lock pins on my door can rattle, typically with bass from the speakers (probably from the subs being in the doors).
OP, you might also try jiggling/pressing the lock pin and handle to see if that affects the door rattle.
Natchez Trace Pkwy swilliams500 General Mustang Discussion 6 10-07-2012 04:56 PM
Huge Mustang Natchez Trace Cruise Nov 2nd. SVTOA-Memphis lowflyn Regional Mustang Discussion 10 10-27-2008 11:16 PM
so i stopped the interior rattles Kyle Mustang Audio & Video 2 09-25-2007 07:32 PM
Spoiler Rattles jaredp Mustang Audio & Video 22 06-25-2007 03:25 PM
How i got rid of 99% of the rattles w/subs+ windshield decal mexor The Bar 3 10-18-2003 09:31 PM
03:05 AM
