Check brake system check advancetrac - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 06-07-2015, 07:14 PM   #1
Help!! MY BRAKE FLUID LOW,ADVANCETRAC AND BRAKE LIGHT CAME ON AND STAYS ON PUT GRAKE FLUID IN LIGHTS ARE STILL ON ANY ONE KNOW WHAT PROBLEM COULD BE
Ceci850 is offline   Reply With Quote
Old 06-08-2015, 06:37 PM   #2
Jon3.7's Avatar
Take your CAPS LOCK OFF, second off, check your brake fluid.
Should be a reservoir attached to a black circlular object on your firewall in your engine bay. If you can't find it, have it towed to the dealer.
2013 GT, A6, VMP Tuned, Lethal O/R H pipe, GT500 Mufflers
2016 EB, A6, Steeda Tuned, Steeda CAI
Jon3.7 is offline   Reply With Quote
Old 06-09-2015, 05:22 AM   #3
Waylap1's Avatar
Region: New Hampshire
Disconnect battery for 15 minutes.
Waylap1 is offline   Reply With Quote
Old 06-10-2015, 03:55 AM   #4
Strange Mud's Avatar
details on your car and more symptoms can be helpful.
Old 06-10-2015, 11:06 AM   #5
Kevin.Cook
Guest
Posts: n/a
Just like Jon says, check the reservoir under the hood on the drivers side. It is attached to the Master Cylinder (Black thingy on the fire wall). You could also disconnect the battery, pump the brake a few times, reconnect the battery. And see if there is a change.
Old 06-13-2015, 10:53 PM   #6
tym_v6's Avatar
Also check for any puddles/drips of brake fluid on the ground. If you have a bad line or leaky caliper, that could be your problem.
Old 06-14-2015, 07:05 AM   #7
Want to thank everyone for their help had problem fix.
It was the sensor in the brake res. $270.00 In labor and 70.00 in parts
Thanks again
Old 06-16-2015, 04:05 AM   #8
thx for update, glad it's fixed.
Service Advancetrac Untamed5.0 2011-2014 Mustang GT 15 01-30-2016 07:28 AM
Advancetrac sport mode jomcgui 2011-2014 V6 Mustang 25 02-08-2013 08:37 AM
Difference with advancetrac and sport mode Maverick2004054 2011-2014 Mustang GT 11 02-07-2013 03:33 PM
How does AdvanceTrac work Fo Sho 2011-2014 V6 Mustang 7 07-10-2012 01:23 PM
2011 mustang gt advancetrac Jack Israelyan 2011-2014 Mustang GT 16 02-06-2012 07:34 PM
03:52 PM
