Glove compartment key - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 06-18-2015, 01:05 AM   #1
Julio1797's Avatar
Probably a dumb question but how can you lock the glove compartment?
Was the dealer supposed to give me the two remote keys and a regular key for the glove compartment?
Julio1797 is offline   Reply With Quote
Old 06-18-2015, 01:30 AM   #2
tym_v6's Avatar
To my knowledge, the glove compartment does not lock (at least through the '13 MY). The center console compartment does; you use your ignition key. It doesn't insert the full depth, but will still turn to lock/unlock the console.
Old 06-18-2015, 04:23 AM   #3
Strange Mud's Avatar
+1
Old 06-18-2015, 08:38 AM   #4
Julio1797's Avatar
Its a 2015 so I only have the fob keys.
Old 06-18-2015, 08:44 AM   #5
oxford5pointoh's Avatar
Shouldn't it have a key in the fob in case the fob stopped working or the battery was dead?
IG @Oxford5pointoh
Old 06-18-2015, 08:51 AM   #6
I'll retract my answer as idk about 15 glove box.
Old 06-18-2015, 11:37 AM   #7
tym_v6's Avatar
IG @Oxford5pointoh
I think so. It's probably tucked into the fob somewhere that's easy to miss.
Old 06-18-2015, 11:46 AM   #8
bucko's Avatar
Yep, there should be a "stub" of sorts that slides into the fob that you pull out (key)to manually insert and unlock or use for the glove box/center console door.
On a side note, does anyone actually put gloves in a glove box anymore? I guess it sounds better then calling it a "junk box".
My wife's BMW had a feature where it would start as she approached the car...I always though this was not a good idea, as a crook could push her aside (car jack) and drive off. Then BMW informed us that if they (crook) did not have the fob, the car would run for about 100 yards (enough for her to run, and run fast!) away from the scene, and the doors would lock. The crook could not unlock them without the fob.
Old 06-18-2015, 11:48 AM   #9
natestang07's Avatar
The glove box on the 15 does in fact lock
Old 06-18-2015, 01:25 PM   #10
Abominable Mustang
WhoDat's Avatar
Region: Alaska
On the back of your key fob, you'll see a release tab. Pull this and lift to remove the cover on the fob. Inside you'll find a physical key.
Sent from the Death Star.
2012 Kona Blue 3.7L V6:
Old 07-17-2015, 09:42 AM   #11
Julio1797's Avatar
Awesome, thanks. I knew there had to be a regular key just in case of a power failure.
Old 07-27-2015, 07:21 PM   #12
Julio1797's Avatar
Just called Ford Customer service and they informed me that the key you refer too is not issued standard with the new purchase. They said it depends on the dealer and of course Viva Ford El Paso don't give you that key with the purchase, only the 2 key fobs
Old 07-27-2015, 11:39 PM   #13
tym_v6's Avatar
Wow, that was the Cust Service answer? How else would you get into the car if the battery's dead? Do they really expect the owner to call Ford Roadside Assistance? What if the battery died and there was a small child or pet in there on a hot day? Nobody's going to wait an hour for a tow truck to show up.
Old 07-28-2015, 06:35 AM   #14
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Did you check both key fobs to see if either had a key in it? I guarantee it's a standard option no matter the dealer. Like others said, how else would you get in the vehicle if the battery is dead?
Old 07-28-2015, 08:47 AM   #15
Julio1797's Avatar
Yeap I checked both key fobs and nothing. I agree with you, it should be standard but I guess it's a way for the dealer to make a little extra money. I can't believe this!!!!
Old 07-28-2015, 09:11 AM   #16
looking at the owners manual online it describes how to open the fob to access the mechanical key.
w/o insulting have you done that?
Old 07-28-2015, 10:17 AM   #17
Julio1797's Avatar
That's the first thing I did before calling. I also checked the bag where the owners manual is just in case and nothing there also.
Old 07-28-2015, 10:19 AM   #18
Julio1797's Avatar
The rep from Ford Customer Service said that it was up to the dealer to cut one of those for you when you purchase the vehicle. This doesn't make any sense to me, it should be standard.
Old 07-28-2015, 11:06 AM   #19
I would go talk with sales and say you forgot to give me this.....be nice and mention you haven't filled out your dealer review yet (if they don't help you when first asking)
Old 07-28-2015, 02:46 PM   #20
tym_v6's Avatar
^ Agreed.
Maybe a little key switcheroo happened?
glove box rattle fix lpardo 2011-2014 V6 Mustang 3 05-02-2015 11:20 PM
Glove box stangz13 2011-2014 Mustang GT 7 03-28-2015 07:52 PM
Glove Box Light!? TheMachine 2011-2014 Mustang GT 8 11-17-2014 11:20 AM
Shelby Signed Glove Box Mlarv5 Shelby Mustang 12 02-16-2013 07:11 PM
Weird noise under glove box Blackedout Pre-2005 V6 Mustang 15 03-24-2012 06:53 PM
03:58 PM
