A very strange behavior after battery got empty - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 06-19-2015, 07:40 AM   #1
Hi guys,
I have a 14 GT Auto transmission running 93R tune by Bama.
A very strange thing happens to me today and I would like to have your help.
My battery went empty (not sure why) and then I recharged it using cables connected my brother's battery car.
I start driving right after I car ignited and at first I felt a very big knock when I changed gears from Neutral to Drive and also to reverse. Something very unusual.
In addition, while driving, I felt like my car is having very high RPM but car is barely moving. Something like RPM go to 3 but my car hasn't even started to move! When I got to 40-50 MPH RPM refused to go down and it felt like the gear is not changing to 4th and 5th.
I decided to pull over, turned off my car completely and started again, only after that I think my car went back to normal: gear and RPM.
What's the explanation for this issue? Is it related to the BAMA tune?
Thanks!!
demas is offline   Reply With Quote
Old 06-19-2015, 08:20 AM   #2
Strange Mud's Avatar
I believe this is why Bama says NOT to do idle re-learn. The first bit after battery disconnect can be angry.
2012 V6 with suspension, shifting, stopping and sound mods.
Strange Mud is online now   Reply With Quote
Old 06-19-2015, 09:25 AM   #3
So is this normal?
How should get back to normal, as before battery went empty?
Thanks
Old 06-19-2015, 09:40 AM   #4
drive it for a while....you may want to reload tune but if it's working now I would let it be. Batteries do not like going dead, it may not last now but see. Did you leave anything plugged into the power ports or something else that may have drained the battery or not run it for 2 months? The ports do not shut off ever...
Old 06-19-2015, 10:35 AM   #5
I listened to music while the keys were in for a few hours..
Seems like car is driving normally again.
Thanks
Old 06-19-2015, 12:57 PM   #6
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Not sure why your battery went dead? This right here is why.
If the issue with your car's drivability comes up again, reload your tune.
2012 Kona Blue 3.7L V6:
Old 06-19-2015, 03:53 PM   #7
Sure, I will!
Thanks!
Old 06-22-2015, 07:09 AM   #8
alucard3600's Avatar
Something similar happened to me after I took the battery out to work on my car, it was out a good 10 hours, and then as soon as I put it back in, I loaded up a new tune, and my rpms have been a little high, so it may be a similar problem. Normally like they said normally the tune will sort its self out after a while as your ecu relearns it, but if it keeps having problems maybe datalog and request another tune to see if it helps?
2014 3.7l Auto Oxford White
Mods: Cervini Stalker Hood, Roush highflow upper and lower grill, AirRaid CAI, LMR strut tower brace,Mac LT headers,Mac Prochamber, Kooks Highflow Cats,Dynomax Race Bullets (resonators), 2.5 o/a pipes, 2011 Gt500 Axlebacks, MPT 93 performance tune.
alucard3600 is offline   Reply With Quote
Old 06-23-2015, 11:10 AM   #9
i eventually re-tuned just in case.
Everything is back to normal now
thanks
Miles to Empty went up after CAI Install MichaelDieguez 2011-2014 V6 Mustang 10 07-07-2014 11:12 AM
Help - New throttle body weird behavior. PureVenom 1996-2004 Mustang GT 44 04-22-2009 03:51 PM
BUSTED! very very very slight WW Tbird232ci The Bar 6 12-18-2005 02:54 AM
A reminder of proper behavior as we head to holiday festivities!* Herbstang The Bar 1 12-16-2005 10:56 AM
11:43 AM
