Mirror Tap to Hardwire Radar Detector - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 07-18-2015, 12:43 PM   #1
Hi,
I'm trying to hardwire my radar detector into the rearview mirror molex connector of my 2015 Mustang. Does anyone know the color codes for the wires? I need to find the ground wire and the power wire. My volt meter probes are too large to get readings. Thanks.
Steve
libsa is offline   Reply With Quote
Old 07-18-2015, 02:49 PM   #2
tym_v6's Avatar
I don't, and you probably don't need to either. Can you stab paper clips or bits of stripped copper wire into the back of the mirror connector? If so, you can then touch your multimeter's probes to those to find power and ground.
Old 07-18-2015, 02:57 PM   #3
Thanks Tym_v6,
Good idea. Connector holes too small for paper clips, but pins/needles might work. I'll give it a try.
libsa
Old 07-18-2015, 03:00 PM   #4
tym_v6's Avatar
What about the pins of the mirror tap wire? You might be able to use those if there's enough exposed metal.
Old 07-18-2015, 03:02 PM   #5
Thanks! Good idea. Connector holes too small for paper clips to work, but thin wire or needles should work. I'll give it a try.
libsa
Old 07-19-2015, 02:23 PM   #6
Usually the vendor that sells the mirror tap has the info on their website, or give them a call.
GT 1 is offline   Reply With Quote
Old 07-21-2015, 10:47 PM   #7
tym_v6's Avatar
libsa, how'd you make out?
Hardwire radar detector?? black94stallion 1996-2004 Mustang GT 1 03-29-2013 10:46 PM
Radar Detector PureVenom The Bar 11 01-31-2007 11:09 PM
Radar Detector Question Dark02Pony The Bar 5 04-24-2005 06:49 PM
radar detector charkelly9 The Bar 18 04-07-2005 12:21 PM
10 Band Laser Radar Detector...New... Junior2561 Mustang Parts for Sale and Wanted 6 05-21-2004 09:54 PM
08:03 PM
