converting to power seat - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 07-27-2015, 01:16 PM   #1
I have a 2014 mustang gt, the passenger seat is too low for my wife to sit at a normal height, can the track assembly be converted so it adjust like the drivers side, is power seat an option to consider? Thanks
naquin14 gt is offline   Reply With Quote
Old 08-10-2015, 07:13 PM   #2
Shadetree43's Avatar
I have the same situation with my wife & my 14 v6 premium. I'm looking for a powered passenger seat. Figure I can change the base & use my seat back & bottom. Eventually one will show up in a junk yard.
Shadetree43 is offline   Reply With Quote
Old 08-10-2015, 08:10 PM   #3
tym_v6's Avatar
I remember reading that it's not as simple as it seems. I think the wiring harnesses are different for cars with manual vs. power seats.
Old 08-11-2015, 07:51 AM   #4
That could be. Driver's seat has power all the time. If need be could just wire pax seat to hot all time fuse.
Locally there are a 12 GT & a 11 V6 being parted out. Will find out soon if either has a powered pax seat.
Old 08-11-2015, 12:38 PM   #5
passenger seat
Good idea about the parts yard, i might look into to that myself, keep me posted, thanks for the input.
Old 08-13-2015, 04:03 AM   #6
bucko's Avatar
To avoid any delay in installation, you could remove the seat and inspect for the additional wiring that would be needed for the power seat. This way you'd know if you need the additional plug and/or wiring on the existing plug that could be removed from the donor vehicle. You could save a trip or two and get it all in one shot.
Old 08-14-2015, 03:05 PM   #7
Concur 100% Bucko,
That used to be 1/2 the fun of going to the "u-pick-it" salvage yards for me. When my three kids were all at home & I had five vehicles to maintain, semi-monthly trips for used parts was inevitable.
No telling what you could find. One trip netted a genuine factory installed in the dash (and it worked for $10.00) CB for my 1979 Dodge Aspen Wagon . Opps guess that's a subject for a different forum.
Old 08-14-2015, 03:07 PM   #8
You could pull the seat out and use spacers underneath it when bolting it back in.
Old 08-14-2015, 04:09 PM   #9
Found FORD OEM powered (without heat) passenger seat wiring harness for 2013-2014 Mustang on Amazon. Shows FORD part # DR3Z-14A698-BA.
Could uses spacers on rear bolts, but will have to fabricate small extension on front brackets. They bolt in horizontal.
Manual Seat convert to power seat drivers side Didi1606 1996-2004 Mustang GT 0 08-29-2013 10:09 AM
Switching from manual seat to power seat - questions Black_Sunshine Pre-2005 V6 Mustang 3 07-02-2010 07:44 AM
Converting from Single to Dual Exhaust GOStang08 2005-2010 Mustang GT 2 04-13-2009 11:08 AM
Help converting 3-speed to 5-speed, please! suffolkpony Classic Mustangs 5 09-11-2007 07:29 AM
Converting V-6 auto-->manual megax29 Pre-2005 V6 Mustang 15 09-06-2004 08:29 AM
05:32 AM
