2006 Mustang random starter issues - Video included - Mustang Evolution
Go Back   Mustang Evolution > Mustang Evolution | Community Forums > Mustang 101 - Tech Basics | Ask an Expert
Old 08-01-2015, 11:17 PM   #1
mustanglindsey's Avatar
Region: Oregon
Hello! I need some advice for the problem that I'm having with my 2006. It usually happens once a month - I go to start my car and it just won't turn over. It makes a little click and sad noise, and it won't start. The lights and everything else come on, but it doesn't start until the 4th or even the 20th time. It stopped happening for about 5 months, and now its happening again.
I replaced the battery, and the dealership is unable to replicate the issue so they cannot find the problem. Has anyone else had this, or do you have any advice? This is so frustrating :/
Here is the video from today: (Car finally starts at 1:33)
mustanglindsey is offline   Reply With Quote
Old 08-02-2015, 05:10 AM   #2
Strange Mud's Avatar
I couldn't tell when it was happening but when you put the key into the crank position is that when all the dash lights go off? If so I would look at battery cables and connections to ground.
If when you put the key into crank position and nothing happens (but lights stay on) you are going to need to check voltage to starter solenoid.
Intermittent problems are a nightmare...good luck
Old 08-02-2015, 12:09 PM   #3
tym_v6's Avatar
When instrument lights go off with the key in crank, does ALL the electrical stuff die too (headlights, radio, etc.)?
If so, in addition to Mud's great suggestion, I might look at the ignition system too.
Might also be worth peeking into the fuse boxes and making sure all the fuses and relays are fully seated in their sockets. You might get lucky and find something.
Old 08-05-2015, 04:57 AM   #4
Also is it std or aouto? If stick shift clutch safety switch, auto neutral safety switch. try pressing releasing the clutch or putting it in neutral/park if auto
2006 mustang
Hello, 08 GT Premium.. Video included! Crixus New Member Introductions & Greetings 13 09-29-2014 04:00 AM
Starter solenoid or starter lost need some help Muller 1979-1995 Mustang GT 7 09-03-2013 08:14 AM
Question will a foxbody starter and mini starter Stang.racr 1979-1995 Mustang GT 3 05-08-2011 10:45 PM
Replaced starter in 67 Mustang with a Powermaster High Performance Starter with internal solenoid? rooney Classic Mustangs 3 03-27-2010 08:24 PM
03:24 AM
